Question about Microwave Ovens
Panasonic NNK 802/852 Blow out when I pressed button to start micro. My finger may have been wet. I had an electrician out to tell me if it was repairable but he was not a panasonic engineer. Can it be repaired?
    Habit-Forming:
  • 193 Answers
Your wet finger had nothing to do with this problem and yes it can be fixed
Posted on Apr 27, 2010
Why did my micro stop working?
I guess the main plug fuse does not blow for the same reason it does not blow and you can wreck a PC, although not certain why that is. I have a feeling from past work on a Panasonic that there is an internal fuse as well. This may have blown with the power surge.
Jul 07, 2014 | Panasonic Nn-sn797s Countertop Microwave...
My microwave intermittently blows the downstairs sockets
If it is tripping the breaker when you just close the door, I think it might be one of the door switches that the latch activates. There are usually 3 switches behind the latch holes in the microwave. One is a safety monitor switch that is suppose to blow the internal fuse if the microwave is started and the door is not closed properly. It should blow the micro fuse before the house breaker unless you have a weak house breaker. It will do the same thing if start is pressed and it senses a problem with the door. You say the problem is intermittent so I assume you do get it to work at times so I'm guessing most of the microwave is OK. I'm pretty sure you have a door switch problem--- either out of adjustment ---or 1 of them going bad.
Apr 03, 2014 | Neff Microwave Ovens
Power trips after pressing start button
We recommend you have the microwave moved to a different electrical outlet, and circuit, if possible. If the problem stops, then we recommend you contact a local qualified electrician.
Mar 23, 2014 | Panasonic Microwave Ovens
Where is the high voltage capacitor at on panasonic microwave model nn-sn960s
behind the control panel,while your checking the h.v. cap check the h.v. diode for a shorted condition as this will also blow the 20 amp fuse too
Jan 06, 2013 | Panasonic NN-H275 Microwave Oven
Dimension 4 microwave stuck on demo mode
Here are is the manual:
http://service.us.panasonic.com/OPERMANPDF/NNT888S.PDF
Page 13 tells how to shut off Demo mode. (Press FUNCTION-0-2.)
Aug 12, 2009 | Panasonic NN-T888S Convection/Microwave...
Microwave panasonic model nn 6358 about 10 years old
In most cases, you press Clock, enter the numbers for the time, then press Clock again, or possibly press Start.
Sometimes you have to press Clock, Clear numbers, then Clock or Start.
Or Clear, Clock, numbers, then Clock or Start.
In some older models, they had a very small mechanical clock button located at the top right corner of the controller near the display window. If yours has that, press it, then the numbers, then that button again or Start.
If this doesn't do it for you, could you post a clear photo of your control panel?
We're happy to help and we appreciate your thoughtful rating of our answer.
Mar 21, 2008 | Microwave Ovens
Sunbeam SMW5500 micro/convection oven shorted out when opening door
You are decribing a typical Door Safety Switch problem. The Door Safety Switches has Failed.The Door Safety Switch is designed to shut down the Micro in the event the Micro is still cooking when the door is being opened. The first "Click" of the switch cuts off the "Cook". If it does not cut off the "Cook", the second "Click" blows the power. Otherwise it would "Cook" with the door open, and I need not to tell you how DANGEROUS that could be. It first Tripped the Circuit Breaker which supplies power to the Microwave. After Re-Setting the Breaker the same thing happened except this time the Micro is DEAD- not even a light working. Yes, there is a line FUSE inside the Micro. You however need to address the Door Switch SHORT before replacing the fuse. If not, it will just Blow The Fuse Again, and Again, until the Short is corrected.
Call around, ask How much to replace a Door Safety Switch.
Good Luck!
Feb 15, 2008 | Microwave Ovens
Microwave Ovens Logo
85 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
