Question about Price Pfister R897EBK Brushed Nickel Catalina Single Handle Shower Only Tri
I cannot get the water to turn off no matter how far i turn the handle
    Scholar:
  • 81 Answers
Once your cover plate is removed you can access the cartridge. With different styles by Price Pfister there maybe an additional pressure balancing part behind the cartridge. If so they should both be replace at the same time. Remove and take to your local plumbing parts store for a match up.
Posted on May 29, 2010
I have two vanities and a shower in the bathroom. We only get hot water to the sinks when we turn on the shower to hot. Even if we turn off the shower we will still get hot water for a while. It just seems...
Check the water supply lines to the shower at the faucet handles. If the fitting for the hot water line connected to the handle is loose, it can twist and kink off the water supply further down the line when you turn the faucet handle. I'm not exactly sure how this could be relevant otherwise, but under normal design circumstances this type of scenario with your shower wouldn't matter for other faucets.
May 01, 2011 | Delta Faucet Bathroom Faucet - Delta 2...
Cant get valve to shut off no matter how far it turns either direction. Hat could be causing this?
Having looked at the diagrams of the valve I not sure the handle is tight on your stem an is not turning the valve stem.
Look at that and if that's not it I will try to help.
Feb 01, 2011 | Grohe Integrated 1/2'' Shower Thermostatic...
How doi i get the cover plate off to get the valve out
http://www.pricepfister.com/www/ImageAssets/mirror/model/bath/catalina/catr89-7eb/ex-808-01.pdf The cover plate is held in place with part #972-300. That part has threads on the inside like a typical nut. Grab firmly ann twist counterclockwise.
Apr 26, 2010 | Price Pfister R897EBK Brushed Nickel...
I have a new delta in my shower. It gives me very little hot water. I removed the handle and turned the ring for more hot water. But the teeth do not line up.
YOU CAN ONLY TURN THE ANTI SCOLD SO FAR.WHEN IT IS ADJUST RIGHT (110 DEG).THE HANDLE SHOULD BE AT 10-11 O"CLOCK, SETTING .BELIEVE ME ,IT NEVER FEELS THAT HOT!!
Apr 15, 2010 | Delta & Single Handle Shower Faucet
No cold water
Anti Scald Valves have an adjustment under the handle (remove handle) to allow so much hot water in no matter how far handle is turned. Its possible that the adjustment is set to allow only hot water in, this of course defeats the purpose of anti-scalding. Check to see if you can adjust this back. Good Luck have a Great Day. Please give a 4 THUMBS UP if this free answer was of any help.
Apr 01, 2010 | Ldr Industries 520 1300C ADJUSTABLE SHOWER...
We have a newly installed Delta single-handle shower faucet and cannot figure out HOW to get a warm water mix. No matter where we turn the handle, we get different temperatures of "cold."
That is a graduated water mixer valve, and it sometimes has a little white water restrictor blocking flow from your hot water port. See if that was left in by removing the handle with all water shut off to the valve and reattach then try again. This can also happen if you have a tankless water heater because pressure controls heat. Typically a Tankless water heater system will require little, to no cold water to your bathtub valve because of the heavy water flow at the tap. Remember, flow equals temperature. Less flow = more heat, more flow = less heat.
Mar 09, 2010 | Delta & Single Handle Shower Faucet
Warmer water
take handle off and turn stem 180 degrees and put handle back on,...should be fixed.
Nov 04, 2009 | Moen & Posi-Temp Single Handle Shower Or...
Price Pfister R897EBK Brushed Nickel Catalina Single Handle Shower Only Tri Logo
171 people viewed this question
Top Price Pfister Home Experts
Mike
Tim Whalen
Donni Steen
Are you a Price Pfister Home Expert? Answer questions, earn points and help others
