Question about Ricoh 4506 Copier
How do I set the fusing unit correctly? - Ricoh 4506 Copier
    New Friend:
How to fix the Error: "Set the Fusing Unit correctly"
Ricoh Aficio SP C411DN & C410DN Color Laser Printers
1. There is a short Wire Jumper (color: black or white) on the inside of the main electrical connector of the Fuser Unit.
Note: These procedures can be done without removing the outer plastic housing of the Fuser Unit.
2. Press the side clip (or tab) and first pull the tab end of the large connector plug from the main housing of the Fuser Unit.
Warning: The connector plug wires are very short -- it extends a maximum of about 1 inch (or 2 cm) from the main housing of the Fuser Unit.
3. Use a small screwdriver and gently remove the small white connector that the Wire Jumper is plugged into.
Warning: Try to remember the correct orientation that this small connector is plug-in.
4. Use a small screwdriver (or a small flat blade) and gently raise the small tabs on the front of the small connector, while pulling gently on each end of the Wire Jumper.
Warning: Do not remove Wire Jumper forcefully by pulling.
5. Make sure that this Wire Jumper is plugged into the same pins as the one on the old Fuser Unit that is being replaced. There are only three pins that the jumper can plug into.
6. Reassembly the Fuser Unit by plugging in the two connector that were removed.
7. Replace the Fuser Unit into the Ricoh printer and secure properly.
8. Power on the printer -- it should start-up and go to the ready state without any errors.
9. The END.
Posted on Jul 15, 2017
I want to make the machine cloning works
  • Fusing warm-up trouble
    • Detected temperature of the heating roller temperature sensor (TEMS) does not go up a given range of temperature even after a lapse of given period of time at warm up. • The warm-up is not completed even after the set period of time has elapsed after the warm-up is started. • Less than the predetermined temperature of the heating roller temperature sensor (TEMS), even after a predetermined period of time after warm-up is complete.
    • 1 Check the fusing unit for correct installation (whether it is secured in position). 2 Check the open/close operation of the right door. 3 Check the fusing unit, DCPU and PRCB for proper connection and correct or change as necessary. 4 Replace the fusing unit. 5 Replace PRCB. 6 Replace DCPU.
Nov 25, 2014 | Konica Minolta bizhub Office Equipment &...
Error cs548 in ricoh mp c4500
Fusing unit rotation error
The fusing belt sensor does not detect change in the actuator for 0.5
seconds after the fusing/paper exit motor has turned on.
* Defective fusing/paper exit motor
* Deformed actuator for the fusing belt sensor
* Defective fusing belt sensor
* Broken connection between IH inverter and IOB
* Incorrectly set fusing unit
1. Check if the fusing unit is correctly set.
2. Check or replace the actuator for fusing belt sensor.
3. Replace the fusing belt sensor.
4. Replace the IH inverter.
5. Check the connection between IH inverter and IOB.
Jul 14, 2014 | Gestetner DSm645 Digital Imaging System
Fusing unit is not set properly
This is a common problem on older ricoh with high counts the unit has a connector at the back to receive the fusing unit the connector on the fuser may have bee bent out of position and is therefore not contacting the unit correctly check the fuser connector is not damaged. also if there have beed jams sometimes paper can get stuck in the contactors also check in the receiving contact that the unit is not knocked out of place.
Feb 17, 2012 | Ricoh Aficio 450 Copier
C-3721 error is displaying. How can I fix it?
Fusing abnormally high temperature detection (heating side)
Check the fusing unit, PRCB and DCPU for proper connection and correct or change as necessary.
Change fusing unit
Change PRCB
Change DCPU
Jun 28, 2011 | Konica Minolta Bizhub c203 Copier
Getting error: set fusing unit correctly on Ricoh Aficio SP C410DN. Have just changed thermister in fusing unit.
Take the unit out and install it again, making sure it is in all the way and sitting correctly. Then reset the machine and see if the error goes away.
Nov 10, 2009 | Ricoh Aficio SP C410DN Laser Printer
Problem replacing fusing unit for a Ricoh Aficio SP C411DN
Look in your owners manual for the set of reset keys you ppuch to reset the error in the machine. Can't tell you much other than it is a sequence like holding POWER button and 1 or 2 other keys for so many seconds. Have you tried to ask the question at their website?
Here is the location for the manual
Jul 15, 2009 | Office Equipment & Supplies
Konica minolta 2490mf
18H: Heating roller warm-up failure
2 Check the fusing unit, DCPU1, and PRCB for proper connection and correct as necessary.
3 Check the lever of the safety switch and correct as necessary.
4 Change the fusing unit.
5 Change PRCB.
6 Change DCPU1.
Jun 22, 2009 | Konica Minolta magicolor 2490MF Laser...
Error c3921 konica minolta c451 error c3921 not known what to do
C3921: Fusing sensor wire breaks detection (Center of the heating roller)...
• At the warm-up stage, the heating roller
thermistor/3 voltage does not decrease by
predetermined steps (temperature rise)
within a predetermined time.
upper right door.
Check the fusing unit, IHPU, PRCB and
REDB for proper connection and correct or
If that check still give you error code 3921
Change fusing unit
Mar 16, 2009 | Konica Minolta bizhub C450P Laser Printer
Error Message C3451
It is a fuser error.
Try resetting. To reset a Rank A error follow these steps:
1. Turn OFF the Main Power Switch.
2. Turn Main Power Switch ON while pressing the Utility/Counter key.
3. Touch [Trouble Reset].
4. Check to make sure that [OK] is displayed and the it has been reset.
5. After turning off the Main Power Switch, turn it on again more than 10 seconds after and check if the machine starts correctly.
If the error recurrs then do the following:
1 Check the Fusing Unit for correct installation (whether it is secured in position).
2 Check the Fusing Unit, PWB-M and PU1 for proper connection and correct or change as necessary.
3 Change Fusing Unit
4 Change PWB-M
5 Change PU1
Oct 02, 2007 | Konica Minolta bizhub C250 All-In-One...
Ricoh 4506 Copier Logo
541 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
