Question about Canon PowerShot A520 Digital Camera
Will not save date every time camera turned on and off date needs resetting
  • Canon Master
  • 4,738 Answers
Time to change out the CR1220 battery that keeps the camera's time. It's located under the rubber flap on the left side of the camera (with the A/V and power inputs plugs). Just pry out its slide door with your fingernail, and take the little battery to your local drug store. It runs about $3 to $4 for a replacement.
Posted on Apr 26, 2010
    Problem Solver:
  • 5 Answers
I was very frustrated with this problem too! I changed my CR1220 battery and continued to have the problem. On closer inspection, I noticed that the contacts for the button battery were corroded. I hadn't expected or noticed it since the slot is so small. I used a scalpel blade and some rubbing alcohol to scrape and clear the contacts and it solved the problem. It works like new..
Posted on Aug 07, 2010
Date and time won't stay set
Had the same problem. The problem is a small button cell that needs to be replaced. From Canon's support page:
http://www.usa.canon.com/cusa/support/consumer/digital_cameras/powershot_a_series/powershot_a510?CMD=MIXED_SEARCH&mName=PowerShot+A510&mType=PowerShot+A+Series&pageKeyCode=ekbresults&searchString=date+and+time+wont+stay&BASIC_SEARCH_CURRENT_TOPIC_ID=1236&BASIC_SEARCH_CURRENT_TOPIC_TYPE=0&RESULTS=RELEVANCE&RELEVANCE_START=1&RELEVANCE_COUNT=25&CONFIGURATION=1011&PARTITION_ID=1&TIMEZONE_OFFSET=null&USERTYPE=1&isSecure=false
Jul 13, 2012 | Canon PowerShot A510 Digital Camera
Tip
DATE RESET PROBLEM ON DIGITAL CAMERA
Have you encounter on your camera that the TIME and DATE are always cleared once you turning ON? Menu of the date setting appears everytime inserting the battery and turing the power ON?
Dont worry the problem of your camera is only a minor. For your technical information, all cameras have a capacitor together with board that provide power to save your date setting or its work as a battery.
Once you open you camera and you found out color green stain can be seen in the part of the said capacitor. You need to clean first by brush and make it sure be gently while brushing the capacitor just to remove the stain.Then try to turn On your camera and set the date and time, after this turn off and remove the battery for a second. Once again put the battery on your camera and turn On. Once you need to set the date again it means the capacitor was damage and need to replce new.
if you have knowledge about repairing electronics what you need to do is remove the damage capacitor and replace it new with the same specifiction and size.
I hope my tips will help you
Good luck and thank you
on Jul 21, 2010 | Cameras
Time and date won't save
Replace the date/time battery. See the instructions on page 87 of the advance user guide.
Jun 11, 2012 | Canon PowerShot A410 Digital Camera
Camera keeps loosing the time and date settings. When turning the camera on the lens does not open, then a screen asking to set the date and time settings appears - once date reset the camera works...
have you check the settings for time and date have you saved it? You can also try to remove the cam battry for 2 mins. then put it back in then turn on the camera and then after few secs. turn it off, then see if the issue persist.
Feb 21, 2010 | Sony Cyber-shot DSC-W170 Digital Camera
Time and date resetting constantly...
This camera has a separate date battery. Lift up the small rectangular cover next to the main batteries. A small CR1220 battery maintains the date. Replace it and you should be OK. I just discovered this on the Canon web site.
Jan 10, 2010 | Canon PowerShot A720 IS Digital Camera
Camera resets DATE and Time to Jan 2002 when
Some of these cameras cannot save the date, and has no internal battery to save the data. The best solution I have use is to buy another battery with these kinds of cameras and always have one charging, or take two batteries when you take pictures.
These older point and shoot cameras are nice, and slower than the newer ones, but will not save the data unless you keep the main battery in it, or replace the one to be charged with another battery within a very short time.
Sep 27, 2009 | Nikon Coolpix 4300 Digital Camera
Powershot A700 camera won't save the date and time
The date battery needs to be replaced. It is a CR1220 "button" battery. Instructions for replacing it are on page 117 of the Advanced Camera User Guide, which can be viewed/downloaded here.
Feb 06, 2009 | Canon PowerShot A700 Digital Camera
Have to reset date every time I turn on camera.
You need to replace the date battery. It's a button-type battery (CR1220) which is in a holder near the regular batteries. After you pull the holder out, place the new battery into the holder with the negative side up, and slide it back into its slot. (Instructions are on page 120 of the manual if you have it.)
Jun 19, 2008 | Canon PowerShot A400 Digital Camera
Clock always reset to default upon power up
Either the replacement battery was dead or the camera needs to be serviced. If the date/time needs to be reset every time the camera powers up, the camera is not receiving the power it needs from the date battery.
May 04, 2008 | Canon PowerShot S5 IS Digital Camera
Polaroid digital camera a500
i cant get my vpc t-700 digital camera from saying no image i need to save my pictures thank you
Dec 28, 2007 | Sanyo Xacti VPC-T700 Digital Camera
Canon PowerShot A520 Digital Camera Logo
344 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
