Question about Samsung SlimFit TX-S3082WH 30" TV
My TV is death
I cannot see anything on screen cannot hear sound nothing works just when turn ON for 2 sec. line middle of the screen and after this is black - "death".
Please help me
    Genius:
  • 3,422 Answers
Since the TV has no sound and picture then please check the Horizontal amplifier,The flyback and the power supply.The problem can mostly be with the Horizontal voltage amplifier.The only solution will be to get it replaced.
I strongly recommend you to get it repaired by a technician.The repair can cost anything between $200 -$300.
Goodluck,
Please don't forget to rate the solution.
Posted on Mar 24, 2008
    Guru:
  • 1,894 Answers
I think the problem with the ICs responsible for video in the main board.
  • 3,037 Answers
Horizontal line is collapse of vertical deflection amplifier and will require a repair to the vertical output driver. Cost is usually around $100 plus or minus depending on the size and age of your set.
Anything else?? Let me know. Thanks for your question.
  • 1 more comment
  • Benjamin Patri
    Benjamin Patri Mar 24, 2008
    be careful when opening your tv. An expert should do it to avoid electric shock, don't do it yourself if you don't know what you are doing
  • Benjamin Patri
    and a vertical line is a result of the collapse of the horizontal amplifier
  • Benjamin Patri
    Benjamin Patri Mar 26, 2008
    How is your problem going? Do you need any more help? Let me know if you do.
    Have a Great Day!
    Genius:
  • 1,913 Answers
Hi
open your tv clear dust , check capesitor,power supply ,transi sotr ,regester,
SOURCE:
Acer Aspire 7520 black screen wont boot
Turn off notebook. Remove the battery. Press Power button. Notebook should start working. Wait for 15 secs. If the screen still blank press Power button and hold it for approx. 4 seconds until notebook is powered off. Then press power button again. Bingo, problem should be solved.
Dec 19, 2009 | Acer Aspire 7520-5185 Laptop
I turn my system on and the screen is black but i hear the game. i changed the video cord still the same result.
It is nothing just hold your on button untill it turns off again hold it again but nou it will make a sound keep holding your finger untill it makes the sound twys in a rowe take your finger of and in about 5 sec a screen will apear say restore sestem if it's not working the first time do it again untill it work's 100%.HOPE I WAS USEFULL PLZZZZ RATE ME O JHE SORRY FOR ME SPELLING I AM ONLY 13 AND AFRIKAANS if u want some more answer about ps3,2 or 1 or any network or PC problems email me to [email protected] i even do DVD player so lpzzz rate me and if there is anything els plzzzz email me i will help..
Nov 08, 2009 | Sony Playstation 3 (PS3) Console
TURN ON AND SCREEN IS BLACK W/ WHITE LINE IN MIDDLE
this might be the psp's problem you might of droped it .so go to a mechanic to help you pls. vote for me cloud_foe
Jan 10, 2009 | Sony PlayStation Portable (PSP) Console
I need help with my TV
Good day.
There is a problem with the vertical circuitry. It may be not be receiving supply from the flyback or the vertical IC is busted. Have it cheched by a repaireman.
Response is highly appreciated.
chris
Mar 24, 2008 | Televison & Video
Samsung model#TX83082WH
you have a weak power supply its simply trying to go out on you
Mar 14, 2008 | Samsung HLN467W 46" Rear Projection HDTV
Black Screen with vertical lines down the side?
· http://esupport.sony.com/perl/news-item.pl?news_id=24
· Which models are affected with the "flicker" problem?
A1: There are 12 models in total: KDP57XBR2, KDP65XBR2, KP46WT500, KP51HW40, KP51WS500, KP57HW40, KP57WS500, KP57WV600, KP57WV700, KP65WS500, KP65WV600 and KP65WV700.
Jan 03, 2008 | Sony KP-57HW40 57" Rear Projection...
Bright,thin line, in the middle of the screen, then...
1. I turn on the monitor, I hear a 'cracklin' sound
Reply: In a CRT Monitor there is a component called EHT which generates High voltage which is connected to the anode of the CRT, If there is any leakage due to moisture can cause this crackiling sound, You need to clean this high tension wire or replace the EHT ( CAUTION : BE AWARE OF HIGH VOLTAGES )
2. The screen only shows a bright, thin line.
Reply: The vertical Drive section of the monitor is faulty.
Dec 21, 2007 | Hitachi SuperScan Elite 802 21" CRT...
Sony KV-32FV15 TY
I have had my Sony KV-32FV15 for about 2 years now and nothing has ever gone wrong(even going through several moves.) I recently moved again and when I plugged in the TV, you can hear the sound perfectly but the screen just stays black. You can not even hear the squeal that the TV makes when comming on. Is there anything that I should initially look at to troubleshoot. I cannot afford at this time the $250 fee to repair my TV. I look forward to your input and hopefully I can get this TV working again.
Oct 24, 2007 | Sony KV-32FV15 32" TV
Line in the middle of screen
You have a bad component in the vertical circuit of your set. If you hit it on the back of the cabinet with your hand which will "jar it" and the picture flashes back on then you have loose connection. If nothing happens then the vertical circuit has a bad component most likely the Output IC. (Chip) Stargazer
Mar 27, 2007 | SansuiS2001 20" TV
Samsung SlimFit  TX-S3082WH 30" TV Logo
120 people viewed this question
Jerry Greenberg
Jerry Greenberg
Ekse
