Question about Toro 42'' Zero Turn Lawn Mower 22hp Kawa Consumer
Trouble starting and a lot of black smoke at startup
I have a Toro 38" Zero-Turn Timecutter tractor. I have changed the oil, spark plug, and batter to no avail. The unit is only 4 years old with maybe 50 hours of use in its life. Could it be bad gas? The only things I have not changed are the oil filter and air filter. The air filter is clear however.
  • 54 Answers
Could be. Black smoke means too muck fuel or not burning properly. Also make sure your oil is not over full.
Posted on Apr 28, 2010
Toro wont start
Clean the fins on top of motor and engine.
Sep 07, 2014 | Toro TimeCutter SS4235 - 20HP 42 Zero Turn...
How do I replace an idler pulley on mower deck on toro timecutter mx 5060?
Release belt tension, unbolt the pulley, replace it with a new idler pulley. If you need more help, please follow up here.
Jul 29, 2014 | Toro Zero Turn TimeCutter MX Series MX4260...
Can you jump start a toro zero turm mower with a car battery and jumper cables?
Better to not jump them can burn the leads up. Pull it out and slow charge it
Jul 17, 2014 | Toro NEW 42 TIMECUTTER 21.5 HP KAWASAKI...
Timecutter 42 kholer electrical problem
The battery may not be chargeable and will have to be replaced.
Apr 20, 2014 | Simplicity 42 Toro Timecutter 20hp Kohler...
Toro str will not start, motor spins but will not fire
Ensure clean fuel. Always use Stabile in fuel. Follow fuel line from fuel tan to carb, ensure no leaks. Remove carb fuel bowl to check float operation. Have pliers to crimp line or use fuel shut off valve. Remove carb float bowl and clean. Float should hang down freely gas should flow. Push float up gas should cut off. Replace spark plug, ensure plug wire snaps on tight. Clean or replace air filter. Ensure oil is full, 30w oil. All mowers have low oil shutoff.
Sep 12, 2012 | Toro TimeCutter Zero Turn Lawn Mower...
TORO TIME CUTTER SS4235,NOT STARTING,NO ELECTRCAL POWER TO SWITCH
Check wiring for ground. Ensure battery is fully charged or replace. Replace spark plug. Clean or replace air filter. check oil level, all mowers have a low oil start cutoff. Bad gas? Flush out fuel tank by removing gas line, flush fresh gas thru. Reattach gas line, fill with fresh gas, always use Stabile in gas! Check fuel line for cracks and secure connection to carb. Battery should read 12.8 volts or higher. .
Aug 21, 2012 | Toro TimeCutter Zero Turn Lawn Mower...
Toro cutting off
Maybe low oil level, all mowers have a low oil cutoff. 30w oil.
Aug 07, 2012 | Toro TimeCutter Zero Turn Lawn Mower...
Toro 38" Locked up?
on the bottom of the engine there is a bolt but if there was little to no oil they will not warr it most shops don't rebuild anymore the just replace the whole engine where is it you live?
Apr 07, 2012 | Toro Zero Turn Rider 74366 Lawn Mower...
Toro 42''  Zero Turn Lawn Mower 22hp Kawa Consumer Logo
717 people viewed this question
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
Mike Squire
Roland W VanLue
Roland W VanLue
Are you a Toro Garden Expert? Answer questions, earn points and help others
