Vista update Did the vista update tonight now cant boot computer into safe or normal mode. Dell pc. any ideas what to try?
    Problem Solver:
  • 14 Answers
Insert your windows vista disk and during setup youll see system restore it will fix your boot problem once after you run it
Posted on Mar 24, 2008
Computer starts then goes to black screen and system recovery wont work error code 257'
The display drivers maybe corrupt.
Boot the machine into safe mode. Right click on My Computer (XP) Computer (Vista) and select manage from the sub menu.
When the window pops up select Device Manager.
A device list will populate. When it has look down the list for Display Adapters. Click on the + icon next to Display Adapters to it expands. Right click on the display adapter and select uninstall.
Restart the computer and let it boot in normal mode.
If it boots in normal mode let it detect the Display and install the drivers for it.
I would be a good idea to update the display drivers via the Dell Support website
Regards.
Sep 30, 2009 | Dell Computers & Internet
Screen goes out after you turn on.
I would be a good idea to update the display drivers via the Dell support website.
If it still won't display in normal mode please post back.
Good luck.
Sep 22, 2009 | Toshiba Computers & Internet
Black Screen Dell 600 Laptop
Good luck.
Sep 17, 2009 | Dell Inspiron 6000 Notebook
My Dell laptop is stuck on Windows Vista Home Basic
Press F8 to go to Safe mode, open SYSTEM RESTORE to go back to checkpoint where not yet updated the system.
And next time to open back your system normally finished all updates before you shut down.
Sep 16, 2009 | Dell Inspiron 1525 Notebook
Help My Sandisk U3 Locks up vista SP1 useing intel 920i
Very well could be due to the fact your running 64bit Vista. I would try shutting the computer off,connect the U3,then turn on the computer. Sometimes the drives come with software that could be causing the problem also due to the try to install themselves when connected. You could also try booting up in safe mode. Press F5 repeatedly when the computer is booting up and this will take you to a menu that you can choose the safe mode option and try to connect the drive in this mode. You can then load/disable files or software on the drive that may be the cause of the problem. Also try the drive in another computer if possible and if it works try getting the firmware update from the sandisk website. It is possible the drive itself could be bad.
Sep 04, 2009 | Dell Studio XPS 435 PC Desktop
Window vista is not booting the computer
Try starting in safe mode. If it does boot in safe mode then go to HELP, THEN SYSTEM RESTORE, pick a date before you had these problems. Good luck. You start in safe mode by pressing F8 then selecting SAFE MODE from the menu.
Jul 30, 2009 | Acer Aspire 3680 Laptop
My desktop keeps restarting and shows windows update 3 of 3. it does it over and over.
If you have a Windows Vista operating system, try this:
Try a system restore from safe mode or from the repair option VistaDVD. Other then that only solution I have is a workaround. See if youcan access safe mode F8 at the boot screen, select "safe mode withcommand prompt" at the prompt type:- Code: C:windowswinsxspending.xml C:windowswinsxspending.old.xml
C:windowswinsxscleanup.xml -> C:windowswinsxscleanup.old.xmlPress enter after each command, reboot you will still see the config updates however it will quickly dissapear and Windowswill boot normally. I would contact MS about this, for a permanent fix.If no safe mode boot with your vista dvd go past the language setup andselect the repair option Now select command prompt (BTW at the "xsources prompt type C: press enter brings you to C:/>) now run thetwo above commands.
If you find this works you may be able to permanently remove the"Update" go to C:windows software distribution and right click select"delete" windows will recreate a fresh folder at boot.
Jul 19, 2009 | Dell Inspiron 530 Desktop Computer
Hard drive will not completely finish installing Vista Sp1.
Try booting in Safe Mode (press F8 during startup). Once in safe mode, see if you can see the update in the Add/Remove programs from the Control Panel. Make sure the select the "View updates" checkbox.
If it is there, try uninstalling it before you boot in regular mode again.
While in Safe Mode, also disable the automatic Windows update. You can then try to install it manually from the Microsoft site instead.
Microsoft has some more ideas on how to fix SP installation.
Jules
Jul 16, 2009 | Samsung HM060HI Hard Drive
I have Windows Vista installed on my laptop. I install all the automatic updates. Recently Vista downloaded Service Pack 1 and I installed it. After the installation my laptop stopped working. I can...
Your problem: "I have Windows Vista installed on my laptop."
Unfortunately, as with a lot of MS service packs, they can crash some computers. You need your windows vista disk and, booting from it, you can select repair your vista installation. This should take care of the problem. Then don't update to sp1 for a few months.
Jul 05, 2008 | Acer Computers & Internet
Computers & Internet Logo
37 people viewed this question
David Payne
David Payne
