Question about Sharp AR-235 Copier
I have an Sharp AR-235 and the key operatorcode is lost
I have an Sharp AR-235 and the key operatorcode is changed and nobody knows the new code. It is not 00000. How do I reset the code.
  • 328 Answers
Enter command 22-13 and see operator code
Posted on May 27, 2010
SHARP-235, lp 6-10 CALL FOR SERVICE CODE...Sep 2010 ... What does error code L6-10 mean on a Sharp AR-235 ... my machine sharp a 235 say call for service lp 6-10 what dos it mean
L6 10 Content Polygon motor lock trouble
Details The polygon motor does not rotate.
The motor lock signal is detected for 6sec
or more after the polygon motor rotates.
The motor lock signal is detected for 1sec
during rotation of the polygon motor.
Cause Polygon motor unit failure
Polygon motor connection harness trouble
or disconnection
MCU PWB failure
Check
and
remedy
Check the polygon motor operation with
SIM 61-1.
Check connector/harness of polygon
motor
Replace the polygon motor.
Replace the MCU PWB.
If the polygon motor isn't working then you will neeto buy a new Laser Unit. They can be expensive if you can get one. To replace it will tak alot of disassembly as well. Might be better and more cost effective to get a new machine.
Oct 22, 2011 | Sharp AR-235 Copier
I have a sharp ar-235 what does call service code U2-40 mean
CRUM chip communication trouble = the chip on the toner cartridge is faulty.
1, Try to clear the code press P, *, C, *, to enter the service simulation, on the key pad press 1,6, then the copy start, press execute on the screen.
2, Change the toner cartridge.
If it is a brand new one return to supplier as fault, if it is a refilled new one take back to supplier (the CRUM chip serves as a genuine supplies protection for sharp and 'blows' when the toner is empty the re-filler will have to put a new chip on it)
Nov 04, 2010 | Sharp AR-235 Copier
SHARP-235, F5-02 CALL FOR SERVICE CODE
Sep 2010 ... What does error code L6-10 mean on a Sharp AR-235 ... my machine sharp a 235 say call for service u9-99 what dos it mean and how can i
Sep 04, 2010 | Sharp AR-235 Copier
Drivers for Sharp ar 235 printer for windows 7
sharp ar-235 cannot work with win7.apply win xp and install.
Jun 29, 2010 | Sharp AR-235 Copier
Sharp AR 235, output light
You have to change the Developer in the developing unit. code is: AR271D
This procedure must be done by a copier tech.
Feb 15, 2010 | Sharp AR-235 Copier
Sharp AR 235 error code E1-11
Abnormality on the IMC board.
Try resetting by pressing # / interrupt / c / interrupt.
punch 14 and ok / enter.
restart your copier.
if it doesn't work you will need a tech.
Jun 17, 2009 | Sharp AR-235 Copier
F9-00 (Print Function) Error Code on Sharp AR-287
this copier will display f9-00 if the nework is not connected or the card is bad this means network connection lost usaally resting copier will work if the network is on if not call service
Mar 03, 2009 | Sharp AR-235 Copier
Lost key operator code for Sharp Copier AR-M207.
The default is 00000
Simulation 22 - 07 will display the Key operator code.
Perform the following procedure to enter the simulation mode.
"#" key -> “*“ (star) key -> "C" key -> “*“ (star) key (do this in quick sequence order, the display should change, then enter below)
Main code {22} ->
(Green Copy Button) Start key ->
Sub code {07} ->
(Green Copy Button)Start key
Press the "CA" button to go back to Copy mode.
Jan 24, 2009 | Sharp AR-M237 Copier
Sharp AR-235 Copier Logo
237 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
