Question about Maytag Atlantis MDG7400AW Gas Dryer
Heat Element glows then shuts down---will not ignite gas
    President:
  • 2,468 Answers
It could be your radiant flame sensor on the burner tube that senses the flame,or it could be bad boost and secondary gas valve coils on the gas valve located inside the unit,a defective high-limit or cycling thermostat on the burner tube,any one or combination of these can cause your symptoms
Posted on Apr 26, 2010
What is causing my igniter to get hot and shut down
what is it for,a dryer an oven?if it's for an oven even though it glows doesn't mean it's good,it works with amps,it has to get 3.5 amps to open the gas valve for a flat igniter 2.5 for a round igniter,if it doesn't ignite within 40 to 60 seconds the igniter is bad or no gas but usually it will be the igniter if it's a dryer and the igniter glows but no flame you could have bad gas coils or a bad gas valve,usually if the coils are bad you'll have heat for like the first 15 minutes then when the coils heat up they fail the igniter will glow but no flame,also check the sensor,if the igniter glows longer than normal the sensor could be the problem but the only way to tell is by checking the sensor and coils with a meter for ohms,make sure the gas is on,if you had work done in the house someone could have shut down the gas,seen it before but you have to send the brand name and model number off of the machine you need fixed.good luck
Dec 15, 2017 | Cars & Trucks
Why won't my inglis dryer heat up
if electric? check ur thermal shut off and thermistor with a multimeter. does it run at all? if it does it wont be thermal shut off but may be ur heating element? is it gas or electric? Gas? 1. may need to check ur coils which regulate the flow of gas, ? 2. CHECK Igniter which ignites the flame, or 3. CHECK THE glow bar. there are also thermostats on the heating eleemt you will want to check with a multimeter. the thermal cutoff, the hi-lo thermostat and the element itself.
Aug 16, 2014 | Whirlpool Inglis IP8200 Dryer
Gas oven won't light on Tappan Centenniel. First, the burners come on, so gas is getting to it. When oven thermistat is turned on, some sort of electric igniter element glows. How does this igniter...
The inside of igniter has a probe that is heated, When it is time to light, the solenoid opens gas valve and allows gas, then that heated probe ignites the flame. After temp is reached fuel is shut off.
Oct 29, 2009 | Kitchen Ranges
Dryer drum is rotating but no heat is present
If electric then the thermostat or the heating element has failed.
If gas: First thing to check is the ignitor underneath the drum. (You have to open the panel to see it) It should glow shortly after the dryer starts, then the flame starts and the ignitor shuts off. If the ignitor does not glow then it or the thermostat is bad. If the ignitor is glowing but the gas does not light then the flame sensor may have to be replaced. If the gas ignites but does not stay on either the flame sensor or the coils are at fault.
See also: http://home.howstuffworks.com/how-to-repair-a-dryer.htm
Oct 23, 2009 | Dryers
Gas dryer will not stop running and has no heat
The sensors will not shut down the dryer until the dampness goes away and if you have paid the gas bill, I would assume the gas carrying apparatus within the machine has gone haywire. Quite simply when the clothes are wet the control klixon sends current to the gas assembly. Within the gas assembly is the flame sensor, the igniter and the gas operator solenoids. The power is fed first to the sensor and then to the igniter. The coils also are hot and on the same circuit. Those coils won't open the gas valve because of the enormous rate of power it takes to fire up that igniter. The flame sensor has a bi-metal within it that determines the heat of the igniter and when the temperature reaches 1800f then the sensor shuts down power to the igniter and all of the energy is toosed in the direction of those solenoids. They snap down and yank the spring loaded gas valve open and fuel flows outward right onto the screaming hot igniter. Houston we have ignition. So what can go wrong? If the fuse is blown due to excesive lint or blocked air flow then no power will get to the gas assembly. If the power is getting there then if the sensor is open the igniter wont glow. Since the silicon carbide igniter becomes a resister in the same circuit when the flame hits it, the gas coils themselves will not fire off if the igniter is faulty. The solenoids themselves will get hot and quit,cool down and work some more.
Oct 14, 2009 | Whirlpool LGR6636 Gas Dryer
Not drying clothes not producing heat
Aug 26, 2009 | Dryers
Oven doesn't heat up
Hi, Even though your igniter is glowing it's bad..A igniter should glow brillient yellow for it to be able to light the gas...basically whats happening in your case is although the igniter is drawing the correct amps to open the gas valve it is not getting hot enough quick enough to light it..change the igniter and you should be good to go. Good Luck!!! Mike
Aug 17, 2009 | Ovens
After starting my GE gas dryer , the burner fires and everything seems fine . The burner stays on for a few minutes and shuts off like it's supposed to . After a few minutes , the glow element turns on to...
Watch the igniter. Does it glow bright orange, then shut off without igniting the gas? (When the gas ignites there's a large blue flame.) If so, there may be defective coils on the gas valve. Mounted on the top of modern gas valves, there are black electrical coils. The coils, when energized, open the gas valve. If one or more of the coils are defective, the valve doesn't open and the gas cannot ignite. Because it's often difficult to properly test the coils, it's usually best to replace both (all) of them at the same time.
Aug 01, 2009 | Dryers
Maytag Atlantis MDG7400AW Gas Dryer Logo
105 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
