Question about Sony Cyber-shot DSC-W120 Digital Camera
Sony Cybercam DSC-w120 stopped working completely for 1 week.
My Sony cybercam DSC-120 camera stopped working completely for 1 week when I went near the ocean. The power light cam on but the lens would not open and pop out. Today I turned the on button and after about 3 minutes it just opened. It makes all the noise for the buttons working but the screen is light and grey without a picture or anything, it just lights up. Its only 4 months old.I thought it may have gotten wet but it didnt appear to be wet when it stopped working.
    Top Expert:
  • Sony Master
  • 50,314 Answers
Contact SONY it should still be covered under warranty period
Posted on Jun 09, 2017
SOURCE: Have a Sony DSC-W120 digital camera that got wet
Well some people believe that if u put ur wet camara without the battery the on (uncooked) rice for 24 hours all the water left in it will leave the camara for good.
Posted on Jul 23, 2009
  • 94 Answers
SOURCE: The touch screen will not let me change any settings in the menu
Please try to reset the DSCT10 camera and check if it helps. To reset the Camera, please remove the Battery and press and hold the button for one minute. Then, leave the power button and reinsert the Battery. This should help to access the menu options
Posted on Sep 22, 2009
  • 1382 Answers
SOURCE: My camera stopped working suddenly. When I turn
Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Thank you!
Posted on Jun 01, 2010
Testimonial: "Thanks for the feedback! I tried this and another solution I had found, and it now works!"
welcomejee
  • 10594 Answers
SOURCE: SONY DSC T33 SCREEN STOPPING
This is due to failure of ccd imager chip in your camera, replace ccd imager chip to get live view in lcd to take fresh pictures.
Let me know if you need ccd imager chip part number.
Posted on Sep 28, 2010
SOURCE: My Sony Cybershot DSC-W120 Super steady shot Camera won't turn on
I have the same problem, but when I remove the MS Pro Duo card (1GB) from the camera it works fine again. The memory card works fine in a pc memory card reader. Is there a problem with the Sony camera built-in card reader?
Posted on Oct 31, 2010
Turn power off again sony dsc w120 shot
disculpe tengo una camara sony DSC-W120 la bateria esta cargada y la quiero encender y no prende que puedo hacer saluda atte rodolfo
Jan 14, 2013 | Sony Cyber-shot DSC-W120 Digital Camera
I have a sony cybershot dsc w120 camera and it turns on and maybe lets me take 1 or 2 pictures before shutting off (sometimes with the lens still out). It hasn't been dropped or exposed to water, so I
Things to check first for a camera that won't turn on, or works intermittently are the battery contact points, ensuring that they're clean, and making good contact with the battery. Troubleshooting tips on other things that need to be checked may be seen here. These tips won't work for every case, but they're worth a try.
Nov 23, 2011 | Sony Cyber-shot DSC-W120 Digital Camera
How can i use my sony dsc w-120 digital camera as a web cam?
You can't. The W120 was designed as a camera, storing images and videos to memory. It was not designed to stream live images to another device.
Mar 19, 2010 | Sony Cyber-shot DSC-W120 Digital Camera
Sounds touch button array on LCD got disconnected due to over use or might have hard scratch on LCD surface, needs to be replaced LCD in your DSC-N2
Let me know if you can replace LCD in this camera to provide you LCD part number info.
Thanks.
Sep 20, 2009 | Sony Cyber-shot DSC-T10 Digital Camera
I can't use macro on my sony cybershot digicam
I have a Sony W120 and had the same macro problem, tried all the "solutions" mentioned here without result. So I pressed the "Home" button, went to "Settings" (last menu item at right), then "Main Settings", and used the "Initialize" functio. Problem solved !
Aug 12, 2009 | Sony Cyber-shot DSC-W120 Digital Camera
Have a Sony DSC-W120 digital camera that got wet and has quit working.
Jul 08, 2009 | Sony Cyber-shot DSC-W120 Digital Camera
Need to charge battery
You can not charge camera DSC-W120 battery with USB cable in computer. To recharge battery you need battery charger with following part number..
148017521 CHARGER, BATTERY (BC-CSGC)
Available in Sony Accessories Store.
May 08, 2009 | Sony Cyber-shot DSC-W120 Digital Camera
Sony Cyber-shot DSC-W120 Digital Camera Logo
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
