Question about Sony BDP-S300 Blu-Ray Disc Player
My disc says, this operation is prohibited by this disc when I go to play it.
4 Suggested Answers
  • 5 Answers
SOURCE: playing the soloist on panasonic dmp-bd80. get
Try updating the units Firmware:
Firmware is software that exists usually on chip or flash memory within a larger piece of hardware, such as a Blu-ray player. Firmware can be upgraded to fix a technical problem with the player or to meet new industry standards.Firmware updates can be applied either by downloading them directly to your device, or by disc installation.
Posted on Jan 19, 2010
SOURCE: DISCWON'T PLAY, RECEIVE MESSAGE "THIS DISC CANNOT BE PLAYED, PLAYBACK PROHIBIT BY AREA LIMITATIONS
i am ohamed scondo
i have pdf repair
Posted on Sep 16, 2008
  • 208 Answers
SOURCE: Program Play of Title 32 Prohibited
NO. it will most likely be either a limitation of the player or a faulty/incompatible disc.
A very quick test is to play the disc in another slot and see if the problem moves with the Disc.
Posted on Mar 18, 2010
DVD says operation currently prohibited by disc Audio
Some discs for example will not let you bypass certain parts of a disc. Different types of disc will also stop certain functions happening. It's unlikely there is a fault, unless it's really crucial to the operation of the disc player.
Aug 24, 2017 | Televison & Video
Is there a way to change the region code on a Sony HCD-S300 Please?
Unfortunately, you have a DVD player that is "Region Specific" and cannot be changed. Your system has a region code printed on the back of the unit and will only play DVDs that are labeled with identical region codes. DVDs labeled "ALL" will also play in this unit. If you try to play any other DVD, the message " Playing this disc is prohibited by area limits." will appear on the TV screen. Depending on the DVD, no region code indication may be labeled even though playing is prohibited by area limits.
Mar 26, 2012 | Televison & Video
I have a dvd from England and my old Sony DVP-C670D keeps giving me a prohibited message4 every time i try to play it. How do i unblock the region code.
Although no guarantee, this 'region hack' is rumoured to work:
1. Place the DVD player into 'standby' mode.
2. Using the Sony remote, press the following button sequence: Title; Clear; Power (green button); 0 (zero button)
3. Using the remote, Open the disc tray, then close again.
Now insert your disc and attempt to play - allow up to 2mins to load/play. If no response, open/close tray and try playing disc again.
Cheers,
Jun 22, 2011 | Sony DVP-C670D
Mar 17, 2010 | Televison & Video
Playing the soloist on panasonic dmp-bd80. get
Jan 19, 2010 | Panasonic DMP-BD80K Blu-ray/DVD Player
Is there a code for multi regions for sony hcd s300
Put your player into „Standby“ Mode and enter one of the following commands if necessary:
Remote control command Function
[0] [RETURN] Default Default region code on the player
[1] [RETURN] Region 1
[2] [RETURN] Region 2
[3] [RETURN] Region 3
[4] [RETURN] Region 4
[5] [RETURN] Region 5
[6] [RETURN] Region 6
[P. MODE] [RETURN] Only play DVDs with the selected region; auto switching OFF
[AUDIO] [RETURN] Default Auto switching ON
[ANGLE] [RETURN] Enable video interference impulses (Macrovision ON)
[SUBTITLE] [RETURN] Default Disable video interference impulses (Macrovision OFF)
[PREV] [RETURN] Enable user operation prohibitions* and access restrictions
[NEXT] [RETURN] Default Disable user operation prohibitions* and access restrictions
* The DVD can no longer prohibit you from using the fast-forward, chapter change or Audio-/Subtitle-/Angle switch. You can no longer be forced to watch intros. Just press [TITLE] or [DVD MENU] and select PLAY.
Jan 12, 2010 | Sony DAV-S300 System
Program play prohibited
This can happen if you have the "repeat" function turned on on your DVD player.
Nov 10, 2008 | Sony DAV-C450 System
Cannot play DVDS
What does it do? I have a similar problem. the disk loads up and I get the previews, etc.. then I hit play and it says "Operation currently prohibited by disc.
Jan 01, 2008 | Sony DAV-FR1 System
Toshiba SD-43HK Discs failing to load.
Sorry not a solution but experienced the same problem. The problem started off the same as you described by now my player won't play DVDs at all. Seems that the laser is faulty and it is cost prohibitive to repair (it's sold as a complete module which would be around £100). I've been advised to replace it :-(
Jan 16, 2007 | Toshiba SD-43HTS System
Sony BDP-S300 Blu-Ray Disc Player Logo
1,242 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
