Question about Intel PENTIUM-4 865GV CHIP MOTHER BOARD (MBP4I65GV) Motherboard
Borad, hard disk & processors heat problems - Intel PENTIUM-4 865GV CHIP MOTHER BOARD (MBP4I65GV) Motherboard
  • 64 Answers
DO NOT CHANGE THE transistor power, you will blow the power pack. Check dust collection and correct CPU/fans speed in your bios
Posted on Apr 27, 2010
  • 75 Answers
Change the transistor power ( near the socket power )
Posted on Apr 26, 2010
What do u look for on the mother borad when fixing rrod for xbox 360?
I recommend that if you have a warranty send the console to Microsoft for repairs.
But if you don't have a warranty and are determined to do it yourself, then you may proceed.
You have to look for these
two X-shaped pieces of metal are what try to hold the heat sinks onto the CPU and GPU. Problem is, they aren't springy enough to do the job. The heat sinks have a tiny amount of wiggle room, and the motherboard is free to warp from heat. That prohibits proper heat dissipation, and allows the processors to break away from their connections.
Dec 10, 2010 | Microsoft Xbox 360 Console
During power up the power indicator is lighted up but no video and no hard disk activity and stays that way
first remove your smps connector to the motherboard short the pin green and black and see wether the smps fan is working if working connect the connector remove the power supply of the hard disk otherwise it may damage the hard disk now remove the cpu fan and the processor from the socket clean the CPU fan and the processor and fix the processor to the socket apply a thin layer of heat sink solvent and fix the CPU fan firmly on the socket now remove your memory and wipe it clean with a dry cloth and fix it to the memory slot and switch on the computer
Nov 30, 2010 | Toshiba Satellite L305D-S5881 Notebook
Hi i my computer suddenly started to shutdown and turn on again after a fev seconds.some times it goes in to windows but soon after crashes.it has wrked for over a year and this was a home built...
Try these....
Overheating problem in your PROCESSOR!
Check the temp in your BiOS and the setting of your processor!
Check also the power supply and upgrade it to hifgher wattage!
Clean your processor HEAT SiNK, dust and dirt might have acumulated!
Check the HEAT sink position, if its flatly fitted on top of procie, and scrape the old silicon paste between ur proci and heat sink and put a NEW ONE!
Encountered this kind of prob.. the prob is in the PSU unit(Power Supply Unit)!
These might help you!
Nov 07, 2010 | ASUS P5QL PRO Motherboard
FireLite 40 GB Hard Drive: The usb port where you insert the cable on the har...
1. the only way to know what breally has gone wrong is to open the enclosure & check. if the Ports has broken off fromm the PCB borad inside then ( if you are technically savvy) you can resolder it back. ( the disk has to be removed first) if not you have two option.
1. take a device to a repair shop.
2. buy a new enclosure & swap the disk
May 05, 2010 | SmartDisk FireLite 40 GB Hard Drive
Blank Computer Shuts Down For No Reason
the old hard disk died a month ago and you got a new new one now rt? that means you were not using your computer for one month.So there is a chance of processor heat sink paste worned out and processor is getting hot. So you need to remove the heat sink and apply new heat sink paste and re-fix processor, re-fix ram sticks also.. make sure processor fan is working well.
if its still having problem, you need to check the SMPS...
Another reason, you need check to the compatibility of mother board with hard disk. That means, you need to check how much size of hard disk your motherboard will support?
Apr 02, 2010 | Western Digital MY BOOK HOME 1TB EXT...
Hp pavillion ze2000 laptop cuts off after about 3 mins when started from cold.When i try to start again it shuts down immediately.I've gone into the bios to check hard disk and the machine freezes.Ive...
I will ask that you do this, format your PC and this are the step if you don't know... Go to the control panel you will see backup and recovery, buy an empty disk backup all files, then format your PC and recover after. All will now be fine. check
Dec 31, 2009 | HP Pavilion ze2000 Notebook
What to do?
Is it possible you have to enable some type of external display setting?
Aug 29, 2009 | Acer Aspire 5720-6661 Notebook PC
Intel PENTIUM-4 865GV CHIP MOTHER BOARD (MBP4I65GV) Motherboard Logo
62 people viewed this question
Top Intel Computers & Internet Experts
Tony
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
