Question about Zebra Stripe S600 Thermal Label Printer
My zebra only prints the left half? I have tried calibrating, it does nothing. Can you help me out? Thanks
  • 1 more comment
  • kdenham533 Apr 26, 2010
    ok so it is situation #1. it says that the width is "050 6/8 MM." How do I change the width setting?
    ok it is situation #1 but I am not sure how to adjust the width. I have no manual to this printer. The current width is "050 6/8 MM"
    ok it is situation #1 and it is saying that the width is "050 6/8 MM" How do I adjust the width setting?
    Scholar:
  • 97 Answers
One of two situations exists:
1. If the printing stops with clear stopping edge, then the PRINT WIDTH setting has been changed from the default full width setting of 104mm.
Best way to check this is to take your tallest and widest label and print out a configuration label. This is done by turning off the priner, pressing the CANCEL key and holding while turning on the printer. Release the button when the calibrate led turns off. A config label will print and you can check the setting for PRINT WIDTH.
2. If the printing stops by fading away to the right side, then that is caused by a pressure imbalance across the printhead. There is more pressure on the left side than the right side. There are two toggles the press down on the printhead and the pressure can be adjusted on each by turning the knob on top. Readjust the right side until printing returns across the label.
Hope that helps !
Posted on Apr 26, 2010
Testimonial: "Helped me out a bunch. He was right on the money. Thanks"
  • Bob Miller Apr 26, 2010
    check for a setting in your printer driver. Are you using a labeling software package ?
    You could also set the printer to Factory Defaults. That will return the width to 104mm but some other parameters will reset as well. To do defaults, turn printer off, then press and hold FEED and PAUSE while turning on the printer. After a few seconds, you can let go and the printer will be reset. Save the settings by pressing MODE 4 times until the three LED's flash. Then turn printer on and off again and you will be back to the full width.
2 Suggested Answers
  • 52 Answers
SOURCE: Zebra 170PAX3 not printing the top half of label
If you print a power on test label, see if the print is aligned, id so, use the top of form setttings to get all the print on the label.
As far as a USB, the printer will only take RS232-422,485, and parallel, and you can add the factory Nic card or use an external print server.
Posted on Feb 25, 2009
My zebra tlp 2824 won't line up to the labels
Either your printer needs calibrated: Calibrate Zebra Desktop Printer
Or your label template size( in the software) does not match the label size. I recommend the calibration then looking at the software label templates.
Jan 20, 2014 | Zebra Eltron LP 2824 Thermal Printer
My Zebra 105SE is printing fine on the left
I think the 105 has an adjustment on the printhead. There are left and right hand adjusters just above the printhead. It sounds as if the right hand one does not have enough pressure on it, try increasing the RH one and see the effect on the print.
Jan 06, 2010 | Zebra 105Se Thermal Printer
Losing half of top line when printing
Label definition in printer driver may need adjustment. Try calibrating printer, printer on solid green light, hold down feed key & release after light blinks 4 times, (blinks once, twice, three times then 4 times) Download the Zebra setup utility and use it to configure printer.
Sep 29, 2009 | Zebra TLP 2844-Z Thermal Label Printer
Problem with my Zebra LP2824 printer
You have to calibrate the printer to solve this problem
Check following to solve this problem
1)Press the feed button and hold it for 1-2 seconds switching printer on.It will calibrate the labels.
2)Install Zebra Designer driver from CD.After installing Zebra designer Add printer Zebra Designer LP2824.After installing driver right Click the printer Zebra Designer LP2824 and go to printing preferences then select advanced option and calibrate printer.It will calibrate printer
3)Check the label size is properly set in printer or not.Label width and label height in printer settings should be same as label which you are using .
Aug 22, 2009 | Zebra Eltron LP 2824 Thermal Printer
Printing half the vertical, no matter what size label in use.
Some drivers adjust the length of the print area, regardless of the length of the label. Do calibrate the label and also verifies that the margins are zero.
Roberto Martinez
Jul 21, 2009 | Zebra Z4M Printer
Unable to print a 4X 6 label
asslam aleekum wr wb
mere pass zebra printer hina but us mian ak problem ya arha hian k us k print out blank arhha hian why?
plz mujhe batey
Apr 22, 2009 | Zebra Z4Mplus Label Printer
Dec 08, 2008 | Zebra 170XiIIIPlus Thermal Label Printer
Zebra 2488-z
Have you tried cleaning the sensor? It is underneath the labels oppoistethe print head.
Oct 18, 2008 | Zebra LP 2844 Thermal Printer
Zebra TLP 2844 Error Condition
Qusetion, Using USB my TLP2844 detects as a LP2844ps. Weird, huh? Also when I calibrate it the label does not stop at the perferation. When I print half goes on one label and the other half goes on the next label. Someone told me once there was a trick to get it to calibrate correctly. Anyone here know this? When I print a test page, it feed the correct amount of label.
Dec 04, 2007 | Zebra LP 2844 Thermal Printer
Zebra Stripe S600 Thermal Label Printer Logo
4,008 people viewed this question
Top Zebra Office Equipment & Supplies Experts
pkwc
CheckitRight
CheckitRight
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
