Question about iRobot Roomba 560 Robotic Vacuum
I have 2 I robot roomba cleaners they charge but will not turn on. The robot company does not repair them don't know what to do
    Problem Solver:
  • 28 Answers
Hi. It depends on where you are in the world. Companies in the US repair them and so do I in the UK.
But if you are using a new battery and same issue, then the power button is at fault.
Posted on Oct 06, 2010
Why won't my Roomba start when I press a green "clean" button?
Bad PC board. Throw it away. Robot vacs are nothing more than novelties ( expensive toys ) They may do what you want them to do at first but they never last very long and other than brush replacements they are not repairable. If it is within the warranty period you can get a replacement with that.
Jul 01, 2017 | Roomba iRobot 630 Vacuum Cleaning Robot
How do I change schedule on Roomba
go to roomba.com when at there site go to customer care support then to pooduct resources then select a robot roomba,scooba,ect find your sereies 700,600 ect go to documents&manuals then to scheduling roomba then to viewing and deleting schedules follow the steps
Dec 18, 2012 | Roomba iRobot 560/561 Vacuum Cleaner...
What are these 2 blinking lights on my irobot roomba?
"The Charge Indicator Light is located immediately to the right of the power button on Roomba Red and Roomba (sage). On Roomba Discovery and Discovery SE, the Charge Indicator Light is incorporated into the power button. Please refer to the table below to determine what the Charge Indicator Light is telling you.
* Pulsing Amber - Charging
* Green - Fully Charged
* Amber - Partially Discharged
* Red - Almost Fully Discharged
* Flashing Red - Fully Discharged"
At the end of a cleaning mission, Roomba will tell you if it has successfully completed it's mission or not:
GREEN = MISSION COMPLETE
YELLOW = MISSION ABANDONED (Check robot's brushes, etc.)
YELLOW RED POWER BUTTON = BATTERY DEPLETED (Scheduler Models)
RED YELLOW POWER BUTTON = BATTERY DEPLETED (Discovery Models)
number of beeps after ?uh-oh? :
No beeps: A wheel is stuck or is not touching the ground. Pick up the robot, place it down securely on the floor and touch the clean button to restart the cycle.
1 beep: The main brushes cannot turn. Turn over Roomba and remove the brush guard by pushing the two yellow tabs. Remove the brushes, clear any obstructions, and replace them again.
2 beeps: The side brush cannot turn. Turn over Roomba. Look to see if something is wrapped around the side brush. Remove the side brush with a screw driver and check for string or hair that may be wrapped around it.
3 beeps: The vacuum cannot run Remove and empty Roomba?s bin.
4 beeps: A wheel motor cannot run Your Roomba may be stuck or something may be wrapped around a wheel. Look for something wrapped around the wheels. Push them in and out and make sure they turn easily.
5 beeps: The cliff sensors have failed or are blocked. Turn over Roomba and clear any debris that might be caught underneath the front bumper in the cliff sensors. You can also use compressed air to clean them out.
6 beeps: Wheel obstruction or robot attempting to drive over an obstacle. Turn over Roomba and remove any obstructions that prevent the wheels from seating all the way up into Roomba?s body. Also, remove any obstacles that Roomba could drive over.
7 or 8 beeps: Not applicable Roomba?s beep codes do not include 7 or 8 beeps. If you are getting an error with 7 or 8 beeps, try counting again or contact iRobot Customer Care.
9 beeps: Sensor error Please contact iRobot Customer Care.
10 beeps: Roomba is stuck Pick up Roomba and start it again somewhere else. Use a virtual wall or other barrier to keep Roomba away from the
place it got stuck.
Your Roomba may be experiencing an issue where the battery is deeply discharged and may need to charge longer than the standard 3 hours. (or 7 hours if you have a standard charger)
Even with the charging light showing green (this indicates a fully charged battery) the robot is still charging. If your Roomba exhibits behavior where it charges for a short time then runs for a short time you will need to do the following.
1. Plug the charger into Roomba (if you have a home base be sure to plug directly into Roomba instead of using the home base, this will ensure the robot's charging cycle is not interrupted.)
2. After the Roomba's charging indicator goes to solid green please keep the Roomba on the charger for an additional 72 hours. (3 days)
3. After the 72 hours (3 days) has passed, turn your Roomba on and begin a normal cleaning cycle. If this works successfully it may take several uses for the battery to get back up to the performance it once had.
If this does not correct the problem, please call customer support at 877-855-8593
Nov 22, 2012 | Vacuums
My dirt devil Rampage Robotic pool cleaner vacuum get stuck on the bottom drains
There is a ring that is designed to fit over bottom drains to prevent robotic pool cleaners from getting stuck. There are several different brands/kinds available and any of them should prevent the problem. Here is one example:
http://www.backyardcitypools.com/Automatic-Pool-Cleaners/NE290-Smart-Ring-Drain-Cover.htm
May 07, 2010 | Dirt Devil Rampage Robotic Pool Cleaner...
I have iRobot Roomba 4210 and I have a problem with charge battery. The battery is new. When I charging a battery in other iRobot Roomba the battery was full charged. When I charging in my iRobot Roomba...
The charging circuit on the main board is fried. This is a common issue. You need some good electronic repair skills, and equipment, to replace the problem components
Nov 23, 2009 | iRobot Roomba 4210 Bagless Robotic Vacuum
Roomba goes a few minutes after a charge then stops
you can try cleaning the battery and charging contacts with some rubbing alcohol or contact cleaner, but its also possible the battery has reached the end of its service life.
Sep 13, 2009 | iRobot Roomba 560 Robotic Vacuum
Roomba charged (new battery just installed) and won't run
Charging circuit on the roomba will sometime stop the unit from running. Just repaired one the other day doing just that. (Replace the main board, if you don't haave electronic repair skills, or the equipment to do it)
Jul 30, 2009 | iRobot Roomba 4210 Bagless Robotic Vacuum
Battery temperature sensor.
you should not make your own battery and use it with roomba, or try charging it with a charger not meant for roomba, i suggest you buy the APS battery on ebay for $30 - $40. and buy a new charger from the company for $30. You can do some serious damage to the motherboard on the robot and your roomba might not work at all after that.
Mar 10, 2009 | Roomba Robotic Floor Bagless Vacuum
ROOMBA 415
It could be the power button itself. If you have a Roomba remote, try using that to power on the robot.
Sep 28, 2008 | iRobot 4150 Roomba Vacuum
Open Questions:
See all iRobot Roomba 560 Robotic Vacuum Questions
iRobot Roomba 560 Robotic Vacuum Logo
176 people viewed this question
Top iRobot Vacuums Experts
Shehu Pro
Shehu Pro
Are you an iRobot Vacuum Expert? Answer questions, earn points and help others
