Question about Uniden BC796D Base Scanner
CANT GET IT PROGRAMED FOR 800 MEG HTZ - Uniden BC796D Base Scanner
    Genius:
  • 1,274 Answers
You can download a manual for this unit at, BC796DOM.pdf it is 84 pages....hope this was helpful...
Posted on Apr 26, 2010
Extremely strange issue. I recently cannot connect to wi- fi at my house or my business with my android maxx phone. It will connect for a few seconds then it disconnects. I tried connecting at my sisters...
It sounds like you have a dual band router which has two wifi signals .. 2.4 htz And 5 htz. You might find you are better off on the 5 htz as this gets less interference.if this is not the solution try logging on with this phone but when it gives you the sSid of the router you wish to log into, go far right arrow and look for "forget this network" that will remove any previously saved password for that network then re-enter correct password and the conflict should go away.
Dec 05, 2014 | Computers & Internet
Pioneer htz 151, does it support optical cable?
I looked thru the HTZ151 manual and there is no mention of an optical connection. If it did support optical, you would see a square black port usually on the rear panel.
Mar 06, 2011 | Pioneer HTZ-151 Theater System
Had my Tv for a week and connected it to a Thomson sky receiver. Everything worked fine until today. When watching sky progammes the screen continuously flashes every second making viewing impossible. I've...
Make sure both deviced are set for 60 htz, it might be that there is a signal overly if one is set for 50 htz and one for 60 htz double check your screens refresh rate make sure its 60 htz as well. If it flashes once every second while staying on most of the second this could be it. check to also make sure all the cords are correctly positioned and try to keep the cords away from audio equipment stereos/ home audio, this can also cause signal issues.
Nov 06, 2010 | LG 42LC2D 42 in. LCD HDTV
I need to know more about a Gateway Performance 800 motherboard. I added a second 128 meg SDRAM 100 Mhz simm in bank 1 (the board came with a simm in bank 0). The BIOS recognizes the original simm as 128...
Check the specs for your new ram. It sounds like you have double density ram installed. If your motherboard only supports single density it will only see 1/2 of the modual hence 64meg showing for 128 stick.
Please rate this solution if it has helped you.
Thanks, Gary
Jul 11, 2010 | Gateway Performance 800 PC Desktop
How do i increase the number of hertz that my tv work at?
That is telling you that the broadcast signal is at 60 htz.
Jun 04, 2010 | Samsung LN40B630 40 in. LCD TV
My computer screen keeps jumping, what can I do?
Change your computer display settings: try a lower resolution first like 800 X 600 then gradually increase it until your monitor 'complains' (eg. is not stable and jumps around or cannot display anything properly). You could also fine tune your video card display 'frequency' if it has been set higher than 50 or 60 htz as your momitor may not be able to handle anything higher.
Dec 29, 2009 | Dell Dimension 2400 PC Desktop
Trying to put my pc picture to my rca mm52100 via svga1. I have sound but picture is scrambled.
set your pc to the lowest setting in your display settings it should be set to 800 by 600 and at 60 htz and by using a computer monitor cable goodluck
Sep 12, 2009 | RCA MM52100 52 in. Rear Projection...
Pioneer HTZ-370DV Home Theater System Suddenly Turns Off
out put protection fault check speaker cables and speakers
Dec 10, 2008 | Pioneer HTZ-360DV System
Uniden # bc145xl scanner
How do I program my Uniden Bearcat BC 145xl? I lost the booklet.....
Oct 29, 2007 | Radio Communications
Uniden BC796D Base Scanner Logo
53 people viewed this question
Top Uniden Radio Communications Experts
Jason
Steve
eradiostore
eradiostore
Are you an Uniden Radio Communication Expert? Answer questions, earn points and help others
