Question about Denon DRR-M30 Dual Cassette Deck
Tape stuck cant get tape out and looking on internet for solution
  • 189 Answers
HELLO
Go to Audiokarma.org on the web. The guys on there are brilliant and I'm sure someone may have the answer. You will have to register to post your problems - it's worth a shot!
Posted on May 09, 2010
Remove stuck cassette tape
To remove the tape you will need to pull the whole unit out of the dash and disassemble it.
Jun 11, 2017 | Kenwood Car Audio & Video
STUCK VHS TAPE
If you know how to do this open the latch on the cassette when it stops and look to see if something got spilled into or on the tape itself.
If the unit only shuts off with this tape the cassette is the issue.
If you open the door on the tape (little square button to release the door also look (happens if you use same tape a lot and fast scan with it) to see if the bottom edge of the tape has curved waves in it--should be perfectly flat with no ripples at bottom edge of the tape.
Apr 03, 2012 | Televison & Video
My tape is stuck in the cassette player how do i
I've done this by using a small screw driver and gently prying up on the tape while holding down the Eject button.
Jan 31, 2010 | 1997 Buick LeSabre
Cant load tape
You probably have some paper scraps stuck in the path that the paper has to go thru.
May 07, 2009 | Sharp EL-1197P Calculator
UVW-1800 SONY VTR - s-reel error
Both these error codes indicate a problem with the supply reel motor.
The first code (02-058) indicates that the reel motor is drawing too much current, which could be caused by a bad motor, defective driver circuit, or even a bad tape. The second code (02-803) indicates tape slack, caused by the defective supply reel motor. FIRST thing to check would be a possible bad tape. Try different tapes and see if the problem persists. If it does, it may be time to find a technician.
Mar 16, 2009 | Sony UVW1800 VCR
Hp deskjet printer640c/colorcartridge no 49
sounds like either part of the tape that covers the cartridge (you did remove the tape right?) is still stuck on it and it didn't seat right. Was it harder (applied more force) to latch the new cartridge in place than the old one? If so then there is something either stuck on the new cartridge foot or nozzle face.
Another explaination is that the foot came off the old cartridge and is still in the printer. This happens some times. Examine the new and old cartridge carefully. Are they different? How?
Remove both cartridges and look at the emply holes where they were. See the metal pins? Is anything covering them? Remove any tape or pieces of tape carefully.
Jun 22, 2008 | HP Office Equipment & Supplies
Canon ZR 45 Won't Eject Tape
That would be the take up or supply reel fault. It may also be a mode position error. Try here for advice but I don't advise tackling this job without full service instruction manual for the deck. No idea of your country so try here first;
https://www.usa.canon.com/internet/portal/us/home/support/details/camcorders/support-minidv-camcorders/zr
Apr 15, 2017 | Video Cameras
Tape is stuck in VCR- Fast rewind and forward
It may need to be cleaned. Mechanical problems are one of the big problems with VCRs they use alot of mechanical moving parts and play for so long they fail. Plastic parts dont help much either. The pinch roller takes up the slack and is usualy the part that fails first because it constantly runs along the tape and builds a coating on the rubber so it doesnt grip the tape and pull it back into the cassette. If its not pulling the tape back in then it hangs up inside and you cant get the tape out. Fastforward uses the reels to pull the tape not so much the roller. Try and stop 2 times then fast forward then eject the tape. Try and eject the tape while its fastforwarding so it doesnt do anything else. Sometimes machines will unload after its been in fastforwad a while then it will eject. You will hear a change in the sound when it unloads, you can hear the mechanical arms move the tape in and out of the cassette. Thats when you eject it. You cant really clean it till you get the tape out. YOu can clean the pinch roller with fingernail polish or paint remover. It is a wheel inside it looks like a black tire. It pinches the tape against the capstan arm this is why it developes a film or a shine on the rubber making it slip.
Apr 04, 2006 | JVC HR-J461MS VHS VCR
Denon DRR-M30 Dual Cassette Deck Logo
176 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
