Question about Emerson MW8102SS 1100 Watts Microwave Oven
Loud noise and not heating up
I turn it on and it started to make a loud noise and not heating up
    President:
  • 2,468 Answers
If its making a loud humming noise you need to remove the outer and carefully discharge the high-voltage capacitor in the magnetron circuitry(caps are usually oval in shape and 3 to 5 inches long) after this disconnect one terminal of the cap and check it for being open,then do the same on the high-voltage diode and check this for front to back resistance high in one direction and lower with the meters leads reversed on the diode,the humming is coming from the transformer not being loaded by the cap and diode to double the voltage required by the magnetron tube of -2,000 volts D.C.
Posted on Apr 26, 2010
Making loud noise when turning on to heat.
If there's a loud noise when you try to microwave food, then the current through the high voltage transformer is probably too high.
Most likely, this is being caused by failure of a component in the high voltage circuit. The most likely component is the high voltage rectifier, followed by the magnetron or high voltage capacitor. High voltage transformers occasionally do burn up as well.
May 27, 2016 | Microwave Ovens
When microwave is started, why does it make a loud buzzing sound--like a Skil saw sounds?
Whirlpool Microwave Buzzing Loudly - ApplianceBlog
www.applianceblog.com/.../26531-Whirlpool-Microwave-Buzzing-Loud...
Aug 12, 2011 - 10 posts - ‎2 authors
My Whirlpool MT4155SPS-2 microwave oven has recently started to buzz loudlywhen operated. The sound is getting louder and more frequent ...
Whirlpool making intermittent loud buzzing noise Microwave ...
www.fixya.com > ... > Microwave Ovens
Whirlpool microwave ovens making intermittent loud buzzing noise related questions and answers. Ask your ... ...loud buzzing noise and it doesn't heat. i just tried it again and let it run for 1 minute. ... Question about Accuwave Microwave Oven.
Troubleshooting the Microwave: Potential Problems ...
www.appliancejournal.com/.../troubleshooting-the-microwave-potential-...
If your microwave buzzes loudly and produces no heat you probably have a defective power .... I have a whirlpool oven range and it's less than a year old. .... Humming sound stops when I open door to remove food, but when door is closed, ...
Whirlpool Microwave Ovens - Consumer Affairs
Feb 03, 2016 | Whirlpool Accuwave Microwave Oven
We were using the microwave the other night and it started making a loud noise like the fan was running (although the fan was not). We let it sit for awhile and try to use it again but the noise came...
The loud noise and no heat means that the magnetron has failed. It the part that generates the microwaves that heat the food. When it fails it shorts out, causing the transformer to heat up. That is what was causing the burning smell. The cost of a replacement magnetron is around $130-150 range so it may not make sense to have it fixed.
Mar 24, 2011 | Maytag MMV4205 Microwave Oven
Microwave not heating and giving burnt plastic smell
STOP USING IT!! UNPLUG IT!! Microwaves are inexpensive now. It will cost you more than a new one costs, to get it fixed.
Apr 02, 2010 | Microwave Ovens
Our microwave oven started making a loud sound and quit heating
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Basic Microwave Oven TroubleshootingTips
heatman101==]-]=-
Feb 14, 2010 | Emerson MW8107WA Microwave Oven
Whirlpool builtin microwave humkming loudly
yes for sure magnetron or diode has gone bad.but usually it is the mag.magnetron when go bad they start making noise and stop heating.when chaging magnetron chg the diode with it.
Aug 18, 2009 | Whirlpool MH7140XF Microwave Oven
Unit making loud noise
your turning spindle must have warped due to high heat in oven
Dec 06, 2008 | Microwave Ovens
Microwave made loud popping noise
The magnetron is bad. Probably cost about $50 or $60 for the part. Not too easy to replace, but it can be done.
Dec 13, 2007 | Whirlpool MH7130XE Microwave Oven
Microwave makes a loud noise while using.
Could you describe the noise?
It may be a noisy fan motor or a failing magnetron or high-voltage transformer.
If you or a friend decide to look into it, we have critical information on safety, disassembly and door switches at our site, linked here on Fixya: http://tinyurl.com/yzjozk
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
Oct 13, 2007 | Microwave Ovens
Emerson MW8102SS 1100 Watts Microwave Oven Logo
219 people viewed this question
Top Emerson Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Jerry Greenberg
Jerry Greenberg
Are you an Emerson Microwave Oven Expert? Answer questions, earn points and help others
