Question about Plumbing
I have a Mcculloch 14" chain saw Model FR 2.0 s/n46750-48? The chain oiler will work for about 1-1 1/2 min then stop. How can I repair it?
    Problem Solver:
  • 9 Answers
It sounds like the vent is clogged. Usually it is on the oil fill cap
Posted on Apr 26, 2010
Automatic oiler problem since date of purchase. Remedy?
No found recall for this. link below not your exact model, may help on repair of oiler
Chainsaw chain oiler repair
Jan 16, 2016 | Makita UC3530A 14" Electric Chain Saw
MCC1514 oil
Most any chainsaw , chain oil . Just so it is not dirty and will not clog the oiler.
May 17, 2014 | McCulloch 14" Electric Chain Saw Mcc1514
What is the oil capacity for the Hornet 14" Mach 2
Usually about 3-4 ounces in the bar oiler tank. The fuel mixture you can find at McCullock.com.
May 03, 2014 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
Chain not getting oil
Extremely difficult! If the oil pump or worm gear is defective it may be the most difficult saw to repair. This is the only saw I have seen with the oiler mounted behind the fly wheel.
Your basic model number is 600035. There are 11-, 21-, and 22- prefixes used with 600035s. There are also a ton of suffixes with the 600035s. I think the suffix is on your saw immediately after the basic model number somewhere (usually on bottom of older Macs along with the serial number. The dash of the serial on older Macs is the prefix). I must defer to you to find your exact IPL, here:
McCulloch IPLs
http://www.ordertree.com/modelinfo/McCulloch/139.59.html
I chose this one as an example "22-600035-58" for an IPL
http://www.ordertree.com/modelinfo/MCC/22-600035-58-Mac-3516-IPL-211229-01/139.22-600035-58-Mac-3516-IPL-211229-01.1.59.1.html
The "Powerhead Assembly" lists an oil pump (1) and a worm gear (10). These are the most common failure on most saws but Macs have many more hoses than most. There are oiler components on at least 2 different details. It appears the oil pump is on the starter side of the engine. and you may need to remove the fly wheel for access. I would examine every connection and perhaps try the "Kit Gear/Plunger Assembly" before trying to access the oil pump and gear.
Oil System Plugged.
  1. Remove the clutch cover, bar, and chain, clean the bar groove, any holes and passages on the rear of the bar (both sides, consider rotating the bar), if equipped with a sprocket nose ensure it rotates easily at least one complete revolution. Clean the saw oiler hole and channel. Insert a blunted, hooked piece of wire through the oil filler hole and pull the hose in the oil tank out. Pay attention to the screen or filter on the free end (clean or replace, difficult to determine serviceability). Start the saw and see if it oils when revved up. If yes reassemble your saw. If no, continue with 2.
  2. Work your way through the linkage cleaning and replacing any defective parts as you go. Carefully check the hoses for cracks especially at bends and connections. Please make extensive notes & some digital pictures will help during reassembly.
If it does not oil on completion of 1 it is most likely a bad oiler or worm gear. Please see the IPL to aid in oiler component identification.
You can reply below with any questions. I hope you found this most helpful. Good Luck
Lou
If you opt to remove the fly wheel PLEASE reply to me first. I can probably save you a couple of headaches and may prevent component breakage.
Feb 01, 2010 | McCulloch Garden
Mcculloch 14" chainsaw no oil at chain??
Oil System Plugged.
  2. Work your way through the linkage cleaning and replacing any defective parts as you go. Carefully check the hoses for cracks especially at bends and connections. If equipped with an oil pump it is usually behind the clutch (clutch is a left handed thread). Please make extensive notes & some digital pictures will help during reassembly.
If it does not oil on completion of 1 on a McCulloch it is most often a plugged or disconnected hose.
There are in excess of 230 different McCulloch chainsaws. Oilers are often specific to one model. Please reply below with the model and serial number of yours so I can provide a more complete answer and an IPL. HTH
Lou
Jan 22, 2010 | McCulloch Garden
Mcculloch em300s electric chain saw stopped oiling the chain. I noticed the oil had all flowed out in storage shed and when I refilled it and used it I noticed the chain and bar were dry.
This is a little complicated so I’m going in small steps.
http://www.m-and-d.com/parts.html
Click “Illustrated Parts Diagrams ON LINE”
Click “Click Here for Parts Lookup”
Changes to “Select OEM” Window reads “Briggs & Stratton ▼” Click the arrow and select “McCulloch Power”
Click “Electric Chain Saws” The model number of your saw is probably on a tag affixed to the bottom. The tag also displays the serial number.
If it is a 300S the hyphen is the bar length.
I looked at the 300S-16 (same oiler parts as -14)
  1. Remove the clutch cover, bar, and chain, clean the bar groove, any holes and passages on the rear of the bar (both sides, consider rotating the bar) Clean the saw’s oiler hole and channel. Start the saw and see if it oils when revved up. If yes reassemble your saw. If no, continue with 2.
  2. Item 15 has a filter on the bottom check it first, insert a blunted, hooked piece of wire through the oil filler hole and pull the hose in the oil tank out (clean or replace, difficult to determine serviceability). If good I’d look closely at item 17. I can’t get enough detail from the IPL but that is the logical culprit.
Oil systems on all Mac Electrics appear pretty basic. Good Luck
Lou
Nov 08, 2009 | Homelite Consumer Products 9.0 Amp, 14 In....
Can't get the chain oiler to work. Using standard bar oil.
You can always put some penentrating oil in the saw oil tube by the bar, spray it in with the plastic straw attatched. Sometimes this will clean things out. As far as the tube being un attatched,,,, taking case apart is usually the remedy - kinda takes a while... :) Hope this helps you, Rick.
Apr 19, 2009 | Garden
Plumbing Logo
70 people viewed this question
Top Plumbing Experts
Donni Steen
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
