We have a grundig elegance tv and it has been changed to another language and cant get it back to english
    Scholar:
  • 103 Answers
If you can find the menu, look for a setting labeled with something LIKE: "idioma" (if it's been changed to spanish), "idiome" or "langue" (if changed to french) or "sprache" or "zunge" (if it was changed to german). Select this section and look for "ingles", "anglais" or "englisch". (These all mean "English" in spanish, french, and german, respectively.) Choose this and it should switch back to english. I hope this helps! Sincerely, Der Strom
Posted on Apr 26, 2010
How can i change my tv language back to english?
Hi dear,
Kindly mention model number of your tv.I will give you the solution.
Aug 19, 2014 | Konka Televison & Video
Grundig tv problems
If you have sound then it is probably a high voltage problem.
Jul 14, 2014 | Televison & Video
Change language from Spanish to English Vizio 323SV
You may have to go back to the setup procedure and search for a language option to select English.
Dec 19, 2013 | Vizio VO320E LCD TV
Grundig elegance 72 flat screen problem
sounds like frame collapse check out repair costs as can be rather expensive
Dec 01, 2012 | Grundig Televison & Video
How do you change a language that you cant read back to english
go to language on the system and change the language that u can understand. better if u take a look at the manual first and read it...tnx
Jun 19, 2012 | Ematic EM162VID MP3 Player
NEC TV - How to change language of menu
I just bought an NEC FS-5160 from a local opportunity store last Friday (July 2, 2010) with the same problem. After a few minutes of fiddling I found the solution:
1. Press 'Menu' button. You will see 'Menu' written in Russian. To the right you will see a number '1' above the the word 'TV' or 'Video'. This is 'Menu 1' or screen 1.
2. Press ONLY the 'Menu' button and the arrow on the left will scroll down. On the fourth press the '1' referred to above will change to a '2' for 'Menu 2' or screen 2.
3. Continue to slowly press the 'Menu' button until 'Memu 3' or screen 3 appears.
4. Press the 'Menu' button twice more and then use the first channel changing button to change the language from Russian to English.
Apr 02, 2010 | Grundig GF70-600 TV
Tv won't stay on
Hello ! this problem can come about if the video card has faults ie processor lickage or an i tem is burnt , processor over heating .
I recomend u change the video card
good luck
Sep 08, 2009 | Televison & Video
Open Questions:
samsung pn64f8500 boot loop with evoulution kit 3000za installed I had perfectly working Samsung plasma ph64f8500 working fine with Samsung evolution kit 3000 ZA installed. Then we moved I took off the evolution kits so the movers would not knock them off. I powered up without the evolution kit installed accidently. Now both plasma are stuck in boot loop. They power up but go to the smart tv logo and cannot find the evolution kit. I read somewhere a long time ago that I needed to reset the evolution kit to a state where it had not been installed. The current issue is the Main Logic Board eeprom instructs the unit to boot correctly but it cannot find the evolution kit. If you boot without the evolution kit the system halts and indicates on the screen the evolution kit has been uninstalled and you must install it if you wish to view. If it could find the evolution kit one could go thru the menu to uninstall it correctly. One option is to manually reset the eeprom to remove the install instruction that boots looking for the evolution kit. I have been looking for the eeprom on the Samsung main logic board but I cannot download the logic board schematic. I cannot find the logic board number. The main logic board is BN94-0625C. The logic board has tow other part number references.• MFR Part Number 1: Samsung BN94-06205C • Board Number(s): BN41-01998A, BN97-06633G i have been researching the logic board IC Numbers and belive that IC 1701 is the eeprom that requires reset. The youtube videos for similar models indicate a eeprom that is listed as a part nmber for this samsung pn64f8500 unit as 24C512 and shows how to jumber 2 IC locations that will force the eeprom to reset to standard starup without the Evoution Kit 3000
Jul 16, 2018 | Samsung Televison & Video
Televison & Video Logo
249 people viewed this question
Top Televison & Video Experts
