Question about Brother HL 5140 Laser Printer
Printer makes clicking noise when printing
When a file is sent to the printer to print the printer begins making a consistent clicking noise while the printer is actually printing the document. It sounds as though it is coming from the rollers that take the paper. Can you help with this problem or can you suggest a location in Washington, D.C. that can repair the problem?
Thank you for your help.
Lance Marburger
  • l_marburger Apr 26, 2010
    Interesting comment. I just put a new cartridge in the printer
  • 14 Answers
It sound like the Brother HL-5140 Fuser gear is about to give out. This is very common.
Posted on Apr 30, 2010
One reason why the cartridge is making a clicking noise is that there is a washer and spring missing from the inside of the cartridge
if this is the case you will need to buy a new cartridge as it can not be solved until the washer and spring are put in
Posted on Apr 26, 2010
Printer is in ready to print mode but not print when document is sent.
Hi Felix,
Again in broad terms.
When you see processing data that could be a sign that the internal processor is trying to make sense of the information you sent to it.
I've seen Xerox printers saying processing data and nothing appears before.
It could be anything from a bad file sent to the printer, that it can't deal with or print because you don't have a PDF license perhaps.
The other helpful thing would be to see if your error sheets have been turned off. I know it is usually a wast of paper but it might be a clue as to why no print appears apter processing your file/print.
Consider this, the printer I have is sat quiet with a window saying ready to print and yet the fuser is quite cold. The only thing that can wake it up is a genuine print. Now if it's cold all the time then you should have a 'Fuser Error'
Again, sorry to be so vague but without being on site it's difficult to get to the bottom of your query.
The local Xerox engineer or concessionaire should be really helpful.
Good luck.
Jul 03, 2015 | Xerox Phaser 7750DN Laser Printer
How to change Epson Lx300+ II Font
The Epson printer is controlled directly by the computer it is connected to. The printer actually has no say in how and what it prints, so if you want to change any aspect of your print document (such as the text) you need to adjust the text in the document you are printing from. This only requires a few clicks of your mouse and once the text style is changed you may begin printing with the next font.
1. Open the program you are printing from and want to change the text font of.
2. Select "File," "Open" (or click the "Open" button on the front of the program), then choose the document you want to print.
3. Click-and-drag over the text you want to change. Once highlighted, click the font type option on the top of the page and choose the new font you want. Once selected, all the highlighted area changes.
4. Click "File," "Print" and choose the Epson Stylus CX5000 as the device you are printing from. Click "OK" and the document will print with the new text.
I hope you find it very helpful.
Thank you for choosing fixya.com where we provide greater solutions.
Aug 11, 2011 | Epson LX-300 Matrix Printer
No content prints on document when word document is sent to the printer
Is the problem only with Microsoft Word? If so you might have selected something else in the "Print What" box in the "Print" dialog box instead of "Document". See the below screenshot and make sure that the "Document" is selected. The Print dialog box will come up when you click the "Print" sub-menu from the "File" menu, i.e. click "File" and select "Print".
If this doesn't help, reinstall the printers drivers/softwares. That should fix your problem.
If the problem isn't only with Microsoft Word Documents, then there might be other problems with your printer, it could be cartridge/s, ink, drivers, etc..
Let me know if you need further help.
Good Luck.
Thanks for using FixYa.
Jun 14, 2011 | HP Officejet 6500 AllInOne InkJet Printer
Keep printing old docoments / will not print current docoment / printing seem to be strunt
Follow these steps to fix your problem :
Method A :
Press the cancel button or use the cancel menu command on the printer
The most obvious way to cancel a print job is to find a cancel button or a cancel menu command on the printer and to press it. So, if you have not already done this, try this method first.
If this method worked for you, you are finished with this article. However, you may want to read the "Prevention tips" section to avoid this problem in the future.
If your printer does not have these items or if this method did not work for you, try Method B.
Method B:
Turn the printer off and on
Next, try turning the printer off and then on. With certain printer models, this cancels the print job.
If this method did not work for you, turn your printer off, and then try Method C.
Method C:
Use Control Panel to cancel printing
This method is a bit fancier. We will use Control Panel to try to cancel printing.
But what exactly are you trying to do? Are you trying to cancel printing only a single document, or are there other print jobs that you want to cancel? And are all the print job yours, or are there print jobs that other people have sent to the printer? If you have to cancel documents that other people have sent to the printer, you must have Computer Administrator status or you must have permission to cancel the print jobs. If you are using your own printer, you most likely have Computer Administrator status. If you are printing to a shared printer, you might have to ask the system administrator to cancel the print job for you.
To cancel one or more print jobs, follow these steps.
1. Click Start, and then click Run.
2. In the Open box, type control printers, and then click OK.
3. Right-click the icon for your printer, and then click Open.
* To cancel individual print jobs, right-click the print job that you want to cancel, and then click Cancel.
* To cancel all print jobs, click Cancel All Documents on the Printer menu.
Note If you cancel a print job that you did want to print, make sure that you send the print job to the printer again.
If this method did not work for you, make sure that your printer is turned off, and then try Method D.
Back to the top
Method D: Stop the print spooler and delete all spooled files
If you tried Methods A through C and you were not successful, Method D should work for you. If you came to Method D immediately only to delete a print job, some of what we say here might not apply to you, so please bear with us.
Method D is somewhat more complex and will require a bit more work than the other methods, but don't worry. Method D looks much more difficult than it really is.
First, in case that you don't know how printing works, here is a short explanation. Print jobs are sent to the printer as spooled files. This means that the files are put in a temporary location so that the printer can access a print queue and print jobs at its own speed. If you stop the spooler and its files, most of the time, you both cancel printing and delete the print job.
Note To use this method, you must have Computer Administrator status. If you are using your own printer, you most likely have Computer Administrator status. If you are printing to a shared printer, you might have to ask the system administrator to cancel the print job for you.
Step 1: Start Notepad
To stop the print spooler and its files, we will have you create and run a script file that will automatically stop the service. This sounds difficult, but it really isn't. Just follow these steps carefully.
2. In the Open box, type notepad, and then click OK. Notice that a blank Notepad document opens.
Step 2: Copy a command script to Notepad
Now we will have you copy and paste some commands to the Notepad document.
1. Carefully select (highlight) all the following text:
net stop spooler
del %systemroot%\system32\spool\printers\*.shd
del %systemroot%\system32\spool\printers\*.spl
net start spooler
2. Right-click the text that you selected, and then click Copy.
3. In Notepad, right-click in the blank document, and then click Paste.
4. Carefully select (highlight) all the following text:
C:\DeletePrintJobs.cmd
5. Right-click the text that you selected, and then click Copy.
6. In Notepad, click Save As on the File menu.
7. In the File Name box, right-click, and then click Paste.
8. Click Save.
Step 3: Run the command script file
Now that you have created the command script file, you will run it. To run it, you will copy and paste the name of the command script file in the Run box.
3. Click Start, and then click Run.
4. In the Open box, right-click, and then click Paste.
5. Click OK.
6. Notice that the Command Prompt window opens to run the command script file that you created. Notice also that this window closes automatically when the command script file has finished running. If you do not see the Command Prompt window open, check that you saved the command script file by using the correct name and that you entered the correct command script file name in the Run box.
If this method does not work the first time, or if you cannot print anything after you use this method, restart your computer, and then try again.
Nov 20, 2010 | Lexmark X2500 All-In-One Printer
My hp officejet 4315 only prints in black
Good day, To print from software application (windows) follow the procedure below.(for hp officejet 4315).
1. Make sure you have paper im the input tray.
2. On the File menu in your software application. click Print.
3. Make sure the HP officejet 2315 all in one is the selected printer.
4. If you need to change settings. click the button that opens the Properties dialog box.
Depending on your software application, this button might be called Properties, Options, Printer Setup, Printer, of Preferences.
5. select the appropriate options for your print job by using the features available in the Advanced, Paper/Quality, Effects, Finishing, and COLOR tabs.
6. Click OK to close the Properties dialog box.
7. Click Print or OK to begin printing.
God Bless.
Oct 19, 2009 | HP Officejet 4315 All-in-One Printer
Unable to delete doc after being sent to printer
First, I would try canceling the document either at the printer (hit cancel if it has already been sent) or at the computer.
You can do this by going to start -> settings -> printers and faxes
double click on the printer to open it
right click on the offending file and hit delete
It sounds like both of these have been done already. So...next option.
Second option - Restart the print spooler
Go to Start -> Settings -> Control Panel -> Administrative Tools -> Services
Click on the "Print Spooler"
Select Restart
Third option - delete the document from the spooler
Stop the Print Spooler by following the instructions above and clicking "stop"
Delete all files in the c:\windows\system32\spool\printers directory
Restart the print spooler.
CAUTION!!! - This will clear out both the offending job and any other jobs that have been sent to the printer after the offending job. If you have a number of other jobs, you may wish to clear out only the offending job from the printers directory.
Hope this helps - flub
May 29, 2009 | HP Officejet 4315 All-in-One Printer
Printer will not print multiple copies
go to start menu, control panel, printers and faxes, right click your printer, click properties, click the advanced tab and make sure your printer is set to spool print documents.
May 29, 2009 | Lexmark X2600 InkJet Printer
Printing Acrobat 9 pdf file to the Imagerunner 7200
In acrobat go file, print and press advanced. Check print as image. Print the job again and see if you get different results. This does the image processing on the PC. Your document may have a postscript error in it and your device may be set not to print PS errors.
What driver language and version are you using?
Try updating your driver to the newest version, get device status.
You may also wish to try PCL printing for that file. (as a workaround)
Do other files have the same problem? What about when sent to another printer entirely?
Mar 05, 2009 | Canon imageRUNNER 7200 Copier
Stalled printer cartridges
Sounds like an issue with the print carriage. When it's out of alignment and tries to print, it can make awful noises. HP.com has a web page that describes a number of troubleshooting steps when you have print carriage issues:
Carriage Jam Errors
There's also a related web page having to do with the noise coming from the printer:
Noisy Print Carriage
Hope this helps. Good luck.
Oct 07, 2008 | HP OfficeJet 4215 All-In-One InkJet...
Brother HL 5140 Laser Printer Logo
766 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
