Question about Dryers
Runs, heats and tumbles but the clothes do not dry. Lots of lint in the vent outside
  • 5,911 Answers
Your first clue to your problem is the lint accumulation. You may want to check the dryer interior cabinet and/or the entire exhaust duct run to ensure you have no clogs anywhere. The following link explains many of the problems that can cause poor drying efficiency and longer dry times:
http://www.fixya.com/support/r3578821-dryer_takes_too_long_to_dry
Before assuming you have a problem with the appliance, check your installation to ensure you are providing the dryer with proper exhaust and air flow. A dryer in a clogged state or having improper air flow will not dry efficiently and will cause the heating circuits to actually overheat. Eventually, this can lead to component failures and is the source of fire hazards.
If you have any questions, please post back an let me know. I hope you find this information helpful.
Posted on Apr 26, 2010
Clothes not getting dry
sounds like perhaps you are losing your heating element...could be electronic, but it's most likely the actual element needs to be replaced...
Apr 25, 2008 | Whirlpool GGQ8831L Gas Dryer
Tip
Saving money drying clothes
The biggest thing to remember about your clothes dryer is that it has to get the moisture out. If you keep your venting clean it will aid your dryer in shorter drying times. The more heated dry air it can pull through wet clothes while they are tumbling the faster clothes will dry.
If the venting is restricted by lint or kinked, or low quality venting, all end up costing more in drying times. Use good venting, preferably steel, and do use the proper vent cap on the outside wall.(check lint does not catch here also)Many service calls could be prevented by regular maintenance of venting.( thermal safety fuses which all dryers have are the reason for most service repair calls when the venting has not been cleaned) Also the shorter distance your dryer is vented, the better.
The second less obvious problem is not cleaning the lint screen. All the air or almost all passes through this screen before being exhausted outside. You need to clean the lint first. Second you need to wash the lint screen in the sink to clean off any build up of fabric softener that can also cause slow drying. Water should run straight through the metal mesh, if it ponds it is coated with softener, and water should wash this off.(I have been on service calls where dryers were not drying correctly and just washing off the lint screen of fabric softener fixed the problem)
Lastly wiping the two short parallel bars about three inches long found inside the dryer with alcohol to remove any fabric softener or other coating will keep the automatic cycle working right.Not all dryers use these........
Before thermistors, when thermostats were all that was out there.........
Hope this saves you some money and time.......
on Feb 23, 2010 | Dryers
Taking long time to dry the clothes
Due to a dryer either heats or no heat , I would suggest pulling the dryer out and removing the vent hose . Dry a load of clothes to see if they dry normally . If they do , this verifys that the vent hose is either kinked ( restricting air flow ) , or , if the vent runs UP inside the wall , there is a restriction between the inside vent hose to the outside vent . May have to go into the attic to clean .
Jan 28, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Dryer heats clothes but does not dry them
Check the following:
Since you said the dryer heats....
Make sure you have the dryer set to the correct cycle, and not delicate or air only.
Make sure the drying cycle time runs for the set period. If not, the timer may be faulty.
Make sure the dryer is tumbling (the drum is turning). If not, you may have a drive issue like a bad or broken belt, or some other mechanical drive issue.
Make sure the lint screen is clean and the dryer exhaust all the way to the outside of the dwelling is clear and not obstructed with lint or anything else. If you don't feel a pretty good beeze coming out of the wall discharge vent, start looking for a plugged vent.
There could also be an exhaust fan issue with the dryer if the vent line is clear. If this is plugged or not working, the back of the dryer will need to be removed and the cause(s) determined.
Make sure the dryer isn't overloaded and that the clothes aren't too wet when they are placed in the dryer, possibly pointing to a spin dry issue with your washing machine.
Jan 12, 2010 | Dryers
Wed9200sq0 heats, tumbles but does not dry at any heat setting
You are correct. Pull the dryer out and disconnect your venting from the back of the dryer. Turn your dryer on and check to make sure your dryer is blowing air out of the dryer duct. If it is then leave your dryer out at least 2 ft from the wall and run a load of clothes through the dryer. If it dries your clothes normally then you have a venting restriction. Check to make sure your venting is clean, not kinked or smashed, make sure your outside vent is opening an doesn.t have something blocking it. Check your lint screen filter by running water through it. If water is not flowing through it, you have a build up of fabric softener on your screen, blocking air flow. Scrub your screen off and test again. Good Luck, Appliance Specialists
Dec 30, 2009 | Whirlpool WED9200SQ Electric Dryer
My dyer heats and tumbles, but doesn't dry
I'd check first for clogged vent hose or clogged lint filter or clogged vent flap on wall (outside).
If that's not a problem, it may be a faulty thermostat. Heating element is probably okay if it heats some of the time.
More info, let me know.
Charlie
Oct 01, 2009 | Kenmore Dryers
Not drying clothes
If the unit is heating properly which it should pull around 25 amps when heating , and the unit is tumbling it is 100% an exhaust issue , either a kinked duct behind the unit , a ball of lint stuck in the duct , lint build up outside in vent , or water in under ground duct. If you find the clog it will be FIXED!
Let me know if you have any other questions.
Phil
Apr 14, 2009 | Whirlpool WED6200S Electric Dryer
Maytag dryer model # SDE3606AWY HEATS UP TUMBLE clothes but does
There is most likely a lint obstruction somewhere in the exhaust. Start by checking the outside vent as often there is an animal screen on it that over time gets caked with stray lint. If that's clear then work backward and check the hose, etc until you either find something or get to the dryer itself. It's possible that in the internal exhaust tubes there's an obstruction as well so if you don't find anything in the external tube you will need to disassemble and have a look inside those internal exuast tubes/ports. If it's inside then do it soon as there's clearly a risk of fire if there's a wad of lint somewhere inside where it shouldn't be.
The mother of a friend at work had this issue - her clothes took HOURS to dry. Her animal screen had several inches thick layer of lint. Once that was removed the dryer dried like new.
Mar 29, 2009 | Maytag SDE3606A Electric Dryer
DRYER WILL NOT GET CLOTHS DRY
A dryer needs only three things to dry clothes:
1. Tumble the clothes.
2. Blow the air.
3. Heat the air.
If your clothes aren't drying, you are missing one or more of these.
You've mentioned that the basket is tumbling. That's good. The blower is also running if the motor is turning. But that doesn't mean the air is blowing. It could be clogged up behind the lint screen, in the vent pipe behind the machine, or at the vent outside the house.
If it's blowing lots of cold air (go to the outside vent to find out) then your dryer isn't heating. This would mean some part inside the dryer has failed. If so, the first thing you want to determine is, does the ignitor glow? There's a hole at the very bottom front edge where you might see it glow. You may have to place a mirror in front of the hole to see it glow.
Write back with more symptoms, and I'll help you through the rest.
Mar 23, 2008 | Dryers
Dryers Logo
54 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
