Question about KitchenAid Dishwashers
Very squeaky hinge on main loading door- I think caused by vibration of the plastic pulley that guides the cord attached to the spring that balances the door
I just finished fixing mine. I tried WD40 on everything that moved, but it did not help. In fact, it was worse, After reading the reply above,I wiped off/cleaned the cord and put on a lubricant such as Lubriplate grease and it totally stopped the squeaking.
Posted on May 10, 2010
How to replace door springs
There is a service bulletin on the spring and connector(the cord that connects the spring to the door)The spring for the hinges part number is 4970ED4004G. You will need to change the connector assembly for each hinge (plastic colored black at each end of the cord instead of white) and that part number is 4933DD3001B. I use a heavy coat hanger with a hook bent at the end. At the other end where I hold it, I've bent the remaining length of the hanger into a handle of sorts. This gizmo is about 1.5 feet long. Release as much tension from the springs as possible by closing the door. Using a headlamp, remove the kick panel and locate where the springs are attached to the lower frame. Now, using the coat hanger, hook the end of the spring that is attached to the cord. Pull firmly against the spring tension with one hand and unhook the spring from the cord with the other. Do this on both sides. Reach underneath and remove the springs and replace them with the new versions, hooked in same place as the old ones. Replace the cords with the black upgraded versions and reverse the above procedure. You shouldn't have to remove the washer from the counter to do this. Just take your time and don't get frustrated--I do this all the time, you *don't*. The hardest part is trying to hold the spring forward enough to latch the cord connector onto the hinge. That's where having that coat hanger is a blessing! Otherwise, you're gonna have to pull the dishwasher out of the counter and that can be a real pill. Good luck and I hope I helped you!
Sep 12, 2015 | LG LDF8812 Stainless Steel Built-in...
How to fix a squeaky dishwasher door
You may need to slide the dishwasher out slightly. On both sides at the floor level are the door springs, pulley, and cables. The cable is usually attached to the door hinge--then goes around the pulley wheel and goes back to the spring system. Most noise comes from the hinge pivot point or the pulley axle. You can spray all those parts with something like WD40 or if you don't like that smell try a silicone spray. Do both sides and work the door up and down.
Mar 31, 2015 | Frigidaire Dishwashers
How to fix a squeaky door on a frigidaire gallery dishwasher
Thank you for your post, friend!
I see that you need assistance in repairing a squeaky door on your Frigidaire dishwasher. The best way to quiet down a squeaky door is to pinpoint the cause of the squeak. This could be an issue with your hinges, springs, or the cables. You can use a lubricant such as WD-40 on your those parts to see if that will help alleviate the squeaking. Hope this is helpful. -Matt
Feb 27, 2015 | Dishwashers
Hello. I have a 1993 Hobart LX-30 dishwasher. Just recently the door lost the tension it has when we open it up. it now is extremely heavy and falls open like a dead weight. Any ideas what might be the...
There are a few possible causes of this, so it's easier to explain how it works and how to find the fault. There is usually a wire or cord attached to each hinge. The cord is threaded anti-clockwise through a pulley then runs vertically up to near the top of the washer where it's attached to a spring. When looking at the side of the washer, the spring is usually about 2-3 inches back from the door and attaches about 2-3 inches below the top of the washer.
To find the fault you need to remove the side panel/s of the washer. It helps if you can identify which side has lost tension (it could be both) as this avoids removing one side panel unnecessarily. Once you have removed the panel, you should be able to see the back of the hinge and the pulley/cord/spring assembly. It should then be fairly obvious what the fault is - it could be a detached/stretched/broken spring, or a detached/broken cord.
Hope this helps.
Regards,
BElectric
If your problem has been solved, please be generous and award this solution 4 thumbs-up. This service has been provided FREE - your simple acknowledgement is appreciated. Thanks.
Nov 08, 2010 | Hobart SR24C-5 Dishwasher
My KitchenAid dishwashers door will not stay shut. I have replaced both hinges, the plastic rollers for the tension lines that atached to the spring. Still no luck. Could it be that the locking (?) switch...
Sure thing.
Our dishwasher is one that we put our own "Door on it" in our case, it matches the cabinet. It is designed for that.
I went on-line and ordered the replacement parts. I can't recall the site but I will look thru my files and send to you if I find it.
I removed our door front and slid the DW out about 1/2 to 2/3 of the way. I did not want to mess with disconnecting power and water lines. 1/2 way out should be enough room to work on the places you need to be. On both sides near the back and bottom you will see a large tension spring. Be careful not to bust a knuckle here. Using a sturdy hook of some kind is recommended. In place of that you might try a solid wooedn hanger with a heavy hook on it. BE CAREFUL, while pulling on the front part of the spring you will release the tension on the cord that is around the plastic guide wheels and attaches to the bottom hinge of the door.
Release the hook and then the tension you have on the spring. repeat this on the other side. With both sides free the door should lift off the hinges and the base it sits on. inspect your hinges. mine were bent, not much, but I was at whits end. I replaces both. I also replaced both cords that were attached to the tension spring and one of the plastic roller wheels ? I am sure there is a better name for them. It was the longer of that is on the tear drop shaped fastener.
I then placed the door back in posistion and closed it. On the the tear dropped shaped guide wheel (the one at the bottom) you will see that there are holes to adjust the tension. The closer you move this wheel towars the front of the machine, the more tension on the hinges. I set mine in the middle and this seemed to work. Before you slide it back in the space, try a test to see if the door stays shut. ie. run a rinse cycle too. Hopefully that is all you will need to do...BUT.
That was not to total solution in our case. I ended up ordering and replacing the door switch (a black plastic piece that is what the metal latch on the machine is supposed to "hook" into.
Replacing it is fairly simple. I did shut the power off for this. This part is replaced by taking off your face plate which is secured bu screws inside of your DW door around the edge. You will see 4 screws to remove and it "snaps" out. At this point you can see the working relationship with the latch, the switch and the contacts on the switch that the door latch (metal part coming out of the top of the DW) after replacing this...try the process again and hopefully your issue will be solved. I had to remove my latch and bend it back to the original shape and mess around with a slight bend to make it latch and hit the contacts in the door latch.
Good luck! I am sorry this is so long. :-)
Mar 14, 2010 | KitchenAid 24 in. KUDI01FLSS Stainless...
Our Kitchenaid KUDS01FLSS6 dishwasher door string broke, but unsure what I need to pull apart out to replace?
The "STRING" is referred to as a LINK. The link has a plastic connector glued to each end. It is common for the plastic to get brittle with age (even less than 5 years) or the nylon cord to wear down and break. That is why you see the frayed cord. You have to pull the dishwasher out to fix the problem. I had to order my link online because parts store in my city didn't have it in stock. Go to the Kitchenaid website to and key in your model number to get the parts schematic for your dishwasher. Under Customer Care, go to Locate Manuals and Guides, key in your model # and click Go. At the bottom of the web page you'll see Parts List. Click on the link and this pdf pops up: http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%208194009.pdf.) From the schematic you can find on page 7 "Link, Door Balance" which is #24 part 8535568. The spring hooks on to the back of the dishwasher frame and runs parallel to the floor. The Link end with the round hole attaches to the spring and the other end slips/hooks over the bracket arm that is attached to the door. Good Luck
Feb 27, 2010 | KitchenAid 24 in. KUDI01FLSS Stainless...
Frigidaire dishwasher door squeaks when opened and closed
I had the same problem and this worked like a charm:
http://www.blog.applianceoutletservice.com/2008/12/frigidaire-dishwasher-door-squeaks.html
All you'll have to do is take off the kick plate, actually remove the cords, and lubricate with soap (lower tech than spray silicon, but it's worked so far...)
Aug 22, 2009 | Frigidaire PLD4555RFC Dishwasher
Squeaky noise when open door
petroleum jelly rubbed on the nylon cord and all parts that it touches...it does the trick
Jul 13, 2008 | Frigidaire 24 in. FDB1050REC Stainless...
Canoscan lide 60 drive cord problem
Drive cable is attached in two places. One at the hinge end of the scanner. The other at the control panel end. The hinge end connection is a simple ball-end that slips into the slot. The control end fixing is more complicated. The wire cable at this end has a spring attached. This is fixed to a plastic fitting which clips into place. Look carefully the plastic fitting. Fit the spring over the small peg and take the cable round the radiused part of the plastic fitting. And refit the plastic clip to the scanner body.
c21b280.jpgFiddlly but doable.
The cable often comes loose when someone investigates how to take the scanner to pieces. Underneath they see a round pin with a small rectangle on each side. They press the round pin in slide the piece of plastic in the rectangle and hey presto they'll undone the cable. Oooops!!!!!!!!
Mar 13, 2008 | Canon CanoScan LiDE 25 Flatbed Scanner
Squeaky door
On our KitchenAid dishwasher we had the same problem--a REALLY loud squeak as it opened. The sound comes from the nylon rope slipping along the plastic pulleys. We've had the DW for about 3 years and the noise has gotten worse over time. I was determined to win the war against the noise and am happy to say I fixed it today.
The trick is to use a dry lubricant on the cord and on the pulleys. I used Dry Graphite by Gunk. It comes in an aerosol spray can and once the stuff dried the squeak was gone. I'll let you know if it comes back...
May 16, 2007 | KitchenAid 24 in. KUDS01FLBL Built-in...
Dishwashers Logo
263 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
