Question about IBM Computers & Internet
How do you remove the keyboard for a series 1400I(2621) thinkpad
  • 119 Answers
Here is a good place to start.
http://www-307.ibm.com/pc/support/site.wss/document.do?sitestyle=lenovo&lndocid=MIGR-4YRRG6
Posted on Apr 26, 2010
2 Suggested Answers
GeOrGeEtUk
  • 332 Answers
SOURCE: How do you remove the keyboard for a series
I think you would need to refer to your manual or have a Laptop technician do that for so as not to damage it yourself. They would charge a fee to do that also, not too much.
Best regards
Posted on May 08, 2010
How do I remove the keyboard on a IBM Thinkpad 1412
Hi There,
I'm a pro laptop repair tech. Go to this link, download the manual and study to remove keyboard.
http://www-307.ibm.com/pc/support/site.wss/document.do?sitestyle=lenovo&lndocid=MIGR-4HDPPV
Cheers
Jul 29, 2010 | IBM ThinkPad i Series 1412i Notebook
Best regards
May 08, 2010 | Computers & Internet
How do I replace the CMOS battery in a Thinkpad 1400?
Your CMOS battery is located up inside the case. It is fastened to the underside of the palm rest. You may be able to see it if you remove the battery, if I recall correctly. Most generally, you have to split the case to get at it. Do that carefully by removing the screws and prying the case halves apart.
Sep 19, 2009 | IBM Thinkpad I1400 2621 Planar TV...
Need to change bios battery in old IBM Thinkpad
You meen CMOSbattery as I understand. for removing or chnging it you need to disaasamble your thinkpad here is instuction go to pg 75 to see where is battery.
Aug 12, 2009 | IBM Thinkpad I1400 2621 Planar TV...
I want a ibm thinkpad i series 1412 vga driver
You need to check the type number on the service pad at the bottom of the laptop, if you cannot find the type, download both vidoe drivers, the wrong one will just not work.
· i Series 1400, 1500
(Machine Type - 2611)
i Series 1400, 1500
(Machine Type - 2621 and 2651)
Apr 15, 2009 | IBM ThinkPad i Series 1412i Notebook
Change of CMOS battery in IBM Thinkpad 1400 2621
This battery is hidden under the keyboard slightly up and to the right of center of the keyboard. To get it out is a pain.
Start with the computer sitting flat, lid closed, lid latchs facing you.. just like you were getting ready to open and use it.
Spin it around, rear ports facing you. Right above the external video port, on the right hand side, there are two screws, at a diagonal UP from the port itself, very close to the bottom edge of the LCD. Remove them. There is a small notch between the screws, using a small flat-blade screwdriver, pry up in the notch and pop the platic backing free from the rear of the laptop. DO NOT open it more than a small crack, you are just popping loose a small plastic tab. Open it too wide and you will lock it closed again or break the plastics when you open the LCD lid.
Spin the machine around again, and open the LCD carefully as far back as it will go normally. Find the Power Button. The Power button is to the far right of a plastic 'strip, with 4 other buttons on the far left. There is a small clear plastic strip overlying this button 'tray'. Find the small notch in the bottom edge of the clear plastic strip, use the flat-bladed screwdriver, and gently pry up, popping the plastic strip out of the tab holes in the tray. Under this plastic strip is a black adhesive 'strip' that has a house, magnifying glass, etc. markings on it, and 'i Series' or somesuch printed on it.
Using a razor blade, peel up the black adhesive strip on the left and right ends of the button 'tray'. You will find two small silver screws. Remove these. Then using your screwdriver, or as I did, a dental pick, *gently* pry up the entire tray from the BACK edge of the tray, and by lifting up the left side of the plastic tray. You will have to work it out from under the edge of the LCD bottom on the left side. DON'T yank on it, there is a small cable attached to the bottom of it. You will be able to rotate it toward you and roll it over, exposing the small latch holding the cable in place. Its a small, press-fit latch like what holds a keyboard cable in place. You'll need to work it open by lifting the left and right edges till the latch becomes loose. Pull the cable straight out of the slot, remove the entire plastic 'tray', and set it aside.
On the far upper right of the keyboard there is a small metal tab holding the right upper edge of the keyboard. Reach around to the back of the computer, right-hand side rear, find the little square thumb-notch, and pull it out. The latch on the upper right edge of the keyboard should retract. Now, while lightly pressing down on the keyboard, push the keyboard away from you. It should slide backwards and the front tabs on the front keyboard edge will pop out of the slots. Lift up the touchpad area, popping up the bottom edge of the keyboard, clear of the plastics, then pull the keyboard slightly toward you. It should pop loose all the way around. DO NOT yank on it, there are 3 small cables attached underneath. You wil need to lift the keyboard up enough to reach the cables and pop the lockdown tabs loose, then pull the cables straight out of the slots they are in. The cable slots are attached to the motherboard, the cables are attached to the keyboard.
Removing the keyboard will expose a flat silver panel underneath. There are 5 screws holding down the panel, 4 in a 'box' configuration on the left, and a single one on the right, and several slide-tabs around the edges. Remove all 5 screws, then slide the whole tray to the right, while lifting up. The entire tray will pop up, with the video card heatsink attached on the left-underside of the tray. Set this aside. Directly in the middle of the big hole you now have is the battery. Its smaller than a standard desktop motherboard battery, looks like a small silver button. Gently pry up on the bottom-left edge of the battery, very carefully or you will break the plastic clips holding it in place, and pop it out.
All done. Reverese order to put it all back together.
Feb 21, 2009 | IBM Thinkpad I1400 2621 Planar TV...
Thinkpad i1400-2621-480 bios does not recognise my new hard drive
The hard drive has to be fdisked and formatted on the laptop to function. If you don't have an internal floppy, I use an external USB drive plugged into the laptop to do the job.
Jan 23, 2009 | IBM Thinkpad I1400 2621 Planar TV...
Replace LCD screen
All modern thinkpads are similar, you start by taking apart keyboard and top cover, then you unscrew hinges and remove screen. Here is some movie:
Thinkpad LCD Removal
Removing Thinkpad 600 Series Display - Part 1
Replacing Thinkpad 600 Series Display - Part 2
IBM ThinkPad R40 -- Fixing the black-out LCD Screen
This is not an easy job, there is risk to cause further damage to your laptop if you do not have enough experience.
May 28, 2008 | IBM ThinkPad T60 Notebook
Computers & Internet Logo
27 people viewed this question
Top IBM Computers & Internet Experts
Computer Links
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
