Question about Lexmark Z2320 InkJet Printer
The power buttom is bllinking and the printer does not print. I cannot reach the cartridge. What can I do?
  • Official Brand Answer
  • 3,344 Answers
Most probably, you're having a problem with the cartridge not being recognized the printer. Maybe it's not seated well in the carrier or just needs cleaning. Maybe the carrier itself has stalled. Unplug the power supply(black box behind the printer where the power cord is attached) from the printer. Open the cover of the printer where the ink carrier is. Hold the solid white tape you see in the middle. Slowly drag the ink cartridge carrier to the center for easy access. Clean the nozzles of the cartridges. Reload the cartridges. Plug the power supply back in the printer. If power light is still blinking, check ink levels. Cartridges may need replacement. If you need more assistance, leave a comment and I'll get back to it. Thanks.
Posted on Apr 26, 2010
  • cristina_nat Mar 21, 2011
    i already followed the above instructions but it is still blinking and could not print...
  • Lexmark
    Lexmark Mar 28, 2011
    You could try to insert a different known working cartridge and see if problem persists. If problem continues, there could be a hardware problem in the printer. I would strongly suggest you contact Lexmark technical support for additional assistance.
X3350 printer says incorrect right cartridge
My be ink cartridges has not refilled in proper way.Are you sure your cartridge are compatible with printer?
You can follow the given steps..
  1. Remove the indicated print cartridge.
  2. Disconnect the power cord from the electrical outlet.
  3. Reconnect the power cord to the electrical outlet.
  4. If the power button button is not lit, press power button.
  5. Reinsert the print cartridge.
If the error:
  • Does not reappear, the problem has been corrected.
  • Reappears, replace the print cartridge with a new one.
**If you need any technical help on printer then you can reach at http://www.vtechsquad.com/printer-support/
Mar 14, 2013 | Lexmark X Office Equipment & Supplies
How to reset canon mp258
Reset Canon MP258 Printer procedure:
1. Press power button / power switch
2. Plug cable power with holding power button
3. Press Reset button one, release power button and press reset button twice until control panel show "O".
4. Press "+" buttom, display changing from 0 to 1
5. Press Power Button again , Printer will be print 1 page
6. Open printer cover
7. Unplug power
8. Take out cartridge 810 and 811
9. Plug power
10 . Press power switch
11. Open scan cover
12. Insert cartridge 810, 811
Aug 02, 2011 | Canon Office Equipment & Supplies
How to reset mp258
7. Unplug power
9. Plug power
11. Open scan cover
Jun 14, 2011 | Canon Office Equipment & Supplies
I refill my cartridge hp d1660,how to reset cartridge ink level?
Hum.... D1660 is not easy to reset the ink level.
Whenever you print.... Press cancel buttom first and Press Power button(with holding cancel button) and let go at the same time... should hold about 3 sec.
At least you can get the print out... Little pain in the ****....
If you would like to save money, try refill kit by "ROADINK".
Not only they are easy, but also the printing quality is good.
For your better understanding pls check out my youtube video.
And will see how easy ink refill can be done.
May 04, 2011 | HP D1660 InkJet Printer
My PIXMA MP 780 consistently prints with a small black smudge on the top of every page, even after performing routine maintenance. Do I need to get the machine replaced or fixed?
No need to replace for a new cartridge. Just clean the buttom plate from where your ink cartridge is installed. Or take the buttom plate out from your printer, and soke it with hot water for atleast 10mins to remove the ink residue. Then wipe it with dry cloth or absorbent tissue. then place it again and run a test print. thanks
Jan 08, 2011 | Canon PIXMA MP780 All-In-One InkJet...
Printer won't print
Sounds to me the printer is trying to tell you that there is a paper problem.
Please check ther entire paper path for any scraps of paper.
Also, make sure that the feed rollers are clean and soft.
May 09, 2009 | Office Equipment & Supplies
Printer wont work
CARTRIDGE OUT OVERRIDE
From the main menu on the printer, press "right arrow" to "System Setup", then press "Select" (green button with check mark)
Press "right arrow" to "Print Quality" and press "Select"
Press "right arrow" to "Replace Supplies" and press "Select"
Press "right arrow" to "Override Out" and press "Select"
Press "Select"
If "stop at out" is selected, the printer will stop printing when a cartridge reaches the recommended replacement point. If "Override Out" is selected, the printer will continue printing when a cartridge reaches the recommended replacement point. The factory default settig is "Stop at out".
Apr 30, 2009 | Office Equipment & Supplies
Nothing prints
If you replace a new toner and sitll not working then you should push and hold on start buttom for 1 min
Feb 23, 2009 | Brother HL-2040 Laser Printer
Toner
You could try two ways.
1) reinstall the software.
2) push "start" buttom for 1 min
Sep 16, 2008 | Brother HL-2040 Laser Printer
Printer is not working
Try pushing the print head carriage with a bit of gentle force. It is getting stuck, and hence the error. You may have to open side and top covers to reach this. Note: this is not the cartridges, but another device that moves back and forth on the slider carriage.
May 15, 2008 | Canon Office Equipment & Supplies
Lexmark Z2320 InkJet Printer Logo
130 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
