Question about Maytag MGR5750 Gas Kitchen Range
Oven will not light however the broiler and stove top work. I confirmed that the ignitor is working. Any help as to what else the problem could be?
  • Maytag Master
  • 43,501 Answers
Here is a tip that I wrote that will help you with that problem...
The ignitor for your burner has failed...
Yeah it sounds crazy, but read this..
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
heatman101
Posted on Apr 27, 2010
My oven is not working The Broiler works and the stove top works fine but the oven will not heat and when you turn it on no gas comes out I tried turning it on and using a lighter but nothing happens
You gave us good clues in information!-- Thanks!
Most modern gas ovens have a device called a Glow Ignitor to light the burner.
If this ignitor has filed, it will NOT left the gas valve open-- (Good thing, right? :-) )
You say the broiler lights fine-- so let's observe something when the Broiler lights:
Do you see a bright glow near the Broiler burner?
(Usually toward the top rear of the oven--)
Well, you should see a similar bright glowing near the BOTTOM rear of your oven, for the main burner to light off-- If you do NOT see this glowing-- then you need a new ignitor-
You can remove the bottom burner cover, and dig deeper into the repair if you like-
But a new ignitor needs to be exactly like the failed one-- the safety circuit is very fussy about the exact same ignitor-- or it will not allow lighting-- even with a new 'generic' installed.
How deep do you want to go into this repair?-- Maybe it is time to call the service people into do the job?-- You can tell them that you think the ignitor needs replacing-- and approx. what will they charge you for the service call and the ignitor?
I hope this helped.
Mack B
Jan 27, 2011 | GE 30 In Freestanding Gas Range ...
Hotpoint oven model rgb745wea1ww oven doesn't light. Broiler and stove top work fine.
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Jan 04, 2011 | Hotpoint Ovens
Stove top and broiler work Oven won't heat
the way to check this is to first see if ignitor comes on or put an amp clamp meter on it. the ignitor needs to draw 2.8 amps or more to engage the gas valve. if it doesnt lite or draw any amps at all. check voltage to bake ignitor. it will be the ignitor most likely. but the gas valve or control could be bad.
Aug 04, 2010 | Amana AGR5835QD Gas Kitchen Range
Oven/Broiler doesn't work. Stove top works
Oven Problems Replacing the Igniter http://www.fixya.com/support/r4572625-oven_problems_replacing_igniter
heatman101
Jun 03, 2010 | Tappan TGFS26C Gas Kitchen Range
MGR5755QD CleanDesign Gas Kitchen Range: oven wont light. stove and broiler work fine. bad ...
heatman101
dfasfdas
May 17, 2010 | Maytag MGR5755QD CleanDesign Gas Kitchen...
Amana stove, oven igniter works but oven wont light
although the bake ignitor appears to be glowing, it probably does not glow with the intensity it needs to open the safety valve assy, VERY common problem, go aheadand replace the ignitor, this will correct your issue
Feb 09, 2010 | Amana ARGS7650SS Gas Kitchen Range
Broiler and top stove burners work, but oven doesnt
Your glowbar ignitor for the bake burner is bad.
Use the attached diagram to show location.
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5221257
Dec 26, 2009 | GE Adora JGBP87SEMSS Stainless Steel...
GSP31GER GE gas slide in oven dosent work
I think you missed a letter at the beginning of your model number. (it is maybe a JGSP31GER ?) I would first test the broil, and see if that works. (I would guess that it does) Most likely the oven ignitor (part number WB13K5058 ) needs to be replaced. It is located under the floor of the oven right next to the burner. It is a round electric coil thing about 4 inches long. If you want to confirm that this part is bad before replacing it, (and the broiler works) you can take the ignitor off the broiler and install it in place of the oven ignitor. They are the same part number. Of course now your broiler and self clean will not work unless you replace the broiler's ignitor. This is not too difficult, maybe a 3 on a scale of 1 - 10. Should be a Fix-Ya for your slide in range!
Jan 01, 2009 | Kitchen Ranges
Maytag MGR5750 Gas Kitchen Range Logo
140 people viewed this question
Top Maytag Kitchen Ranges Experts
Lawrence Oravetz
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
