Question about GE GSH25JFR Side by Side Refrigerator
I have black soot inside frig and freezer if i dont use alot of candles could it be a filter or something the frig runs fine
SOURCE: ice maker not making ice. Water disp inside frig disp water.
the line that gives water to the ice maker, every time the water comes down it lives a drip of water that turns to ice blocking the line, get some hot water and a towel and place the hot wet towel on top of the line intel it melts the ice in side the line. it happens to my frige at list once a year. if that is not the problem the valve that supplies water tho the ice maker needs replacing, it's behind the frige at the bottom, where the line coming from the house meets the frige.
Posted on Dec 10, 2008
  • 401 Answers
SOURCE: I get water (alot) on shelves inside the frig. I
Sounds like the water drain for the freezer defrost is clogged. You will need to remove the back panel inside the freezer and check it. Sometimes it's just a piece of paper, or other wrapping that gets into it. Always UNPLUG the refrigerator first.
Posted on Jan 02, 2010
  • 378 Answers
SOURCE: Freezer works fine but frig does not get cold at all
My fridge is running but not cold enough: Start out with the easy stuff first...make sure the lights go out when you close the door(s), make sure the doors are closing properly and the gaskets are closing fully and not torn. Check to make sure the evaporator fan in the freezer is working, this fan blows the cold air around. If the fan is not working, possible bad fan motor - check for power to the fan motor and also check the fan switches around the door openings, ( if your fridge has these switches, not all do ). A common problem cropping up in the last several years has been the air damper not opening up and allowing the cold air from the freezer to be blown into the fresh food section ( mostly on SxS refrigerators ). For many years the air damper was manually operated and now we have motorized controlled or temperature controlled or thermister and electronic boards controlling air dampers, and if this device sticks closed the FF section will normally warm up. An example picture of "one" style and an air damper ( called a diffuser by Whirlpool ). Next would be to check the condenser tubing, a good place to start is to make sure the condenser coils are not built up with dust!! Make sure the condenser fan motor is also working properly. Check for any "clicking on and off" noises from the compressor, is the compressor running.
The most common fridge "not cooling" problem is a frost free failure. Remove the access panel in the freezer section to expose the evaporator coils. If the coils in the freezer section get plugged up with frost, this frost will block the evaporator fan motor from blowing the cold air around. The fan blade can also hit this frost and either become noisy or stop altogether. Locating the defrost timer can be tricky....they are often hidden behind the back bottom corners of the fridge at the bottom, in the last few years the timers have been located in the ceiling of the fresh food section, and some behind the cold control cover. Once you locate the defrost timer, slowly turn the screw like wheel in the middle of the defrost timer with a straight screwdriver until the fridge shuts off. You are now in defrost. If the defrost heater(s) comes on now, replace the defrost timer and defrost thermostat. If the heater(s) does not come on, you can ohm test the defrost heater for continuity or volt test for 120 volts to the heater(s). If you have no power to the defrost heater(s) you can also bypass the defrost thermostat to see if the defrost heater will come on, join the 2 wires together to bypass the defrost thermostat. If the heater now comes on, replace the defrost timer and defrost thermostat. If the heater itself is bad, defrost the fridge with a hair dryer, replace the defrost heater* and defrost thermostat. If the defrost timer seems "hot" to the touch or is noisy ( like a ticking or screeching noise )...replace it.
*One new safety device added to refrigerators in the last few years has been a in-line fuse added to both sides of the defrost heater. If one of these fuses let's go, you must replace the whole defrost heater, as it comes as an assembly. If the defrost heater does not work, you should check for one of these fuses being open. Check it with a volt meter or ohm meter.
New link from Appliance Repair Aid on how the wiring circuit works for a frost free fridge, the link is here.
On a frost free refrigerator, the cooling coils should be in the freezer section. On a SxS style refrigerator the coils will be behind a cover on the back wall.  On a freezer on top style the coils could be behind the back wall or under the freezer floor. Removing the cover and exposing the evaporator coils could be a valuable tool. Seeing what the cooling coils looks like may help split your not cooling problem. Totally covered coils with white snow is a frost free problem. A ball of ice on the coils and the rest of the cooling coils are bare or only a few coils frosted a little and the rest are bare is an indication of a system problem. Example picture oneexample picture twoexample picture three. System problems may be a leak in the refrigeration tubing, an inefficient not 100% pumping compressor.
Posted on Apr 03, 2009
aasc
  • 1606 Answers
SOURCE: My Crosley side-by-side frig/freezer has hot spots
Either the fan which cools the compressor is bad or the coils under the refrig are dirty .
Posted on Jul 17, 2009
heatman101
  • 43501 Answers
SOURCE: the freezer is icing up up and the frig is warm
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Posted on Jun 09, 2010
Our Rinnai gasheater is in 'n working condition but since we used it the white walls and ceilings are covered with black marks - I am worried that it could be dangerous - any advice?
Unfortunately, you failed to mention the Model Number and whether its a flue-less or Vented unit. In either case, the black streaks you see on the walls and ceilings is soot. If it's a flue-less unit, this is an indication that the unit has not received routine maintenance on a regular basis. The sooting is caused by a dirty or clogged burner or low gas pressure.
Also, burning scented candles and operating the heater at the same time, will cause soot. Not from the heater, but from the candles. All candles soot, but scented candles soot more than others. Combine them with the warm moist heat and they will soot 50 times worse. If this is the case, it's the candles sooting, not the heater. Stop burning the candles while the heater is in operation.
Is the soot dangerous? Yes, to the point that you are breathing it in, when it;s floating in the air. The sooting didn't occur over night, it has been doing it for sometime. You finally realized it, when you saw the black streaks. Stop using the heater until it is professionally serviced by and authorized Rinnai Service Technician and the walls and ceiling are cleaned.
You can either remove the soot yourself or have it professionally done. Then, you should prime paint the walls and ceiling with a sealer like Kilz, before repainting. All curtains or draperies should be washed or dry cleaned. All furniture and carpeting should be vacuumed thoroughly.
I hope this helped you and thanks for choosing FixYa.
Aug 10, 2011 | Heating & Cooling
Black film on inside walls of freezer
if you burn a lot of candles in your home its the soot from that...i bet you do!
Apr 16, 2010 | GE GSH25JFR Side by Side Refrigerator
I get water (alot) on shelves inside the frig. I looked at drip pan underneath and it is dry. Checked vents inside frig and they are not blocked.
Jan 01, 2010 | Kenmore 18.9 cu. ft. Top Mount...
It appears to have been on fire,surronding walls & unit covered i
hmmmm... maybe it was on fire... Barring that,
One thing to be aware of is how these things work: they don't actually filter the air. Rather, they electrically charge dust/dirt/etc. particles in the air as they pass through. This new charge makes them attracted to walls, floors, objects, etc. So rather than straining or filtering dust from the air (like a more traditional air filter), they make dust more likely to stick to walls, surfaces, etc. so that you can then wipe them up.
If there is something in the room that is manufacturing air pollutants, it could cause the problem you're having. The most likely culprit is anything that makes smoke. For example: smoking (duh), or burning CANDLES (especially scented candles) or INCENSE.
Jun 22, 2009 | Sharper Image Ionic Breeze® Quadra® 4.0...
Soot all over Older Ionic Breeze Quadra
Hey, if you read the instuction manual : the DON"Ts section-you will see that candles, scent producing products,cause a lot of soot in these cleaners. If you burn scented candles, or use anythind that generates airborne odors, you will need to clean the system more frequently ( every 2-3 days).
I clean mine every week-no matter what.
One of the postings, talked about a : Monthly cleaning that was performed.
You've guessed it. The thing died-arced out.
So, extra odors kill these filters.
Jan 25, 2009 | Sharper Image Ionic Breeze® Quadra® 4.0...
There is a black "soot" coming from my radiant heater
Black soot appearing above and around electric baseboard heaters is caused by burnt hydrocarbons in the air.
The Heating element draws the cool room air from the bottom and over the element. Any excess hydrocarbons in the air become burned and are deposited on the surrounding surfaces from the warm heated air flowing up out of the heater.
The Heater is not the cause of these hydrocarbons. They come from the home / enviornment.
Some cause.
Smoking, burning Candles releases waxy hydrocarbons, carpet cleaning solutions, spray type air fresheners.
Black waxy sooty deposits are usually from burning candles.
Posted by George Patterson
Jan 13, 2009 | Fahrenheat FBE15002 Baseboard Heater
Soot on walls
does your mom burn candles? lots of candles use chemicals for scents and they can deposit soot.
Oct 26, 2008 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
The air purifier is blowing black soot.
I had the same problem and then found that it was from burning aroma candles! I will never burn them again!
Jan 04, 2008 | Honeywell HFD-130 Air Purifier
Ruud centeal electric
Is this an older gas heat unit? If so, you may have a burnt out heat exchanger, this can be dangerous.
Dec 10, 2007 | Heating & Cooling
GE GSH25JFR Side by Side Refrigerator Logo
1,402 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
