Question about Whirlpool MH2175XS Microwave Oven
The underside light bulb blew now carousel doesn't turn and interior light not working
  • Whirlpool Master
  • 9,085 Answers
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 with a one year guarantee.
At our Web site, you can get details of our service, plus we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
The lights can can be inoperable or stuck on or stuck in "night light" mode. Sometimes this will similarly affect the fan operation, inside light, or turntable too.
Feel free to contact me directly (and please remind me of your full model number from the tag on the unit) for more information & help.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Microwave Oven Control Panel Repair Nationwide
Posted on Apr 28, 2010
HOW DO i CHANGE THE BULB IN MY SHARP R-651ZM MICROWAVE OVEN
Changing the light bulb on your Sharp carousel microwave will allow you to have needed light inside the oven. Microwaves are not designed for consumers to change the light bulb due to manufacturer liability, but it can be done. Following the proper steps will ensure a successful installation. Step 1 Unplug the Sharp carousel microwave from the electrical outlet.
Step 2 Locate the screws around the outer cover of the Sharp carousel microwave and unscrew all the screws.
Step 3 Lift off the covering.
Step 4 Locate the bulb and unscrew. Screw in your new bulb.
Step 5 Replace the cover and screw back tightly. Once done, test your new bulb.
Oct 10, 2017 | Sharp Microwave Ovens
How do I change light bulb under a 2009 ge microwave/model no.lvm1750dm1ww
The range top bulbs can be replaced by removing the screw that holds the glass and frame to the underside of the unit, they swing down, the bulbs usually screw in, the power needs to be turned off by way of unplugging the unit before replacing the bulbs, the interior cavity bulb can be replaced by removing the top grille and accessing the socket assy from the front. Pleazer Appliance...
Dec 22, 2014 | GE Microwave Ovens
How do I replace the light bulb on my Sharp Carousel microwave - model R-8R51
Strip the microwave and you will see the bulb holder at the back you can use yo hand to turn itsideways
Sep 15, 2014 | Microwave Ovens
Microwave heats, but the turntable and lights don't work
see the chart for light 1)
  • Light bulbIf your microwave light bulb is not working, perhaps it has blown. The first step is to replace the bulb and power on the microwave. If this does not correct the issue, the next step is to check the socket and wiring to verify if that is the problem.
  • Light bulb socket & main control boardIf your microwave light bulb is not working after the installation of a new bulb, check the light socket as well as the wiring to ensure they are properly operating. If these sources are functioning properly, the next step is to check for a faulty control board as a possible root cause to your microwave light bulb malfunction
  • 2) the carousel inside your microwave won't turn when you run it, the small motor that operates it may be broken.
    God bless you
    Sep 30, 2013 | GE Spacemaker JVM1640SJ Microwave Oven
    R-8350, No power to touchpad, but interior light works
    The touchpad has its own fuse which has probably blown due to a surge perhaps related to the turning on of the fridge. Removing the cover from a microwave is potentially lethal due to the large capacitor to drive the magnetron. However, this is usually well away from the front panel. If you do venture in you should first unplug the unit and when the outer cover is removed, discharge the large capacitor with well insulated pliers -= otherwise keep well away from it. The fuse you are interested in is on the pc board behind the touchpad. Replace it with exactly the same fuse (usually a slow blow fuse).
    Sep 22, 2009 | Microwave Ovens
    I replaced the bulbs in the underside of the microwave but the lights still won't turn on, can someone tell me what i'm doing wrong or something else I need to do? It's a whirlpool model # MH6130XEB-1
    You did not say if the machine works otherwise.
    I gather you replace the bulbs in the ventilation section;
    http://www.appliancepartspros.com/partsearch/model.aspx?model_id=260489
    Click on the diagram 8 in the left-hand side for ventilation for those bulbs.
    Is it plugged in ?
    You can check.
    Line Fuse
    Thermal Fuse
    You can find a diagram at;
    Click on the diagram 5 in the left-hand side for interior parts and another bulb.
    You can check;
    Switch;
    You can take a voltmeter and place it on the bulb contacts and see if voltage is present when the machine is switch on.
    May 09, 2009 | Whirlpool MH1170XS Microwave Oven
    Kenmore 63682300 Bulb blew now lights won't turn off
    See if I get what you are saying.Sounds like the light switch is bad.That would be the first thing I would check.
    Mar 14, 2009 | Kenmore 63682 / 63684 / 63689 Microwave...
    Goldstar MIcrowave stopped working when light bulb blew out.
    when that happen to me i change the bulb and the fuse in of the microwave f the don't work send it to the company that made it and they should tell what wrong.
    Mar 11, 2009 | Goldstar MV-1501 Microwave Oven
    Interior Microwave doesnt come on..Burned out?
    If it doesn't have a door you have to remove the cover. Its likely a special microwave bulb and the socket will have to be replaced with the bulb. the bulb is built onto the socket.
    Jan 14, 2009 | Sharp R-1514 Microwave Oven
    Microwave touch pad work light doesn't work
    We see this a lot. The problem is on the control panel, which we regularly repair nationwide for $39.95 postpaid.
    Details of our service and critical safety information and disassembly information is at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
    We're happy to help and we appreciate your thoughtful rating of our answer.
    Dec 29, 2007 | Microwave Ovens
    Whirlpool MH2175XS Microwave Oven Logo
    51 people viewed this question
    Top Whirlpool Microwave Ovens Experts
    William Miller
    William Miller
    Chuck
    Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
