Question about Sharp AR-5320 Black and White Copier
Its a New Sharp AR-5316 Printer and it is showing F2-40, this is a new original sharp copier, so I think replacing toner isn't the problem, what do I do?
    President:
  • Sharp Master
  • 1,447 Answers
# interrupt 0 interrupt press 16 press printkey
Posted on May 01, 2010
I had the same problem, tried the code provided and still no luck ANY HELP???????
Posted on May 23, 2010
3 Suggested Answers
  • 34 Answers
SOURCE: I have copier in the name of Olivetu 16 cpm like
If that machine is not made by Sharp you can't interchange toners with other machines. On Sharps If you get a F2 code it means the toner ratio and sensors are not calibrated correctly probably due to the toner not being compatible. If it is compatible the sensor could be dirty and it needs to be calibrated again.
Posted on Mar 22, 2010
  • 74 Answers
SOURCE: copier
The problem is that the toner sensor is not recognizing that type of toner. All toner is not the same you will cause more damage to the machine. Use the specified manufacturer toner.
Posted on Apr 01, 2010
Sharp AR 5316 Maching Toner LED Light 3 Min. Blinking, and them start. Please Toner Curm reseting code.
Have you tried to replace the toner???? Are you sure the light that is blinking for the toner?????
Jan 13, 2013 | Sharp AR-5316 Advanced Digital Imager...
My machine model is SHARP AR 5520,the problem is that the machine is returning all the toner into the waste bin,all the toner will be sent into waste within an hour or two.this happened when i refilled the...
hello,
problem is your toner cartridge. inside of the toner cartridge have a toner roller it's didn't circling.or you are using duplicate toner powder.it's doesn't match with sharp ar 5520 developer. or your developer was expired.
first use original toner and try to make copies .i think your problem is solved.
Feb 05, 2011 | Sharp AR-5316 Advanced Digital Imager...
Problem with the Sharp -COPIERS - AR165 Call servis F2-04
Hi, this is a problem to do with the toner cartridge.
Answer
  • Try to remove it out and re-insert it.
  • Replace the compatible toner sensor with the old one.
  • Please use Ar 202ft original toner cartridge which fits this machine.
  • Your problem is now solved good times.
Nov 22, 2010 | Sharp AR-5316 Advanced Digital Imager...
Sharp AR-5316
The toner cartridge comes with on-chip sensor that counts the toner life. If you allow it to go empty completely that is it gives red triangle which is steady to warn that toner is near empty. You should replenish toner at this time but if you allow it to blink red triangle, that means its completely over and can't be refilled. REPLACE A NEW TONER CARTRIDGE.
May 06, 2010 | Sharp AR-5316 Advanced Digital Imager...
Ar-5316 showing error ch
CH steady means cover is open. Close either front or right cover well.
CH blinking means developer unit or toner cartridge not installed. Remove and return well and firmly.
Nov 22, 2009 | Sharp AR-5316 Advanced Digital Imager...
SHARP AR-5316 MAINTENACE RESET
To reset maintenance codes requires going into service mode. This should only be done by an authorized trained technician as changing or adjusting something in this mode could create all sorts of problems you dont want to deal with.
Mar 17, 2009 | Sharp AR-5316 Advanced Digital Imager...
Add toner still blinking of sharp AR-5316
the best you can do is to replace the toner cartridge itself. It won't work if you just refill it.
Oct 31, 2008 | Sharp AR-5316 Advanced Digital Imager...
REPLACING THE TONER
HI! I HAVE BOUGHT THE SHARP PRINTER/COPIER/FAX/SCAN MODEL AR-M155, WHEN I INSERTED THE NEW TONNER AND MAKE THE PHOTOCOPY TESTING I GOT THE OUTPUT COPY WHICH SHOWS THE HALFED COPY IN VERTICAL ON RIGHT HAND SIDE WHEN YOU READ THAT PAPER SO WHAT COULD BE THE PROBLEM ON IT WHILE IT IS NEW MACHINE???? AM SCARED!!!. PLEASE IWOULD BE VERY HAPPY IF YOU HELP ME TO SOLVE THIS MY REQUEST PROBLEM.
THANKS,
Aggrey34
Sep 16, 2008 | Sharp AR-5316 Advanced Digital Imager...
Ar-5316
I'm not to clear on the request. Please resubmit.
Jun 04, 2008 | Sharp AR-5316 Advanced Digital Imager...
Sharp AR-5320 Black and White Copier Logo
145 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
