Can we make more hot in the asbestos cement sheet
I have an asbestos cement sheet ;
can we make more heat in the asbestos cement sheet by using chemicals ?
  • ruzky May 11, 2010
    Asbestos sheeting is carcinogenic - in other words it can give you cancer - you should not interfere with it as it can be hazadous to your health
  • Heating & Co... Master
  • 2,463 Answers
No asbestos will ony heat to certain temp then it will pop , then you will expose the fiders inside , have you not heard of asbestosos ,
Posted on Apr 26, 2010
Is there any asbestos I creda 59055B models
You will need to call the manufacturer. Don't be surprised if it does. Asbestos is still used in many products today. If you are not sure, treat it as if it does contain asbestos. The main concern is not to breath any asbestos particles. This can only happen if the asbestos is disturbed by drilling, scraping, crushing or anything that can make it air borne. So if it is broken, cracked or crumbling, do not use it. Call an asbestos hot line to find out how to dispose of it.
Feb 24, 2016 | Heating & Cooling
How do I keep the seal in place on the door of the century wood burning stove.
Go to the local hardware, Lowe's or Home Depot and look for a product called "Gasketing Cement and Stove Sealer". Meeco's Red Devil is one manufacturer of the product. It withstands temps up to 2000 degrees. Cut the tip and run a moderate sized bead in the groove of the door or the front of the stove. Place the pre-cut NEW non-asbestos gasket in place and tamp it in lightly with your fingers. Then close the door to mold the gasket to the surface and don't disturb it until the sealant cures....ususally onernight or a full day while you are at work. Do not have a fire in the stove at the time.
Nov 22, 2014 | Century Heating The WHISTLER Wood-Burning...
Can you install class-A cotton foil-backed insulation in a furnace heat exchanger duct
HVAC Insulation Cotton thermo acoustic duct wrap reduces noise and increases HVAC...
None of these products are used INSIDE the heat exchanger. If the problem is a cracked heat exchanger, you may be able tp purchase replacement parts to repair it
How to Fix Cracked Furnace Heat Exchanger DoItYourself com
The heat exchanger must be free of cracks and holes due to the potential of carbon monoxide leakage. You can probably make a short term repair with sheet metal and high heat furnace refractory cement, but that is a quick fix only.
Please be aware of the potential for a lethal situation due to carbon monoxide poisoning.
May 26, 2014 | Cozy (W352E) Heater
Is there asbestos in every 3 way frigde
Asbestos is not used in any industry without notifications. There is no asbestos in the refrigerator
Mar 22, 2014 | Engel Freezer 22 Qt. Fridge/Freezer
Oil filled radiator not hot enough after thermostat replacement
maybe you got the wrong thermostat try fixing the old one or getting a better one
Dec 17, 2013 | DeLonghi Heating & Cooling
I dropped a microwave oven months ago exposing a white material inside. i just put it in a spare room, but i have moved it many times just dropping it until this white material ended up on my floor. i...
The asbestos is to prevent a heat insulation but if only there is any shield failure you need to worry. This could have come from within the chamber and so you can get to buy these to be fitted on to the slot covering the magnetron.
To find if there is leak of any radiation you need to have a tester. but if the covers are intact and the door shuts fine then there is no cause for alarm except that asbestos must not fall into the food.
Apr 01, 2011 | Ovens
Gravity heaters - Asbestos
yes look into it. also have carbon monoxide levels checked.
Aug 17, 2009 | Heating & Cooling
Pipe cutter is crushing the asbestoes cement pipe
I think you are supposed to rotate the cutter around the pipe. If this is so then use a small amount of pressure and then rotate, repeat until pipe is cut.
The cutters could be blunt in which case they must be replaced.
Mar 05, 2009 | Wheeler Rex Pipe Cutter No.29908
Heating & Cooling Logo
78 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
