Question about Kenmore 92022 / 92024 / 92025 / 92029 Electric Kitchen Range
Kenmore electric stove, the broiler in the oven stays on when the oven control is off and is flashing a f2 code, I did find that the code is from temp sensor out of range it was because the broiler stayed on and kept getting hotter what should i do, or check
    President:
  • 563 Answers
Hello.
What you need to do is open and shut the oven door quickly for a few minutes to help it less hot/decrease the temperature.
If you still get the error message, turn off the oven and turn it back on after an hour or half an hour.
Check if you still get the same message.
*Yes, that's right, its the temp sensor. usually it appears if you have preheat it more that 350 degrees F.
So the main thing here is that you need to cool it off first.
If that doesn't work, you need to get the temp sensor replaced.
hope it helps.
Posted on Apr 26, 2010
The oven beeped, the screen said F3, now the oven is locked. It smells like a hot wire
What does F3 mean on my Frigidaire stove when it sounds ...
www.shopyourway.com > Manage My Life > Questions
My Frigidaire range beeps and flashes F3. ... 790.92413202 and when I turn on bake or broil it just shows an F3 code on the screen what does this mean?
What does fault codes "F2" and "F3" mean on a Kenmore ...
I have a Kenmore wall oven model 911.41059591 that beeps and flashes F2 or F3 and shuts off. ... The "F2" and "F3" fault codes is most likely indicating an open oven ... Next, the control panel will need to be taken off in order to measure the ...
Oven error code "F2" and how to fix it ' AskGene.com
www.askgene.com/.../oven.../what-means-the-error-code-"f2"-on-your-o...
Mar 26, 2007 - The error code "F2" will be displayed along with a beeping sound if the
Jan 27, 2016 | Kitchen Ranges
Where are fuses in Kenmore stove C970
Stoves generally do not have internal fuses they rely on the house circuit breaker to protect the circuit. Some stoves have what is called a thermal fuse. These can trip when the oven or broiler has overheated. Some are located on the back panel and some are located on the top panel under the top of the stove. Since this is a smooth top model there may be one on the back panel. More than likely there is a problem with the oven control circuit possibly in the electronic control. The relays can go bad on the control and the oven will not work.
Oct 11, 2014 | Kenmore Electric Smooth Top Stove
My electric oven & broiler elements are not heating up when the they are turned on. kenmore model # 790.94422300
IF it is a electronic control look at the control panel when u turn it on see if it is flashing a F12 IF IT IS YOUR CONTROL IS NOT WORKING may need to call an appliance guy if its a clock style stove with a couple of knobs u turn for the time u may be in manual mode push the knob in to put it back on automatic also check your fuses
Oct 02, 2013 | Kenmore 40494 / 40495 / 40499 Electric...
I have a Kenmore Ultra Bake. Stove was on bake set to 375. Only the broiler element came on at full power. Tuning off oven did not turn off broiler element. Stove was to hot to move so I turned the braker...
Hi
F3-E2 Error indicates a loose/broken wire on the oven temp sensor or the oven temp. sensor itself is bad and should be replaced. To solve this issue test the oven temp. sensor, it should read between 1080-1120 ohms, if the rating is more then that and the door appears to be closing fine then it is the control board that is bad and should be replaced. Hope this helps...please post back for further assistance.
Daniel
Aug 01, 2011 | Kenmore 95002 / 95004 Electric Kitchen...
I am getting a E2 F2 code on my kenmore electric range model 95014102, pressing the clear button does nothing, I unplugged the stove and the code went out for a few days it is back on. What could be the...
The E2 F2 is an indication that the oven got too hot and shut down. If the oven actually got too hot the issue is most likely the main control board. If the oven did not get too hot the problem would be the sensor.
May 08, 2010 | Kenmore 95032 / 95034 Electric Kitchen...
Oven broiler will not go off., when i close oven
This is a control board issue. The contacts on the broiler relay may have welded closed. You options are to replace the controller, or disable the broiler relay output. The controller is the most expensive part of the range. The model numbers shown do not match a Kenmore stove, so I couldn't give you a better answer. Check on the back of the unit for a model number and go to Sears Parts site to find what you need. If the oven works but not the broiler you may be able to disconnect the output from the card and continue to use the rest of the range. I did this while waiting for my part to arrive. The Sears store should have a wiring diagram if you can't find the one that is usually found on the stove. Mine was in an envelope on the back of the unit, though I have seen them attached to the backside of the rear cover. Mine was just a quick connect and I pulled it loose, taped the end up and continued to use the rest of the range.
Jan 05, 2010 | Kenmore 95002 / 95004 Electric Kitchen...
KENMRE OVEN BROILER SHOWED CODE e3-f2 AND BROILER WILL NOT TURN OFF
Your electronic oven control has failed.)ERC) It must be replaced.
Jul 07, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Control screen flashes F2 and F3; now oven element won't heat.
All F3-E Codes - Oven Temperature Sensor (RTD) or Warming Drawer Defect - Replace oven temperature sensor (RTD).
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Feb 10, 2009 | Kenmore 91112 / 91114 / 91117 Electric...
Broiler won't turn off. Error code F-3
The broiler won't turn off even when you press the "Off/cancel" button? It sounds like the broiler control relay is stuck shut. The F3 code means the oven temperature sensor has failed, this probably happened because the oven got too hot when the broiler was stuck on. There is fail-safe thermal fuse that will blow if the oven gets too hot, so the oven won't melt down but you should leave the unit off so you don't blow the fuse.
To fix the relay, you will have to replace the oven control module. I think this is about $200 and not too hard to replace if you are somewhat handy. The temperature sensor is also serviceable, you can find parts at Appliance Parts Pros on the web. Hopefully you haven't thrown the range out yet, let me know if you need further assistance.
Nov 27, 2008 | Whirlpool RBS305PD Electric Single Oven
Kenmore 92022 / 92024 / 92025 / 92029 Electric Kitchen Range Logo
111 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Mike Carew
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
