Question about Dryers
I have a kenmore dryer about 3 to 5 yrs. old and its not putting out hot air, what would the problem be.
  • 45 Answers
Heating element
Posted on Apr 28, 2010
Frigidare dryer is leaving Waffle pattern left on clothes after coming out of dryer. Only waffle pattern is back wall of dryer what is going on? Frigidard infinity dryer 3 yrs old
Does it look like a scorch mark? The hot air inlet is usually near the top of the dryer and it would seem that the only time that something like that could happen is if the dryer stopped with clothes in contact with the hot air inlet. Dryer overloaded? Is the dryer vent plugged with lint.
The thermal fuse should blow if the inlet air exceeds 309 Degrees fahrenheit. Is the dryer cycle working properly. There should be a cool down .period before the dryer stops. If you have not cleaned the dryer vent pipes it would be a good thing to at least check.
Jul 13, 2014 | Kitchen Appliances - Others
The kenmore elec dryer is about 1.5 yrs old and isn't drying the cloths very well. took the cover off the back and checked to see if the coil heats up and looks like it does ( It gets red). it's...
Hi cdsca66...
Check and clean if necessary your vent hose.
If you vent hose "seems" to be clean then,try running the dryer with the vent hose off and see if the dryer is not running hot anymore.
Make sure your lint screen is in place and has no tears or holes in it and is still firmly attached to the frame.
If you are running too hot you are not moving enough air thru the system.
It could be that the fan blade is plugged up.
The problem could be a large lint ball build up in the center of the fan or a sock,thin pants,a pen,etc. that has gotten into the fan by falling down the hole where the lint screen is normally inserted.
You have to find the air restriction to solve the problem.
It also can be a loose or worn out blower wheel/fan.
Please take time to rate me.
Aug 21, 2011 | Kenmore 500 6952 Dryer
Dryer is only 5 yrs old. Started to blow cool air. Not heating. Vent was blocked from outside. Cleared vent, flab is open, but dryer still not blowing hot air. Is there a reset on this machine? Why...
There is a device in the circuitry for the heating element which shuts off power to the heating element when the dryer gets above a certain temperature which is ealsily reached with a clooged vent hose. This device, a thermal limit switch or thermal fuse, cannot be reset, it has to be replaced.
If you want to do this yourself, let me know -- if not, you will need to arrange for someone to repair the dryer. The device costs about $20 -- a service tech will probably charge up to $150 for the repair.
Charlie
Jul 26, 2011 | Kenmore 600 7965 Dryer
Thinking of getting either a Wpl LER7646jQ0 or Kenmore
I'll give it to you straight
Get the Kenmore. i work on all of them and i work on less kenmore
Jan 06, 2010 | Whirlpool Dryers
Our kenmore eliite HE4 gas dryer keeps shutting off after a few minutes of running no mattter what heat setting we put it on. On air dry mode it works. Is this a high heat sensor problem? The unit is 4...
You didn't mention if the dryer is getting hot.
If is getting hot, then shutting off, I agree with you.
If it is NOT getting hot, I would suspect the IGNITER ASSY
Dec 13, 2009 | Kenmore Elite HE4 Electric Dryer
My whirlpool dryer wont get hot
Does it heat up at all? If so, your vent may be clogged. First check the air flow to the vent. If it vents straight out from the laundry area, be sure it's got good air flow. If it ventys up inside the wall, you need to have the vent cleaned out for saftey reasons. If it does vent up, you could have a house fire. Or your safety t-stat or thermal fuse may be out. Call us for parts! 9728590929. Hope this helps you!
Aug 26, 2009 | Dryers
We have a Kenmore 70 series Electric dryer and it heats just fine and stays hot, air flow is good,(checked), however the clothes are not getting dry. My husband replaced the cord to the outlet from a 3...
Did the dryer get clothes dry in your old home with the 3 prong plug?
If so, id put the 3 prong plug back on it, and switch to outlet to a 3 prong...
Jul 10, 2009 | Kenmore 63942 Dryer
Have-kenmor-80-series-dryer-about-5-yrs-old-losess-flam-about-6-min-into-cycle attemps to relight no flam.
replace coil kit no 279834.coils will be found on top of burner, unplug wires, 2 screws remove bracket,easy fix part~ $20 .Hope this helps ,please rate my solution :)
420.. 20 min fix .hope thuis
Jun 27, 2009 | Kenmore 73952 Gas Dryer
Dryer not hot
Tht means that the element is not heating on.
You need to call a technician to test the element, the thermic sensor, and the control assembly.
The most likely is a defective heating element, that must be replaced.
Jan 31, 2009 | Kenmore 73952 Gas Dryer
Dryers Logo
Top Dryers Experts
