Question about Sony Ericsson W600i Cellular Phone
Keys not illuminating
We had fixed the flex cable. Keys not illuminating...would a new screen fix this problem? Thanks for the quick response.
    Brigadier General:
  • 7,752 Answers
You will need to change the keyboard
Posted on Apr 20, 2008
SOURCE:
My phone display blink
Hi, samsung phones with blinking display is usually caused by the flex of the cell phone,.
It can be fixed.There is a common fault for all Samsung cell phones. there is a thread like object inside the phone called a flex that controls the functions on the keys on a cell phone when it's gets damaged, it makes the keys to malfunction. You will need to replace the thread like object which is the flex inside the phone for the keys to function again.
The flex of the phone is located inside the phone, it controls the functions of the screen an also the keypads of the phone.
The flex is a thread like object that is located inside the phone. To see the flex, you will need to disassemble the phone to get to the flex of the phone.
After replacing the phone flex, your done.
Also it might be the screen of the phone. But in other to know if it's the screen, you will need to test a new flex.
You can get a replacement flex from any of the phone repair stores around you.
Hope it helps.
Thanks for using fixya...
May 25, 2011 | Samsung Star GT-S5233 Cell Phone
My droid 2 screen goes black when some calls i cant answer it at all i have to take battery of the back to stop it from ringing
Hi, It can be fixed.There is a common fault for all Motorola cell phones. there is a thread like object inside the phone called a flex that controls the functions on the keys on a cell phone when it's gets damaged, it makes the keys to malfunction. You will need to replace the thread like object which is the flex inside the phone for the keys to function again.
Hope it helps.
May 24, 2011 | Motorola Mobility Droid (2 GB) Cell Phone
MOTOROLA DROID SCREEN IS BLACK BUT IT IS ON
Hi, no need to get a new phone, It can be fixed.
There is a common fault for all MOTOROLA DROID cell phones. there is a thread like object inside the phone called a flex that controls the functions on the keys on a cell phone when it's gets damaged, it makes the keys to malfunction .That's what makes the screen to go black.
Hope it helps.
Mar 12, 2011 | Motorola Mobility Droid (2 GB) Cell Phone
I have a Samsung Propel a767. It is a slide stle phone and all of the key buttons are on the part that slides up. They are completely unresponsive except the power and talk buttons. Why and can this be...
Hi, no need to get a new phone, It can be fixed.There is a common fault for all Samsung cell phones. there is a thread like object inside the phone called a flex that controls the functions on the keys on a cell phone when it's gets damaged, it makes the keys to malfunction. You will need to replace the thread like object which is the flex inside the phone for the keys to function again.
Hope it helps.
Jan 25, 2011 | Samsung Propel A767 Cell Phone
The monitor is black. You can't see what you want to record.
Possibly just faulty flex cable,not the entire monitor.
I had similar trouble on my 2nd hand HC32 no picture,no light,no response on touch-screen function - turned out to be faulty flex cable that runs between LCD and the main body.
Cost me around 60 USD to fix by non-SONY service shop.Now it works like new.Worth every dime for this outdated camcorder.
Aug 07, 2010 | JVC Everio GZ-MG20 Camcorder
My mobile samsung j700 keys are not workin please help
hello,
the reason the keys are not working is because there is a problem with the flex of the phone.
the flex is the mechanism that connects the keypad to the screen, so if there is a problem with the flex, anything you type would not show up on the screen.
therefore, in order to fix this problem, you have to fix the flex. then the phone can be in order once again.
May 27, 2010 | Samsung J700 Cellular Phone
My Acer 9423 has no picture or sound
Try remove ram memories, they should be under screwed cover at the bottom side. After a while put it back, do it very strictly. Make this all on removed battery, and power cable off. You may remove your hard drive too, then get it back. If this doesn't work, you can disassemble and check if the screen cables are well connected. They loose out sometimes.
Apr 10, 2009 | Acer Aspire 9420-6426 Notebook
Motorola v3xx got wet
you may have short circuited the flex cable connecting your screen to your mainboard, in this case you will have to buy a new flex cable
Apr 03, 2008 | Motorola Mobility RAZR V3x Cellular Phone
No sound through earpiece/white screen
you can send too sony ericsson it in if you are the origanal buyer and they will fix it for free but it also has to be under a year old
or if you are on a plan you can get a new phone every two years its not free tho it is very cheap you have to be with at&t to do that tho (cingular)
Jan 28, 2008 | Sony Ericsson W300 Cellular Phone
V3x screen fix
guys! my fone got blocked . when i turn it on it says SIM Blocked...what do i do? then it says PIN1 UNBLOCK code:?
Nov 08, 2007 | Motorola Mobility RAZR V3x Cellular Phone
Sony Ericsson W600i Cellular Phone Logo
Top Sony Ericsson Cell Phones Experts
Damen Wong
Damen Wong
Ekse
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
