Question about Philips Audio Players & Recorders
Need to open up philips home theatre subwoofer
Hi i have a philips home theatre system with dvd player- HTS3545 and i want to open up the subwoofer since the wire is cutoff and i want to fix it. Please assist.
CLUEPATEL
  • 138 Answers
SOURCE: HOME THEATRE SYSTEM
I think you must change the settings and try it out! it will make a great change.
Posted on Dec 08, 2007
SOURCE: Subwoofer for Teac AG-D8800 Receiver
To tell you the truth, if you want to upgrade, upgrade the speakers. Speakers are the single most important component to good sound.
The key word is efficiency...
As a professional sound engineer I can tell you this: wattage, as used as a comparison tool, is nothing. Speaker sensitivity is the important spec. Note this. A speaker that is rated at 300 watts, but the sensitivity is rated at 90 db is actually considerably lower than a speaker rated at 100 watts but the sensitivity is 94 db. This also means you do not have to spend as much money for an amplifier that has a high wattage rating.
Things like frequency response, etc are mildly important, but as I suggest to anyone is how the sound is to you. When making any audio purchase, take music you are familiar with...
jeff
Posted on Feb 05, 2008
SOURCE: PHILIPS HTS3450 DVD HOME THEATRE SYSTEM NO SOUND
quiero saber como puedo ecualizar el sonido con el control manualmente
Posted on Oct 30, 2008
  • 33 Answers
SOURCE: cant wire theatre system right,only get surr. on dvd
Do you have a High Def cable box and Tv? if so you would use and HDMI cable from your cable box to your tv, then run an optical audio or coax audio from your cable box to your surrond system. Depends on which plug you have on both for the audio portion.If you dont have HD tv than you would run cable wire from cable box to tv then run red and white audio from cable box to surround system, to listen to it you would select aux channel.
Hope this Helps.
Posted on May 05, 2009
  • 9 Answers
SOURCE: my philips dvd player 5.1 have female ports at back side for audio but i have the sound system of LG which has simple naked wire to connect .
Philips DVP 3256 has 6 outputs which takes in RCA connectors
Altec lansing VS3251 has 3 STEREO outputs.
Buy 3 nos of STEREO (female) to RCA (male) cables
1. Connect the Altec's green wire to first stereo-to-RCA cable. RCA ends to DVP 3256's Front left and Front right
2. Connect the Altec's black wire to second stereo-to-RCA cable. RCA ends to DVP 3256's Rear left and Rear right
3. Connect the Altec's orange wire to third stereo-to-RCA cable. RCA ends to DVP 3256's Centre/Sub woofer. Interchange RCA ends if the Subwoofer sounds dull.
Good Luck
Posted on Jun 23, 2009
How do I connect a new dvd reader with a Panasonic SB-WA340 active subwoofer?
Of the Phillips is not a home theatre system them you can but you will have no volume co trol of the sub. If it is the alot of philips home theater in a box (htib) use special plugs...you would need to change the cable end of the sub to a compatible plug.
Aug 23, 2016 | Panasonic Audio Players & Recorders
RECENTLY I HAVE BOUGHT A PHILIPS HOME THEATRE MODEL - HTS 3265 . ONE DAY I WANTED TO PLAY STAR WARS MOVIE DVD INTO IT. BUT NOT OPERATING.IT IS SHOWING REGION AND STOP PLAYING. PLEASE GUIDE ME FOR THIS...
HI,
ur dvd player has region lock . it will not play all the disk. check the DVD OF STAR WARS MOVIE which region it belongs. jus try the following not sure is it work or not
Open the tray. Press 99990 on the remote.
by doing this ur dvd player will become region free
then insert ur dvd and try.
for region 1 and region 2 code is 99991 ,99992 respectively.
feel free contact through fixya.
ok
Dec 21, 2010 | Philips HTS-3565 Theater System
I have a Philips Home Theatre System, model HTS7200 which showed 'unknown disc' when I put discs inside.
hi I have a Philips dvd touch screen HTS7200 the lights on top for volume and play are not working ,the try is not opening ,there s no sound coming out thanks
Dec 17, 2010 | Philips DVDR3380/05 DVD Recorder
I recently bought Philips DSP 2500 Home Theater ... i dont have a cd player nor any dvd players. i want to connect it to my pc or my cellphone through aux .... so any sollution 4 this .... m planning 2...
hi! i am the computer expert i will solve your problem , just buy 4nos. 3.5mm jack(without wire connected) . Buy 3meter wire and solder it with one for pc and other 3 for the home theatre.
For more information contact: athibanbirla@yahoo.in, billa_2010@rocketmail.com, rathiban1998@yahoo.in, sachin_vvb@in.com, Ph. no +9104522381424 .
Got It
Oct 25, 2010 | Philips MMS 460 - PC multimedia home...
Corrupted Firmware on Philips HTS3555 Home Theatre System
Only posibility is finding a service shop that services Philips....
Mar 23, 2010 | Philips HTS3544/37 Theater System
Wrong region
Hi , The reason for the error message is because your DVD player is set to one specific zone. The below procesure will open the DVD player to play all zones.
TURN ON THE PLAYER
PRESS OPEN/CLOSE
USING REMOTE PRESS STOP-7-3-4-4-6-6
YOUR REGION AREA WILL APPEAR. PRESS "0" TO UNLOCK (OPEN the DVD player to ALL zones) ALL, THEN WAIT. INSERT YOUR DISC. Hope this helps. Let me know the status. Thanks, Mike
Nov 03, 2008 | Audio Players & Recorders
Philips Home theatre system HTS3000
try to clean the lens of your player with the cd lens cleaner available in the computer store or appliance store.
Jul 20, 2008 | Audio Players & Recorders
I am missing some parts
Jvc home theatre system cable that connects the the bub and the dvd
Jul 04, 2008 | JVC TH-M606 System
Phillips LX3600 Home Theatre
Power up the set and open tray in DVD mode.
Press <9999> follow by <X> buttons on the Remote control.
where x = numeric 1 to 6 denoting the regions below:
Then show your region on TV
1 = USA
2 = Europe
3 = Asia Pacific
4 = Australia, New Zealand, Latam
5 = Russia, India
6 = China
0 = Code Free
This is taken from the original service manual for the reciever
Jan 27, 2008 | Philips LX3600D System
405 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
