Question about RCA Thomson Digital Cable Modem (DCM305R)
All lights are flashing in unison. comcast says I need a new modem. Is this true?
For mine, I just pulled out the battery for a few moments and the lights went normal, then put the battery back in. It's still normal. Figured that the battery light was the only one not flashing in unison with the others.
Good luck. :)
Posted on Dec 05, 2012
  • 3,083 Answers
From my limited experience with this problem, the answer can be yes. If you cannot unplug the modem power plug and reattach it, and then make it "set up" and work, the problem is either a bad line feed or bad modem. The easiest thing to do is try another modem...that will verify if the line is good. If the line is bad, comcast has to fix it for free, to provide your service. It your modem is good, you won't have to replace it and buy another one(however, they may charge a service fee, I'm not sure if or how much- call them and check first). Hope this helps.
Posted on Apr 26, 2010
Comcast is my service provider and I have had an RCA DCM 245R modem for almost 10 years. Until recently it has worked fine. On an ever increasing basis I am losing internet connection and when I look at...
It can be an issue with the modem or with the line. When the line drops the link then the modem shows only two lights. And, when you power cycle the modem (unplug and replug it) it establish the session again with the comcast.
So, i'll suggest you to get the line checked first and if comcast finds that line is working fine then get the modem replaced.
Rashish
Aug 15, 2010 | Thomson RCA DCM245R Modem
Online light flashing at times, no internet. Occasional message: failed on loadingskin name comcast; the file shell.css is required in your sscommon/skin/comcast/css directory.
failed on loading skin name "comcast". the file "shell.css is required in your "sscommon/skins/comcast/css/" directory" this is what i am getting from my acer desk top.... comcast is my internet service provider and say "everything is fine on their end" but i cant access the net... please help me
Jun 29, 2010 | Arris SURFboard® SB5101 Cable Modem
When connect the power I get all solid lights except for the Internet light. Reset does nothing. I got the Modem on Ebay from a past Comcast user. Any ideas? Is it a goner? Thanks... Darryl From Portland...
You have to notify comcast, to let them know you bought a new modem. Comcast uses a two way communications to all of there devices, and it is not setup on your new modem.
Dec 06, 2009 | RCA DCM425 DIGITAL CABLE MODEM (RCADCM425)
The link light on my Comcast modem keeps flashing. I am having a hard time connecting my computer to the internet.I cannot access service from the hibernate mode. Most of the time the internet explorer...
Comcast is full of crappy there internet connection is horrible they are lying to everybody take it back like I'm doing I have never had such horrible connection my cell phone from ATT internet has never not once connected but for some reason my Comcast never connects
Jul 05, 2009 | Computers & Internet
True Mobil 2300 can't find IP address
OK...
since you have a comcast modem the router should automatically pick up connection,since you have already reset the modem,what you need to do is to check whether you are going online suing the modem,once you can go online using the modem,reset the rotuer as well,connect all the devices properly(the cables should be in the appropriate ports)turn off all the devices for 60 sec and then turn the modem,wait for the light to be steday,turn on the router and then the computer and check if you are being able to go online i am sure you will be,incase you are stuck let me know ffurther...
vedhick
Feb 10, 2009 | Dell TrueMobile 2300 Wireless Router...
Comcast modem
the light is flashing because your modem is working.
Dec 05, 2008 | Arris SURFboard SB5120 Modem
Arris cable modem
try shutting of your computer then shutting off the modem, the modems have batteries you might have to remove them theres usally a panel on the bottom, in the back you should have a wire for comcast cable and an ethernet chord telephone too if you have everything. also your modem could be broken, i had the same problem
Jun 06, 2008 | Arris Touchstone 450a (CM450) Modem
My internet won't work on my new laptop.
First turn off you laptop. Second, go to your comcast cable modem unplug it from the wall and wait about 3mins. Now plug the comcast modem back it and wait for all the lights to come back (will take about 2-3mins). Now plug the yellow ethernet cable into your laptop if its not already and turn your laptop on. You should now have internet.
Also if you using a Comcast Surf Board modem be mindful of the standby button on top of the modem. You can tell your in standby mode if the standby light (bottom light) is amber. If it is press the standby button once to get out of standby mode.
hope that helps
May 12, 2008 | Computers & Internet
Actiontec (GS503AD3-01) Modem
--If the Power light is flashing red thanits definately problem with the Actiontec Router --As you have checked with different power source, the possibility of bad power source is no more --May be due to some voltage fluctuation the modem is gone bad.
Jul 10, 2007 | Actiontec (GS503AD3-01) Modem
RCA Thomson Digital Cable Modem (DCM305R) Logo
333 people viewed this question
Top RCA Computers & Internet Experts
Julie Endres
Jose Velazquez
Jose Velazquez
Are you a RCA Computer and Internet Expert? Answer questions, earn points and help others
