Question about Whirlpool Cabrio WTW6600SBT Top Load Washer
Cabrio wtw6600sbo flashes f51, f70 during self test will not spin. however during manual test all light flash when drum turned by hand. CPU?
Washer wont spin its a whirlpool wtw6600sbo
Posted on Apr 28, 2010
I have an error message f51 on my whirlpool cabrio washer model number WTW7600XW0, What is it and how can I fix this error on my own
F51 error code is a motor rotor position sensor failure or a lower harness problem. You need to check the motor in manual test mode, not automatic test mode. This will check the hall sensors and do a spin test: Be sure the washer is in standby mode (plugged in with all indicators off; or with only the Clothes Clean or Done indicator on). Select any one button (except POWER, START, STOP, and PAUSE/CANCEL) and follow the steps below, using the same button: Press/hold 3 seconds. Release for 3 seconds. Press/hold 3 seconds. Release for 3 seconds. Press/hold 3 seconds.
If this test mode has been entered successfully, all indicators on the console are illuminated for 5 seconds with 88 showing in the Estimated Time Remaining two-digit display. During the 5 second wait time with 88 showing in the display, press the same button once. You should be in manual test mode. If the button is not pressed within 5 seconds, the automatic test mode begins. The Rotor Position Sensor uses Wash, Rinse, and Spin indicators to detect the three hall sensors. Console can have up to two of these indicators on at the same time when the tub is not moving. Open the lid and rotate the basket by hand. The Wash, Rinse, and Spin indicators should toggle on and off according to the direction the tub is being turned.
SPIN TEST: Make sure lid is down. Press and release: 2nd RINSE or EXTRA RINSE. The lid locks and the lid lock indicator turns on. Press and release; SPIN SPEED, WATER LEVEL, or LOAD SIZE. The motor/basket spins at 23 rpm. Press again, motor /basket spins at 530 rpm. Press again, motor/basket spins at 950 rpm. Press again and motor turns off.
Oct 24, 2014 | Washing Machines
Tip
F51 Error on Whirlpool Cabrio Washer
When you see the F51, first, try spinning the drum by hand from inside. It should spin freely and coast a bit. Mine did not. Took the drum out and there was the wet pair of undies stuck to the side! Removed that and all was well. Try this before troubleshooting rotor position sensor problems.
on Jan 09, 2015 | Whirlpool Washing Machines
What does error code f 51mean?
http://www.applianceblog.com/mainforums/threads/32879-Whirlpool-Cabrio-UL-F51-Error-Codes
Jul 27, 2014 | Whirlpool WTW8200YW 4.6 cu. ft. Cabrio...
How do I fix a f51 code on a whirlpool cabrio washing machine
SPIN TEST: Make sure lid is down. Press and release: 2nd RINSE or EXTRA RINSE. The lid locks and the lid lock indicator turns on. Press and release; SPIN SPEED, WATER LEVEL, or LOAD SIZE. The motor/basket spins at 23 rpm. Press again, motor /basket spins at 530 rpm. Press again, motor/basket spins at 950 rpm. Press again and motor turns off. This was a cut n paste from a blog on that issue.
Apr 22, 2014 | Washing Machines
Whirlpool cabrio washing machine doesn't spin
Try to turn the drum by hand, if it hard to turn, there may be something stuck underneath spin basket. If it does turn freely but makes a loud growling sound, you probably have a bad bearing. You should notice black oil and water mixture at bottom of washer, on the rotor. It will usually throw a f51 error code. This unit has service bulletin on this problem.
Apr 05, 2014 | Whirlpool WTW6400SW Cabrio Washer
Lid lock flashing
There are two issue needs considering. Should you have very less load and get wrong setting so the sensor can not weight. Do you have any error code like F1, F51, etc...
Try to turn the drum by hand see if it is freely turn to make sure nothing was caught in between.
This motor has a nut that was loosen by time or by working with large load for long. Lift over the washer to the wall, then you can kneel down and look at the bottom. There is a 1/4 hex head nut-see if it is loosen and reset the unit again.
F1 code - the control board dead, need to call Wp for replacement, as far as I know, they cover 1 time part and labor for this code.
F51 code-motor issue or weight sensor, need to figure out which one cause problem.
Oct 21, 2013 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool cabrio WTW6700TW1 only fills little bit, won't turn or agitate, buzz sound/humming noise,code F51 flashes??
The F51 error is a RPS (rotary position sensor) board failure where the control board looses contact with the RPS during the machines operation. The RPS uses hall effect sensors to determine the speed and direction of the drive motor, allowing the control board to constantly monitor the motors operation. Because this error is a communication error and not a mechanical error with the motor itself (that would be and F52 error) we can limit our trouble shooting to the three items that make up the RPS circuit, the control board, the wiring harness, and the RPS itself.
Jan 16, 2011 | Whirlpool Cabrio HE 4.5 cu. ft. Washer
Machine keeps flashing F-51
This happened to me, everytime I washed clothes it lite up F51 and wouldn't go through the cycle to drain. I had to manually put the machine on drain and spin to get the water out.
After three times of having the repair man come I called Whirlpool and said I had a lemon and it couldn't be fixed and the machine was replaced. They are allowed to try three times to repair the machine for the same problem, like it lighting up F51 and then they have to replace the machine as a lemon while the machine is still under warranty.
I hope this was of help. The delivery man said that the machines are bounced around so much during transit that it's no wonder they have problems.
Feb 10, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool Cabrio WTW6600SBT Top Load Washer Logo
488 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
