Question about Video Game Consoles & Games
Pokemon Crystal internal bat.
My Pokemon Crystal's internal bat. has died. Will Nintendo replace it?
    Sergeant:
    Champion:
  • 427 Answers
Sorry to tell you but nintendo will most likely not replace it. But, they will probably repair it. Look up the phone number and send it to them.
Posted on Mar 24, 2008
SOURCE:
Pokemon crystal work when it wants and if it does the game freezes after about 10 mins
Well it might be thAt the battery inside of the game pack that saves your game data is dying then. Or starting to wear out on you so you could buy a new game pack then.
May 18, 2012 | Nintendo Pokemon Crystal
The game stops suddenly
Well its because the battery inside of the gamepack is dying thats nwhy same thing for pokemon yellow for me its a warning that the battery is about to die on you then.
Jan 05, 2011 | Nintendo Pokemon Crystal
When i save on Pokemon gold, silver, and crystal (for GBA) then turn if off then back on to load my game it says "the saved file is corrupted" of there is no "continue" button to push....
Well its because the battery inside of the gamepack is dead now. The battery inside of the gamepack allows you to save the game data is dead now so buy a new one then.
  • How To Replace the Save Battery In Pokemon Gold/Silver/Crystal ... 2q== play_c.gif www.youtube.com/watch?v=IJ_h6P1tF7010 min - 16 Apr 2010 - Uploaded by KMCMATT1
    How To Replace the Save Battery In Pokemon Gold/Silver/Crystal ... Warning: Replacing the battery can damage your game cartridge and ...
    More videos for game save replacement batteries pokemon ... »
  • Nov 15, 2010 | Nintendo Pokemon Crystal
    Can you save after the interal battery dies on pokemon crystal?
    No unless you guys replace the battery inside of the gamepack that allows you to save the
    game data then. Or buy a new one, one or the other.
    Oct 06, 2010 | Nintendo Pokemon Crystal
    Is there anyway to recover data? I went to play it one day and it no longer has a continue only new game
    No, the only way to stop this problem is to change the battery because it is dying or dead; this is causing the memory erases. What you need to do is take the cartridge and unscrew it and change the battery. Here is a guide to replace it: http://www.instructables.com/id/How-to-replace-the-battery-in-a-pokemon-goldsilve/ If you aren't good with soldering, I would recommend just buy a new Pokemon Crystal game.
    May 15, 2010 | Nintendo Pokemon Crystal
    Why wont the game save?
    What you need to do is take the cartridge and unscrew it and change the battery. When the battery dies, the file becomes corrupt and erases every time you turn it off and back on. Here is a guide to replace it: http://www.instructables.com/id/How-to-replace-the-battery-in-a-pokemon-goldsilve/ If you aren't good with soldering, I would recommend just buy a new Pokemon Gold game.
    Apr 02, 2010 | Nintendo Pokemon Crystal
    Is there anyway to recover data? I went to play it one day and it no longer has a continue, only new game
    No, the only way to stop this problem is to change the battery because it is dying or dead; this is causing the memory erases. What you need to do is take the cartridge and unscrew it and change the battery. Here is a guide to replace it:http://www.instructables.com/id/How-to-replace-the-battery-in-a-pokemon-goldsilve/If you aren't good with soldering, I would recommend just buy a new Pokemon Crystal game.
    Mar 28, 2010 | Nintendo Pokemon Crystal
    It freezes when i turn it on
    Well it might be a broken gamepack then to fix a broken gamepack you need to take it apart and check and see if you can find that specific part thats broken on the gamepacks internals or just buy a new gamepack like that then.
    Mar 15, 2010 | Nintendo Pokemon Crystal
    MY GAME STOPPED WORKING AND DOESN'T READS A GAME
    Sep 28, 2009 | Nintendo Game Boy Color Console
    Open Questions:
    Just purchased a TTX Tech wireless PS3 controller that comes with a USB key fob that connects to one of the front USB ports of my PS3 console. I have successfully synced it to my PS3 only issue I'm having is how drastically different the configuration is from the usual sixaxis controllers. I noticed between the 2 controllers there are 2 clear differences amongst them. 1 being the trigger buttons are not the same and that the circular circumference for the analog sticks are alittle bit different in size. Basically comparing the size of a 25cent coin to a 5cent coin. I'm assuming because of the analog having less of a left to right and or a up and down travelling distance due to the difference of having a smaller analog circle that it could very well change the sensitivity aspects in the game of choice (COD Black ops 2) but I mean the difference between the two controllers is beyond noticeable I've experimented with lowering the sensitivity level from what was set when using the sixaxis controller compared to when using the TTX Tech controller. For example using the sixaxis I'm set to 13 for my sensitivity but when switching to the TTX Tech to become even close to having the same feel and view while using it in comparison to the sixaxis i have had to lower my sensitivity level to an 11 or a 10 instead of the 13 and yet it still is quite noticeably different from my sixaxis controller. Also I've found that the right analog for the TTX Tech is extremely sensitive gently applying upward downward and also side to side pressure on the analog causes a significantly noticeable jump or jolt that seems to never differ in speed regardless as to what has been set for the sensitivity level in game settings. In a nut shell basically I'm asking if anyone else has noticed these things I'm experiencing and if there may be a configuration manual or program that could some how configure the TTX Tech controller to act more as if it were a sixaxis controller in the aspects of the analog sensitivities and responding timing. Yes of course a new controller with a different shape and or feel will make for a "getting used to it" experience which does generally occur after a time period of using said controller more and more often. I am more or less meaning whether or not the smoothness and or the rythem you would have with one controller be more similar with one another. If anyone is a gamer and has gone from using a normal typical original PS3 controller and unfortunately having it be no longer able to be used to play games and switching to the TTX Tech controller immediately afterwards I'm sure will know exactly what I am trying to explain. Appreciate any insight and or knowledge towards my inquiry. Thank you kindly for the assistance and of course take it easy or take it any way you can get it :)
    Oct 19, 2019 | The Video Game Consoles & Games
    Video Game Consoles & Games Logo
    Top Video Game Consoles & Games Experts
    Ekse
    Marvin
    Marvin
    Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
