Question about Brother HL-4040CN Laser Printer
What does fuser end mean? and what is the fuser
The fuser is actually the "hot" part of laser printers. It is the roller responsible for "melting" the toner power into the paper fibers thereby making the toner/ink stick to the page....
Posted on May 06, 2010
  • 4,041 Answers
Hi there
The Fuser is the ink powder that is in the printer, you may need to buy a new one as it may have run out.
All the best Pineworks
Posted on Apr 26, 2010
What does E005 mean?
The error code means that fuser cleaning web is about to run out or has run out. The fuser cleaning web cleans off the upper fuser roller (the hot one) and it also lubractes the roller. Most of the time when it runs out it starts to ruin the upper fuser roller. The best thing to do is to have the web replaced and the counter rest. If you just rest the counter, you may end up causing my damage to the fuser unit. Good Luck
Apr 10, 2012 | Canon imageRUNNER 400S Copier
There is a warning said : " fuser unit end". What is the problem for that printer HL-4040CN? Even after I changed the drum unit and belt unit, there are still 2 warnings appearing to ask for...
first you are talking about the FUSER END message that means you have to change the FUSER and as for the DRUM and BELT you have to RESET the TIMER to tell the printer that it has been changed as well as for the FUSER those are consumable parts they have a life and the printer is programed to tell you to change them after so much copies.
Jan 05, 2011 | Brother HL-4040CN Laser Printer
Error c-0510 shows on screen
Code C-0510 means a low fuser temperature. Most probable cause for that - the fuser lamp is probably defective. Try first to clear the error code (if the lamp is close to its life's end the code may pop up after a long print) so do this: power machine off; turn on the machine with the stop key held down; turn off, then on again. If this doesn't fix it then you need a new fuser.
Jul 05, 2010 | Konica Minolta bizhub 350 All-In-One Laser...
My copier displays the error code U4 what does that mean and you can't get passed that.
u usually stands for user so its something u have done,perhaps one of the doors left open.
Mar 26, 2010 | Xerox Office Equipment & Supplies
50.9 FUSER ERROR
The fuser is the part that melts the toner onto the page, the error is thrown by a sensor which monitors the fuser, powering off unplugging and waiting for the fuser to cool (about 25 minutes, dont test it by touching it) before turning back on the printer will fully reset the sensor and may get you going again however this wont fix a fault with the fuser. However the fuser is a consumable which means they can be purchased and fitted by the end user (Not cheap parts), I always recommend that you users buy from the manufacture as they will stand over any item they sell you plus advise on instalation and problems however check prices on-line first and make your own call
http://printertechsdotcom.stores.yahoo.net/hpcola26fune.html
Oct 05, 2009 | HP Color LaserJet 2600n Printer
WORN FUSER? WHAT DOES THIS MEAN PLEASE
that means there is a fuser unit back side of u r printer this is the main unit where printing happens actually. I think there may be problem with fuser unit...may be paper jam or sensor problem..replace the fuser unit
Jul 06, 2009 | Epson Aculaser C1100 Printer
Kyocera FS-4000DN, CALL SERVICE 6030:0159631
this error indicates a problem with the fuser unit.
if you are an end user, you will have to check warranty status with you nearest service agent and have the fuser replaced free or get a quotation if it is out of warranty
Mar 09, 2009 | Kyocera FS-4000DN Laser Printer
RESEAT FUSER
Hi G,
99% of the time the error is the fuser. Either it is damaged, or just not locked in place, and with power off, reseating it will fix the error. Since you just replaced the fuser, I guess the question is did you do it because it was also giving this error, or because it reached EOL ( end of life ).
If it was for EOL message, I would try reinstalling it. If the "reseat fuser" error goes away, but comes back with the new fuser again, then the new fuser you purchased is defective and should be returned or exchanged.
See the information below to correctly troubleshoot your issue.
The following steps are the troubleshooting steps that should be followed for error code 010 397.
First, the definition of the failure is <IOT Fuser Failure>, and means a Fuser Error is detected.
1) With power off, reseat the fuser by physically removing it from the printer, then reinstalling it and locking it in place. Turn the power back on. ( if the error is still present, proceed to step 2 ).
2) If reseating the fuser did not resolve the problem, Replace the fuser with a known good fuser.
( if problem is not resolved, proceed to step 3)
3) Replace the LVPS ( low voltage power supply ). ( if problem not resolved, proceed to step 4 ).
4) Replace the PWBA MCU ( printed wiring board assembly - machine control unit ).
END of troubleshooting.........
In most cases, the fuser itself is the problem. If you tried to reseat or replace the fuser while power was still on, the LVPS could have been damaged just as if there were an electrical storm.
Hopefully this helped.
Oct 28, 2008 | Dell 5100cn Laser Printer
I have a xerox 5016 copier ,
On this model sometimes the plugs on the connectors go bad.
They arc and will not connect good. Sometimes the ends have to be clipped and new pins male and female have to be crimped back on, replacing them on the machine part wiring connectors and fuser rod ends. this fuser kit is a part that is availiable at xerox.
A bad thermistor can cause this type of problem. If the machine overheats, the fuser triac pack can cause over heat problems as well.
On overheats the fuser fuse needs to be replaced. Do not replace with nothing else but a Xerox fuse, this is a safety device. Very important.
Otherwise place a service call to have this area repaired by xerox.
Oct 23, 2008 | Xerox DocuColor 12 Printer
What does j2 mean on a xerox work centre xd 100
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}H4 is a power failure code. To reset the errorplease press in the following order:
CLR - AUTO - CLR - AUTO
(this puts the unit in tech mode).
Enter 14 (as if asking for 14 copies)
Press "PRINT"
Your unit should reset itself and start working
Feb 19, 2008 | Xerox WorkCentre XD100 All-In-One Laser...
Brother HL-4040CN Laser Printer Logo
213 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
