I have a Kenmore Elite Dishwasher. The water comes in and gets drained properly but the spray-arms don't seems to turn. I have cleaned the mesh but no change. Some people with similar issues have suggested replacing the impeller --- Is that true ? if so, how do I replace it. Any suggestion would be appreciated.
  • 3 Answers
Food has made it through the mesh screen and is clogging the holes that spin the spray arms. You should be able to screw it off with lockjaw pliers and use water to try and flush the food out in a reverse manner. If that does not work use a firm slim wire to poke into the holes to free the food. If your still not having luck, buy a new sprayer. If you have disposed of the appliance books, the dealer should have helpful info about procuring manufacturer replacement part.
Posted on Dec 27, 2008
    President:
  • Washing Mach... Master
  • 2,651 Answers
You can replace the impeller, it requires purchasing the part, removing the motor/ sump assy from the d/w( or uninstalling the d/w and flipping on its back) the motor does separate form housing with 1 screw and a twist. new part(s) are installed and reassemble,
Posted on Mar 24, 2008
Dishes come out dirty like trap needs tobe cleaned kenmore 565
Hi
If you are noticing that the dishes are not clean, then there are a few things to check for. Check the soap powder if it's kept in a dry environment. Also try replacing the powder with something like a gel or liquid. Next thing to check for is the water pressure and fill valve. Check if the water is filling in and the spray arms are throwing the water with enough pressure. Try and listen to the sound if you hear a proper spraying action sound.
If it seems as a low water pressure then check the fill valve. Now, check if dishwasher is draining the water or not. While the dishwasher is working check whether the dishwasher is draining and there is not much left out water after the cycle is complete. Try cleaning the spray arm with a soft brush. The water temperature plays a major role in cleaning of dishes. The temp should be between 125 and 150 F for dishwasher to clean the dishes.
Hope this helps... Please post back if you need more information.
Daniel
May 18, 2011 | Kenmore Dishwashers
NO Clean Dishes
dear sir this may be the problem  Dishwashers usually run on 115-volt or 120-volt power. The water they use comes directly from the water heater, and wastewater is drained into the sink's drainpipe. The dishwasher is not connected to the cold-water supply. For best dishwashing results, set the temperature control of the water heater to no less than 140 degrees Farenheit. Water cooler than this usually doesn't get the dishes clean, unless your dishwasher is a newer model that preheats incoming water. The water shutoff for the dishwasher is typically located below the adjoining sink.
Caution: Because the dishwasher is connected to both the plumbing system and the electrical system, you must consider both systems when working on this appliance. Before doing any work on the dishwasher, make sure the unit is unplugged or the power to the unit is turned off, and remove the fuse or trip the circuit breaker that controls the circuit at the main entrance panel or at a separate panel. Shut off the water supply to the dishwasher at the shutoff in the basement or crawl space under the kitchen.how-to-repair-a-dishwasher-1.jpg
thanks..................................
Sep 11, 2008 | Kenmore 24 in. 17482 / 17484 / 17489...
Dishwasher spray arms don't spin & spray water
Check that the water pumped on arms has enough pressure.
Aug 15, 2008 | Kenmore 24 in. 17482 / 17484 / 17489...
Kenmore Dishwasher takes excesive amount of time to run, and dishes are not that clean and dosent seem to dry very well
Hi
If it seems as a low water pressure then check the fill valve. Now, check if dishwasher is draining the water or not. While the dishwasher is working check whether the dishwasher is draining and there is not much left out water after the cycle is complete. Try cleaning the spray arm with a soft brush. The water temperature plays a major role in cleaning of dishes. The temp should be between 125 and 150 F for dishwasher to clean the dishes. Hope this helps...
Daniel
Mar 22, 2011 | Kenmore 24 in. 17362 / 17364 / 17369...
For 6 mos. now, my dishwasher has begun to leave this white filmy, cloudy residue on all my dishes. It has ruined calaphon utensils and glasses I have had for 14 years. The detergent has always been the...
Hi
If you are noticing that the dishes are not clean, then there are a few things to check for. Check the soap powder if it's kept in a dry environment. Also try replacing the powder with something like a gel or liquid. Next thing to check for is the water pressure and fill valve. Check if the water is filling in and the spray arms are throwing the water with enough pressure. Try and listen to the sound if you hear a proper spraying action sound. If it seems as a low water pressure then check the fill valve.
Now, check if dishwasher is draining the water or not. While the dishwasher is working check whether the dishwasher is draining and there is not much left out water after the cycle is complete. Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. Check the drain hose for any visible clogging, remove if present. If no visible lint is present then remove then turn off the dishwasher and remove the drain hose and check for any visible clogging. If still not visible then the drain filter or drain pump is clogged and you'll need to clean the drain filter and drain pump. Hope this helps......
Daniel
Feb 02, 2011 | Kenmore Elite Stainless Steel 24" BuiltIn...
Hi
Daniel
Jan 25, 2011 | Kenmore Dishwashers
Kenmore elite dishwasher leaves food particles on dishes
If someone is putting dishes in the washer and obstructing the spray ams that would cause food to stay on dishes. After loading dishwasher and pushing in baskets make sure the spray arm doesnt hit any of the dishes causing them to not clean properly. If that doesnt work or is definately not your problem try removing the spray arm and seeing if it has food inside of it. Some times they get food build up in them and need to be flushed out.
May 12, 2009 | Kenmore 24 in. 17482 / 17484 / 17489...
No clean dishes
Internal filtersEvery dishwasher has some type of filter to keep large food particles and foreign objects away from the pump assembly:
  • Most modern dishwashers have self-cleaning filters that don't need any routine cleaning.
  • Some have filters in the bottom of the dishwasher that you need to periodically clean. You don't need any tools to remove the filter, and cleaning it is easy. Consult your owner's manual to determine which type you have and its maintenance requirements.
If your filter is clogged, it may be causing the cleaning problem.
Drain valve
Some dishwashers have a valve (or gate) that should open only during draining. If debris lodges in the valve, it can't close properly, so water drains out during the wash cycle. Most dishwashers drain into the garbage disposer. If yours does that, listen for water flowing into the disposer during the wash cycle. If you can hear it then, the drain valve may be clogged.
Spray arms
There's a spray arm at the bottom of your dishwasher--it may have a tall spray tube mounted to the center of it. There may also be a spray arm located directly beneath the upper rack of dishes and/or above the upper rack.
If debris is blocking the holes in the spray arms where the water comes out, it could cause cleaning problems. Regularly inspect each of the spray arms and clean out the holes as necessary.
Detergent cups
Dishwashers don't perform their best if detergent is introduced only at the beginning of a cycle, so add detergent to both parts of the cup.
If the detergent cup isn't opening, see the "The detergent cup doesn't open" section, below.
Note: Dishwashers are usually wired directly to the home’s electrical system. To disconnect the power, switch off the circuit breaker or remove the fuse for the electrical circuit the dishwasher is attached to. Try to turn the unit on after disconnecting the power to be sure you were successful.
CAUTION: If you’re not sure you’ve shut off the power properly, DO NOT CONTINUE. Call a qualified appliance repair technician to complete the repair.
Sep 12, 2008 | Kenmore 16602 / 16604 / 16609 Built-in...
Dishes not getting clean
brittgee, there has been a number of service flashes on this model. One that has to do with the upper spray arm assy. Complaint is poor washability; gritty glasses, food redeposited on glasses, especially in the corners. They redesigned the upper spray arm to improve water spray to all corners of the upper rack. The new part number is 8269022. They also redesigned the third level spinner for more consistant rotation and better washability. This was also under a service flash. Part number.8193768. Other reasons for poor wash would be; low water temperature, rinse aid disp. not working, loading etc. Catriver...post back.
Nov 25, 2006 | Kenmore 24 in. 15933 Built-in Dishwasher
Washing Machines Logo
51 people viewed this question
Top Washing Machines Experts
