Question about Price Pfister R897EBK Brushed Nickel Catalina Single Handle Shower Only Tri
How doi i get the cover plate off to get the valve out
I cannot get the water to turn off no matter how far i turn the handle
    Scholar:
  • 81 Answers
Http://www.pricepfister.com/www/ImageAssets/mirror/model/bath/catalina/catr89-7eb/ex-808-01.pdf The cover plate is held in place with part #972-300. That part has threads on the inside like a typical nut. Grab firmly ann twist counterclockwise.
Posted on May 29, 2010
Took a shower and then the water would not turn off no matter how I turned the handle.
Check beneath the bathroom sink there must be a valve to close the water from going into the bathtub. Or check for a little door near the bathtub find that valve and close it. You have to buy a new handle cause that one is ruined. If you don't find the valve, remove a plastic cover that it's in the middle of the handle, there must be a philip screw in there, take it out, remove the handle and then with shearing pliers turn counter clockwise and it will close.
Jun 27, 2011 | Home
Handle is very hard to turn. what is wrong
First, turn off water supply, then remove screw from center of handle, unscrew cover plate. There is a round mixing valve that will need to be replaced. You can find at any Do it yourself or hardware store. Dont forget to turn off water supply first........
Apr 07, 2011 | Moen & One Handle Tub & Shower Faucet
Cant get valve to shut off no matter how far it turns either direction. Hat could be causing this?
Having looked at the diagrams of the valve I not sure the handle is tight on your stem an is not turning the valve stem.
Look at that and if that's not it I will try to help.
Feb 01, 2011 | Grohe Integrated 1/2'' Shower Thermostatic...
Leaking hot water seal
leaking around handle?Turn water off under sink.remove handle,cover plate,unscrew valve stem assembly,and turn the two pieces apart to expose o ring,and replace
Jan 27, 2011 | Kohler K-16109-4-CP Revival Kitchen Sink...
Usually when I turn the handle on, I have to turn it only to a certain point to start getting hot water. This morning, I had to turn at least two times farther and wait an extremely long time for hot...
It is probably the regulator/cartridge valve in the handle and is fairly easy to fix yourself.
Remove the screw cover from the center of the handle (use a small flat screwdriver to pry it off), then remove the handle (phillips head in counterclockwise direction), there is a metal plate behind the handle remove that and tuen you can turn the water off here as well - the middle one is has a cartridge valve and the other two on each side are the water supply shut off - use a flat head screwdriver to turn them clockwise to shut off the water supply.
There will be a bonnet nut on the center pipe - remove that with an adj. wrench. Pull the valve out (channel lock pliers work well) of the center pipe and insert the new cartridge.
Reinstall the bonnet nut and turn on the water supply valves on either side, replace the metal plate and faucet handle.
Good Luck!
Jan 05, 2011 | Moen Posi-Temp Single HandleTub And Shower...
Installed new valve but when I screw the handle in I can't shut the water off completely. I can pull and turn the water on but when i push it in, it only turns off part of the way. To shut it off i have to...
On most moen single handle valves there is a washer that is supposed to fit over stem on cartridge.This washer has two flat sides to fit over flats on stem. The only other thing I can think of is that your valve face plate is mounted a little to far out and won't let back of handle go all the way closed. I would try tightening the two screws that secure face plate to valve a little and see if that helps. Good luck. Thanks
Nov 18, 2010 | Moen & One Handle Tub & Shower Faucet
Once your cover plate is removed you can access the cartridge. With different styles by Price Pfister there maybe an additional pressure balancing part behind the cartridge. If so they should both be replace at the same time. Remove and take to your local plumbing parts store for a match up.
Apr 26, 2010 | Price Pfister R897EBK Brushed Nickel...
No cold water
Anti Scald Valves have an adjustment under the handle (remove handle) to allow so much hot water in no matter how far handle is turned. Its possible that the adjustment is set to allow only hot water in, this of course defeats the purpose of anti-scalding. Check to see if you can adjust this back. Good Luck have a Great Day. Please give a 4 THUMBS UP if this free answer was of any help.
Apr 01, 2010 | Ldr Industries 520 1300C ADJUSTABLE SHOWER...
We have a newly installed Delta single-handle shower faucet and cannot figure out HOW to get a warm water mix. No matter where we turn the handle, we get different temperatures of "cold."
That is a graduated water mixer valve, and it sometimes has a little white water restrictor blocking flow from your hot water port. See if that was left in by removing the handle with all water shut off to the valve and reattach then try again. This can also happen if you have a tankless water heater because pressure controls heat. Typically a Tankless water heater system will require little, to no cold water to your bathtub valve because of the heavy water flow at the tap. Remember, flow equals temperature. Less flow = more heat, more flow = less heat.
Mar 09, 2010 | Delta & Single Handle Shower Faucet
Price Pfister R897EBK Brushed Nickel Catalina Single Handle Shower Only Tri Logo
274 people viewed this question
Top Price Pfister Home Experts
Mike
Tim Whalen
Donni Steen
Are you a Price Pfister Home Expert? Answer questions, earn points and help others
