Question about KitchenAid KGSA906PSS Gas Kitchen Range
KGRA806PSS shutdown after cleaning
I have teh KGRA806 range. Same problem and this is the 2nd time. Piece of **** range is going to cost me more in repairs then range cost.
    President:
  • KitchenAid Master
  • 2,651 Answers
Sounds as if the thermal overload has gone bad. and it if thats the case, id check your installation. most common reason is the back plate (supplied with stove is not installed) unit needs to breath and the slotted bracket needs to be installed not flush up against custom counter top.(dont know if that's the case but its what i see most, if that isnt the case and your plate is installed i would call kit-aid, and talc ot a cust rep about the issue and how its the second time its happened , the y may cover te cost of repair for you. part number 8300802 parts about 50 bucks, and you could install it your self, just a bunch of screw to access the back panel.WITH POWER OFF TO THE UNIT LIVE WIRES!!!!!!. order ht enew part first and whr you remove the 10-12 screws and you gain acess torearof the unit itll be easy to spot, half way up inbetweeen the broil element.
Posted on Mar 24, 2008
SOURCE:
The start button will not start the oven, all other options on the control panel are working, just the start button.
not good
have you clean it or split something at some time
the igniters can be inspected
wait till gas clears
user manual page 10 ...start button has a control lock design
does the user manual help
https://www.manualowl.com/m/KitchenAid/KGRA806PSS/Manual/249033?page=12
May 18, 2016 | KitchenAid KGRA806PSS Gas Kitchen Range
Kitchen Aid KGRA806PSS
hmmm....that interlock is dependent on a temperature sensor, to ensure that no one opens that door when it's too hot inside. I'm assuming that it's still locked, even after the temperature has dropped off?
Feb 26, 2008 | KitchenAid KGRA806PSS Gas Kitchen Range
I don't know which part to order?
Will need model number to follow up.
Or send photo to supplier.
It is also helpful to know the shape of the shaft, eg. D-shape.
Jul 23, 2013 | KitchenAid KGRA806PSS Gas Kitchen Range
How do you adjust the primary air on a range top burner. Kitchen aid KGRA806PSS propane range
Possible too much air entering the burner tube to which the burner is attached.
But there might be some soil on the burner that you are not observing.
Jul 11, 2013 | KitchenAid KGRA806PSS Gas Kitchen Range
Oven went dead in self clean mode and the door remains locked. Is this the thermostat? How do I get the door unlocked when control panel shut down? Kitchenaide KGRA806
Unplugged the stove and turn off the gas.Take the back off the oven and replace the thermostat. It's super easy. Before you buy the part call kitchen aid... this is a known problem. They will say the parts are not free and try to give you a discount. But if you continue to argue , they'll send it for free.
Mar 02, 2010 | KitchenAid KGRA806PSS Gas Kitchen Range
Unable to find the serial number on my KGRA806 gas range. I have looked all over the oven door frame, drawer frame, chassis, behind the range, under the range. I have looked over the entire exterior. The...
Open the bottom drawer and look on the frame of the stove where the door closes on it. There should be a model number and serial number there. You should probably record it and add it to a file with all your appliances brands and model numbers for safe keeping.
If you have any other appliance issues or needs parts, supplies or accessories, you cn contact us at:
http://www.fixya.com/repair/d499389-accurate_appliance_repair_service.
We are available to assist you from 7AM until 7PM CST.
We hope this answers your questions and helps. Have a great day! Ella
Jan 06, 2010 | KitchenAid KGRA806PSS Gas Kitchen Range
After using the self-clean cycle, display panel went black and oven door stayed locked.
Happens alot dont feel bad , self clean mode runs the elements at 500 deg. to cook off everything possible , what happens is the cabinet gets to hot and heats saftey temp. fuses until they go out and they are not resetable. they are always located in different areas of ranges but usaully in the back. you can ohm them out to check them if you have a meter.let me know if you have any other questions.
Phil
Apr 14, 2009 | KitchenAid KGSA906PSS Gas Kitchen Range
try pressing stop/clear press and hold timer for 5 seconds after making sure there is piower to the range
Jan 22, 2008 | KitchenAid KGRA806PSS Gas Kitchen Range
Kitchenaid Superba Gas Range
It appeared to be something to do with the plenum and cleaning - repair man came - cleansed and it was okay. MK
Jan 15, 2008 | KitchenAid KGRA806PSS Gas Kitchen Range
KitchenAid KGSA906PSS Gas Kitchen Range Logo
243 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Jay B
Level 1 Expert
Colin Stickland
Colin Stickland
ittco
Level 1 Expert
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
