Question about Luminox 3007 Original Navy Seal Diver Series Watch
Date is always a day behind or early ???
How do I set the date on my Luminox watch so that it will change at the correct time instead of at random times....
  • 2,334 Answers
Use this link and browse through my TIPS AND TRICKS: http://www.fixya.com/MyProfile/tips.aspx?usrid=1700524. You will find manual for your watch there.
Posted on Apr 26, 2010
Date changes at mid day not at mid night.
Your watch is 12 hours out of step.The date changes ever second rotation of the hour hand.
If you advance the time 12 hours, the date will change at midnight.
You may have to re-set the date.
Sep 16, 2011 | Tissot PRS 200 Wrist Watch
I have a Tissot Automatic PR 516 from the early 70s. Time is kept well. Date moves forward correctly but it is the wrong date. I am unable to turn back the date. I am able to turn back the day. Any...
The crown wheel (winder) should have 3 positions, (1) the normal winding position (3) fully out; at this position the watch stops and the time can be adjusted.
(2) This position is between the 1 & 2 and is used to adjust the day and date. If you wish to change the date by winding the crown backwards or forwards.
Since watches can very a little, if turning the crown when in position 2 the date does not change, pull the crown to position 3 and turn the hands until you pass the midnight position, when the date will change and then re-set the time. If you wish to advance the time more than one day, when it changes, wind the crown backwards past the midnight position and then wind it forwards again. Repeat until the correct date is showing and then re-set the time. The exact distance you need to turn the crown to change the date will have to be found by experimenting!
Feb 06, 2011 | Watches
Set the correct date for my Luminox watch?? Date changes at random times???
Apr 26, 2010 | Navy Seal Luminox Dive Watch
How do you set the day/date on a watch????????
Try this solution I posted earlier for a similar problem.
Put stem into "set hands" position and adjust hands to the 12:00 position. Day and date should advance at or close to that time.
If you pass 12:00 and there's no change continue rotating another 12 hours (to twelve o'clock again) and they should advance. Once you've found that there's midnight.So say it's now 4:00pm you would need to rotate the hands around the dial again so they pass 12:00 once more (12:00 midday) then four hours more to 4:00.
To set the day/date you can set the crown (winder) to the first position (second posn is "set hands) and rotate winder
eithr clockwise or anticlockwise. Once you discover which direction advances the date and day ring just set it to the correct day/language and date you want then press the crown home.
Hope this solves your problem.
Jul 17, 2009 | Seiko Wrist 5 SNKA03K1 Automatic...
Rolex watch yacht master set time
Let me start by saying that I own this watch and LOVE it!
To set the time you need to pull the crown all the way out to the furthest position.
To set the date you need to have the crown in the position in between the "winding" position and the "time set" position. Basically, pull the crown out till you hear/feel 1 click to wind, 2 clicks (total) to set the date, and 3 (total) clicks to set the time. I always set the date first to 1 day behind the current date. I then move the crown out to set the time so that I can set the watch to either AM/PM depending on the actual time. For example, I set my Rolex today (the 5th of January at 3pm - just an example). I would first move the crown to the date setting function and move it to January 4. I would then move it out one more position to set the time. I would go around the watch until the date changed to the 5th and then go around from 12 to 12 to change from AM to PM. I would then move it to the 3 and then I'm all set. This is helpful because it will ensure that your date will correctly change when the day changes and not be 12 hours behind.
Jan 03, 2009 | Watches
Setting watch date, day, etc.
yes. i do this problem
Jul 04, 2008 | Watches
Date setting on Citizen 0510 chronograph
Try this method. Set the date until it reads a couple of days in the past and then set the correct time. Of course do not touch your date or time settings between the hours of 9PM-1AM. Wait until the next day, then move the hour hand forward until you reach the current date with the correct time.
Jan 09, 2008 | Citizen Eco-Drive BL5184-56L Wrist Watch
Luminox 8200 series dive watch date set issue
This movement has a really quirky thing going on, its one of the few movements that you can actually turn the hor hand to set the day forwards or backwards...so on a day that goes from the 31 to the 1st it will advance fine, if there is no 31 for that month you can turn the hour hand 2 cycles and it will advance through the 34, continue to the 1st and set time...date can also be set by turning the hour hand backwards thru the dates...go ahead it doesnt 'hurt' the movement a bit, its made for this...so in oither wiords, when you get a new cell and the date is lets say the 15th and your watch says its the 2nd, just advance the hour hand through until you hit 15 and yoiu are good to go...hopefuly this help and didnt confuse much...good luck:)
Dec 02, 2007 | Luminox Navy Seal 8202 Wrist Watch
Set the date
If you dial in the date before noon make sure you stop winding the crown right after the date flips. That will give the internal mechanism the most room to cycle and not flip at noon. If you are setting it after noon wind the crown just until the date you want starts to move to the following date, but stop immediately after so as to not flip over. That way the mechanism will be close to changing the date and should flip it at midnight. Make sense? Hopefully, good luck.
Aug 10, 2007 | Luminox Navy SEAL Dive 3103 Wrist Watch
Luminox 3007 Original Navy Seal Diver Series Watch Logo
507 people viewed this question
Top Luminox Watches Experts
Dennis Fitzsimmons
Level 1 Expert
ibewjm
Are you a Luminox Watch Expert? Answer questions, earn points and help others
