Question about Whirlpool 24 in. DU1100XTP Built-in Dishwasher
Whirlpool Model DU8770XY purchased new in 1992 has just started to overflow through the air gap kit 300096. This unit has been working fine for the past 18 years. I checked the unit and drain tail section under the sink along with the P-trap and the water flows through them just fine. The kit is clean with no visible obstruction.
4 Suggested Answers
  • 149 Answers
SOURCE: Whirlpool Gold dishwasher water overflowing and will not shut off
There should be a dome shaped float switch on the inside bottom of the washer. Make sure it is free to move up and down, or is able to float (possibly cracked or broken).
Posted on Jun 28, 2009
SOURCE: Dishwasher expelling water through air gap into
MY DISHWASHER AIR GAP IS SHOOTING WATER INTO THE KITCHEN SINK WHY ?
Posted on May 11, 2010
marka19
  • 1430 Answers
SOURCE: need a new sink- now THE SINK has 4 holes to
Yes you just need to run the hose to the top of the counter hieght to create a high loop. Basically does the same thing as an air gap. Here is a video showing this
http://mediasuite.multicastmedia.com/player.php?v=z3q491n5
Posted on Jun 09, 2010
Why does the control panel on my Whirlpool electric range get too hot to touch when oven is operating at 350 degrees?
heat transference and radiated heat at that temp is normal
the stove should have an air gap between unit and wall
not pushed up against the wall
and internally insulated
check to see if your whirlpool model oven ever had a safety recall 26301150-vpuqtjtdvoowntuyvcl35auo-4-0.jpg
Oct 04, 2016 | Whirlpool Kitchen Ranges
Haier Split Air Conditioner Outdoor unit not working
Check or replace the run capacitor for the compressor.
If that is good, or replacing it does not help, try what we in the industry call a "Hard Start Kit".
No matter if that works or fails, (The hard start kit), call the warranty center or where you purchased the unit.
Jul 13, 2014 | Heating & Cooling
Why does air gap overflow in the first two minutes of the "normal" cycle?
Air gap usually has a valve(sometimes rubber flap) that either is not working or is leaking. Needs to be rebuilt or replaced.
May 28, 2014 | Whirlpool 24 in. DU1100XTP Built-in...
I have a dometic penguin ac rooftop unit. Model no. 630215.421. Fan blows Compressor does not kick on. Fan blows just no cold air. If put on auto and go up or down in temperature On the thermostat The fan...
Bad run capacitor or bad compressor. If you hear an occasional click from the compressor try a new run cap and then a hard start kit. Otherwise it's more economical to purchase a new unit.
Sep 25, 2013 | Dometic Rooftop RV Air Conditioner
I have a whirlpool gold model GU1500 diswasher. When the rinse cycle ends the water pumps out into the garbage disposal like it should, but then water backs-up from somewhere into the bottom of the...
Seems you answered your own question here. You need to make an air gap in the drain hose - take as much slack as possible and make a curve (upside down U) under you sink as high as you can go. Make sure you clip ot to back of the cabinet to stabilize it. Good luck
Jan 11, 2010 | Whirlpool 24 in. GU1500XTLS Stainless...
New Whirlpool Dishwasher filler overflows.
New Whirlpool Dishwashers will NOT accept the same "volume" of water that was desired by the same products of 25 years ago. Therefore the old 3/8" ID copper supply is too large and will overflow the tub filler/aireator (out the air vent holes). I just installed a new dishwasher supply kit consisting of a new 3/8" OD stainless braded hose with an ID of about 1/4". This delivers less volume than that recommended (in the installation manual) and therfore does restrict the flow a bit. However, the flowrate is adequate and the new dishwasher now works perfectly with no water overflow on the floor . . .
Dec 26, 2009 | Dishwashers
Mover agitator slips
The agitator bolt may be loose, or the dogs may need replaced. The following link explains how to access and repair:
http://www.fixya.com/support/r823955-replacing_agitator_dogs
You can view what agitator dogs look like at appliancepartspros.com. Just type in your model number and look for item 18 under the Agitator, Basket and Tub heading. A replacement kit only costs about $5. For a bit more, you can purchase the entire agitator repair kit for about $11 (item 22). The exploded view diagram can also assist you.
Your agitator has a cap that comes off the center post, followed by an air gap cap inside. The air gap cap just pulls out, exposing the agitator bolt. The upper portion of the agitator (called the "auger") will lift off once the bolt is removed.
NOTE: Make sure when you reassemble the agitator that you remember to reinsert the air gap cap and that the rubber o-ring gasket is intact. Without it, water will eventually work into the gearcase (transmission). Also make sure you do not overtighten the agitator bolt. Doing so may damage the agitator or restrict its movement. Tighten until snug.
If you have any questions, please let me know. I hope this helps you.
Jul 21, 2009 | Whirlpool WFW8300SW
Pan that catches water under freezer side overflows
That is pretty unusual unless you live in a humid area. Some units have a switch that allows you to adjust for this and it simply defrosts every 12 instead of 24 hours. Also, the fan that cools the coils under the unit may not be running at normal speed since the warmth of the coils and the fan generally suffice to return the accumulated water into the air. You are right to check the door seals since if these are no longer seating well, external humidity will be gathered by the cooling coils and subsequently become the water collected below that is plaguing you.
Apr 30, 2009 | Whirlpool Refrigerators
Microwave inoperative on rv generator power
Replaced with different microwave. Amanna microwave works fine on both circuits. Would not recommend Whirlpool for RV use.
Thanks
Dec 27, 2008 | Whirlpool 1.6 Cu. Ft. Over-the-Range...
Whirlpool 24 in. DU1100XTP Built-in Dishwasher Logo
41 people viewed this question
Top Whirlpool Dishwashers Experts
Mike
Owen Barnes
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
