Question about LG WM-2277HW Front Load Washer
Water stays in softener and bleach dispenser after washing
Water stays in the softener and bleach dispenser after washing and also the bleach is not dispensing
Posted on Apr 27, 2010
How do I get the bleach dispenser to drain?
Hello Denise C - There are several things that could cause the bleach to not dispense into the washer. Are you sure the liquid in the dispenser after the wash is bleach? If it is pure bleach, the solenoid that lets the water into the dispenser is not working. This solenoid is located on the back of the dispenser. It only gets voltage during the dispense time and fills the bleach dispenser with water. The bleach dispenser fills while the washer is filling for the rinse cycle.
When the washer begins to fill for the rinse cycle, the bleach solenoid is energized and water flows into the bleach dispenser cup. When the cup is full the water siphons out and bleach and water flow into the tub.
If the liquid in the bleach dispenser is pure bleach you may need a technician to diagnose and repair the problem. The voltage will have to be tested to the bleach solenoid and a volt meter is required.
If the liquid in the bleach dispenser is water you probably need to clean the dispenser cup. Scum will build up in the siphon tube and stop the liquid from going into the washer tub. The incoming water will dilute the bleach and overflow the dispenser cup and run into the tub.
Remove the insert from the bleach and fabric softener compartments. Clean the bottom of the insert and the bleach and fabric softener compartments. Reinstall the insert and put the drawer back inside the washer.
To test the siphon action slowly pour water into the bleach compartment. When the water level goes above the maximum line stop pouring. The water should all drain out. You may also test the fabric softener compartment the same way.
I do hope this information proves to be helpful.
Jan 01, 2013 | Frigidaire Affinity ATF7000E Front Load...
GE WSXH208AWW doesn't dispense detergent, softner or bleach. Dispenser is totally dry after wash cycle.Appears no water gets to tray.
I'm having almost the same problem - the bleach & softener both will NOT dispense, but (LUCKILY) the detergent does dispense on mine, for now.
In order to get the solutions (bleach, softener, detergent) to go into the washer, the water needs to pour through the dispenser somehow. Dry means NOT working (mothmanmeg).
I need help, too!! We tried taking the drawer out & cleaning, no luck.
Apr 17, 2010 | GE WSXH208A Front Load Washer
Water left in fabrish softener dispenser after wash cycle
My Frigidaire front loader was doing the same thing and also not taking the bleach. I could hear that the water pressure was not real strong when I turned the machine on. I removed the two small screens on the back of the machine where the water supply hoses attached, found they were partially clogged and cleaned them well. The bleach and softener dispensers are now working like new.
Aug 03, 2009 | Bosch Washing Machines
MAH8700AWW - No Fabric Softener
Not sure if you've ever resolved this issue, but I'm dealing with it myself. I have come across this service manual that gives a very detailed illustration of the systems, how it works and how to test it.
Focus on pages 15 thru 25. Hope this helps you.
http://www.servicematters.com/maytag_library/docs/16026126.pdf
Jan 26, 2009 | Maytag MAH6500 Neptune Front Loading...
Leaking // bleach/fabric softener dispener isnt emptying
Remove the dispenser cup and clean it. Be sure to use He soap.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 10, 2009 | Washing Machines
Can I use color safe bleach in my new cabrio, and if so where do I put it?
According to the manual on pages 12 & 13.
1.
Place a load of sorted clothes into the washer. See “Laundry
Tips.”
■ Load evenly to maintain washer balance. Mix large and
small items. Items should move easily through the wash
water.
■ Load only to the top of the basket as shown. Overloading
can cause poor cleaning. Items need to move easily
through the wash water.
2. Pour measured powdered or liquid High Efficiency detergent
into the detergent dispenser. Always use the detergent
dispenser, and do not put detergent directly onto clothes in
the washer.
3. Add color-safe bleach (powdered or liquid) to this dispenser,
if needed. Be sure to match powdered color-safe bleach with
powdered detergent or match liquid color-safe bleach with
liquid detergent.
4. Pour measured liquid chlorine bleach into the liquid chlorine
bleach dispenser, if needed. Bleach is diluted and
automatically dispensed at the proper time during the wash
cycle.
■ Do not overfill. Do not dilute. Do not use more than 1 cup
(250 mL) for a full load. Use less with a smaller load size.
■ Follow the garment and the chlorine bleach
manufacturer’s directions for proper use.
■ To avoid spilling, use a cup with a pouring spout. Do not
let bleach splash, drip, or run down into the washer basket.
■ At the end of the cycle, a small amount of water may be
left in the dispenser. This is normal.
NOTE: Use only liquid chlorine bleach in this dispenser.
5. Pour measured liquid fabric softener into the fabric softener
dispenser, if desired.
■ Do not overfill. The dispenser holds 3 oz (94 mL), or a
capful of fabric softener.
■ The fabric softener is dispensed in the final rinse. If Extra
Rinse is selected, the fabric softener will be dispensed
during the Extra Rinse.
■ Do not spill or drip any fabric softener onto the clothes.
NOTE: Use only liquid fabric softener in this dispenser.
6. Close the washer lid.
7. Press POWER. This turns on the washer display.
8. Select a Wash Cycle. See “Cycles.”
9. Select the desired Modifiers. See “Modifiers.”
10. Select an Option, if desired. See “Options.”
11. Select Delay Wash, if desired. See “Delay Wash” in the
“Modifiers” section.
12. Press START. The wash cycle begins, and the display shows
the estimated remaining time. The lid will lock.
NOTE: If you do not press Start within 5 minutes of pressing
Power, the washer automatically shuts off.
The way that I read the manual, your color safe bleach would go in the detergent dispenser. Your liquid chlorine bleach would go in the bleach dispenser.
Please rate this solution
Aug 03, 2008 | Whirlpool Washing Machines
Bleach dispenser Kenmore Elite HE4t Model 45986400
is the machine level or is something plugged anywhere?
Mar 27, 2008 | Washing Machines
Fabric Softener Won't Dispense
The fabric softener dispenser is notorious for clogging. Liquid fabric softener is essentially a liquid form of wax. After a period of time it begins to gunk up the inside of the fabric softener dispenser. If you remove the dispenser drawer and look into the cavity, there should be a series of holes in the upper part of the compartment where water sprays into all the dispenser trays. These holes get gunked up and clogged and water will not dispense properly. As a result, the washer goes through a complete cycle, but the dispenser stays full. If this is the case, you can take some cotton swabs and/or toothpicks and clean these holes real good. It may be a bit meticulous, but it should take care of the problem. Post back and let me know if this helps.
Feb 11, 2008 | Maytag Neptune MAH6700A Front Load Washer
LG WM-2277HW Front Load Washer Logo
731 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
