Question about Hoover HCA391FFK Bottom Freezer Refrigerator
Freezer cold fridge warm
Hoover model hca391FFK freezeer cold fridge warm unit runs all the time
    President:
  • 2,468 Answers
Sounds like the evaporator in the freezer section is iced up and you need to see if the defrost section is working correctly,then as for the warm refrige side,it sound as if the vent damper door is frozen shut or the cold control in the refrige isn't opening it to let cold air into the refrige from the freezer,if its frozen take a hand held hair dryer and remove the vent grille over it and defrost it and then check to make sure the control opens and closes it as you adjust its control in the refrige
Posted on Apr 26, 2010
Why hoover fridge not cooling or freezing?
is it warm or hot to touch? no sticking defrost timer? if not then check the cold control tempeture thermostat, the thermistors, and the door seals, lastly may have a coolant problem, do any of the back copper tubes to the compressor feel cold to the touch
Feb 20, 2015 | Hoover Refrigerators
Hoover HCA 33 FSK
gp to repair clinic.com it sounds like the temp sensor or the or the defrost timer either way it probably isit defosting. The fan will run every time the it call for cold
May 29, 2012 | Hoover HCA390FFK Bottom Freezer...
I have a hoover HCA391FFK the freezer section works fine but the fridge dosnt get cold enough any more
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
First I would check cold control. Thats where you turn it off, if your temp is not warm. it can
be defective and not shutting off. If your temp is warm proceed with the following.
I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if FREEZER CONTROL is turned WARMER WHICH MAKES THE REF COLDER AND VICE-VERSA. SEE?
The ref. temp should be about 33-35
The Freezer temp should be 0 to 10 Any thing below these temps is overkill and a waste of elect
The higher the number you turn it up to is the coldest
But is probably a common defrost problem The ice build up
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
Make sure back cover is on the fridge. Some take them off and throw them away.
make one out of cardboard if its gone, using the holes of the old one.
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
If
you need more help go here:
http://www.applianceaid.com/procedures.html
MORE
TIPS AND TRICKS:
STOP PAYING FOR EXPENSIVE WATER FILTERS FOR YOUR REF. DO THIS====
http://www.fixya.com/support/r9962087-stop_paying_high_price_refrigerator
WATER SPLASHING IN FREEZER AT ICEMAKER
THE FILL TUBE IN BACK OF REFRIGERATOR CAN SLIP
AGAINST THE FILL RESERVOIR CAUSING A PARTIAL BLOCKAGE
OR BECOME CLOGGED WITH ICE.
REMOVE THE ICEMAKER AND INSPECT THE FILL TUBE.
RUN WATER IN TUBE TO ELININATE BLOCKAGE AND CHECK
TEMP IN FREEZER. IF TEMP IS BELOW 0 DEGREES, THATS
OVERKILL AND USUALLY A WASTE OF ELECTRICITY TO KEEP IT THAT COLD, NOT TO MENTION THE FILL TUBE FREEZING UP
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME AND GIVE ME YOUR TESTIMONIAL IF POSSIBLE, IF THIS WAS HELPFUL
ITWILL BE MUCH APPRECIATED.
Aug 24, 2011 | Hoover HCA391FFK Bottom Freezer...
The fridge and frezzer are not getting cold at all the lights are on and the is an alarm that keeps beeping, we have hoovered the coils at the back still no differance.
Turn the unit off using the interior switch and unplug the unit for 20 minutes. then plug it back in. With the unit turned turn the thermostat (cold switch) to somewhere in the middle, listen to see if the compressor is running.
If it is running, feel the copper tube coming out of the compressor.
If it gets warm, The Compressor is functioing. The freezer section will get cold first and then the cold air will flow into the refrigerator section.
Let me know if this helps.
Jan 06, 2011 | Refrigerators
Bottom Freezer not working (still cold) Top Fridge not cold enough>
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Nov 02, 2010 | Hoover HCA391K Bottom Freezer Refrigerator
We have a Hoover No frost refrigerator/freezer. There is no control for the fridge temperature which is now running very cold (it freezes drinks, etc.). What can I do to increase the temperature of the...
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
Apr 16, 2010 | Hoover HCA391FFK Bottom Freezer...
Fridge not working but freezer is working perfectly.It makes the usual humming sound after I switched it off and defrosted it but still the fridge didn't cool down.Any answers would be gratefully received....
try checking your evap fan motor if it is not running you will need to check to see if it is getting power if it is then you will need to replace the motor also check your settings make sure th freezer setting is not set over half way the freezer setting controls the air flow to the ref
Jul 03, 2009 | Hoover HCA391FFK Bottom Freezer...
FRIDGE COMPARTMENT NOT COLD ENOUGH.
If you have never defrosted it before, leave it off for a lot lot longer, doors open in a warm area. Is the fan working when you close the door ?(or hold the door switch in), if not, there could be a problem with the condenser fan), otherwise 90% of the time, they are frosted up internally, and because of good insulation, need time to "warm up" inside, in order to defrost
Mar 30, 2009 | Freezers
Fridge compartment not cooling ......freezer ok
verify is in the air vent to fridge isn't obtructed by food products also there's a vent in the the freezer that if obstructed no cold air comes in.
Apr 21, 2008 | Hoover HCA391FFK Bottom Freezer...
Hoover HCA391FFK Bottom Freezer Refrigerator Logo
444 people viewed this question
Top Hoover Refrigerators Experts
Charles T Nevin
Charles T Nevin
tom wright
tom wright
JONFRIDGEDOC
Level 1 Expert
Are you a Hoover Refrigerator Expert? Answer questions, earn points and help others
