Question about Hitachi 57SWX20B 57" Rear Projection Television
Need resistor value for RK62 on DP2X board for 57SWX20B
Resistor is burnt and cant see colors. Anyone know the resistor value for RK62 on DP2X board near the green convergence connector.
Complete schematic available at
http://www.eserviceinfo.com/
Posted on Nov 23, 2008
I purschased the schematics for this unit and found the RK62 is a 2.2Ohm 1W 5% resistor. Replaced RK62 and the two STK-110s with 160's. Performed a manual convergence in dynamic mode and dusted off /clean the 3 projector guns. Works like a champ! Total cost $100. Thanks to this website it saved me from having to purchase a new Samsung 1080p with 120mhz refresh rate. On 2nd thought ...
Posted on Mar 25, 2008
  • Hitachi Master
  • 8,617 Answers
RK62 is a 2.2ohm 1 watt metal oxide resistor hitachi part number 0700054M any 2.2ohm 1 watt resistor will work although it does have to be metal oxide(flame resistant) for safety purposes.
Posted on Mar 24, 2008
R47 resistor is blown on Neff S5453X0GB/07 control board. I can't make out the value as it is badly damaged - anyone know the correct value so that I can replace it (TY7 is blown as well!).
HI.We cannot really but identify the correct resistor value unless we can identify or determine the color coding on the resistor.Each color has a corresponding value and tolerance as well.If you can't indentify the color coding then you can refer to its diagram usually printed out on the side of the control board or near thecontrol board.We cannot but cannot give a guess value unless color coding is given.Thank you for choosing FIXYA.
Aug 27, 2011 | Dishwashers
I need a picture of a 1987 porsche speedometer circuit board, one of the resistors is burnt on the board attached to the speedometer, and i cant deturmine the value of the resistor, by its size its a half...
The color stripes on the resistor should tell you.
If it does not have colored stripes, it is a diode or something, and not a resistor. Find another the same color, and measure it with an ohmmeter. Trial and error works if you start with one having greater resistance.
Sep 17, 2010 | 1987 Porsche 944
I got this one dead. There is a burnt resistor on the main circuit board ( the one with the on/off sw). Would anyone know what value it could be.
You can determine the resistors value by reading the color code bands that are marked on it. The following picture is an example of the color codes and there values.
To show you how to read the color codes on a resistor, I am including a link to a video that will explain how to do this easier than I could probably explain it.
I hope this helps you in solving the problem. If you need further assistance please feel free to ask.
If you would not mind, please rate my help. I would greatly appreciate it. Thank You
Feb 15, 2010 | Fellowes 3011001 Shredder
How do I locate resistor values?
Click HERE to download service manual copy for free. Download all 12 files and unzip with winrar to get pdf file.
Hope this will help you to find out required resistors value.
Oct 28, 2009 | Hitachi 43UWX10B 43" Rear Projection...
WILL NOT TURN ON
Sir;
friend of mind had the same model # and he give me the color band for the resistor
Nov 18, 2008 | Yamaha HTR-5560 Receiver
Kds vs-f14
There is usually an identical resistor somewhere else on the circuit board, so if you cannot read the colors of the burnt one, you can read the colors from an identical resistor on the same board. If you just replace the resistor, it will probably just burn out again or damage another component, you have to find the cause of the resistor burning out, most likely an electrolytic capacitor failing. Look for bloated or seeping capacitors and replace those as well. Also look for broken or burnt toroid coils.
Jul 15, 2008 | BenQ FP731 17" LCD Monitor
65xwx20b
Is this a Hitachi set? If so then check the model number and be sure it's right.
Dec 05, 2007 | Televison & Video
Resistor ohm values??????
RK42 = 2.2 , RK46 = 1.5 , RK58 = 3.3 , RK52 = 1.8 , RK 50 = 2.2 , RK54 = 1.5
Aug 28, 2007 | Hitachi 53UDX10B 53" Rear Projection...
Hitachi 57SWX20B 57" Rear Projection Television Logo
316 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
