Question about Lexmark E232 Laser Printer
Need to reset photoconductor kit
Installed new toner cartridge and the photoconductor did not reset, how do I reset the photoconductor kit
  • Official Brand Answer
  • 3,344 Answers
How to reset PC kit:
1. Open the front door cover while the printer is on.
2. Press and hold the Cancel button until all the lights starts flashing.
3. Close the front door cover.
Print a test page to check if the counter has been reset.
If still not reset, follow the instructions carefully in this article found in the Lexmark website. Just click on this link: http://bit.ly/anGz2O. Hope this helps. If you need more assistance, leave a comment and I'll get back to it. Thanks.
Posted on Apr 26, 2010
  • youngforgood Jun 05, 2011
    How simple!
    Thanks.
You have to hold the "Cancel" and "Continue" buttons simultaneously while the front doo is open to get this to work.
Posted on Feb 05, 2012
PC life warning
This means that the photoconductor has reached the end of life; on other printers, this is called the drum. It transfers the toner onto the page during printing so that it will fuse to the paper. The replacement is $70 from Lexmark: http://www.lexmark.com/US/en/view/Ink/Toner%20&%20Supplies/X340,-X342-Photoconductor-Kit/catId=cat170003-category&prodId=3599-product . The replacement should last about 30000 pages.
To replace the unit after you get a replacement, open the front cover and pull out the print cartridge assembly by the handle. Put the assembly on a flat surface. Remove the toner cartridge by pressing the button on the assembly and pulling on the handle. Open the new photoconductor kit and snap the toner cartridge into place on it. Then slide the new assembly into the printer. The steps are shown here: http://support.lexmark.com/index?page=answerlink&userlocale=en_US&segment=SUPPORT&locale=en&url=http%3A%2F%2Fsupport.lexmark.com%2Findex%3Fpage%3Dcontent%26id%3DSO4365%26actp%3Dsearch%26viewlocale%3Den_US&productCode=&answerid=16777217&searchid=1397780403561 .
After installing this, you need to reset the photoconductor counter.
With the printer on, open the front cover and press and hold Stop for 5+ seconds. When you see Resetting PC Counter release the Stop button. Close the front cover when prompted to do so.
If this doesn't clear the error, try powering off the printer for 10 seconds. Otherwise, try unplugging the printer for a minute to reset the internal memory. If the unit still doesn't reset the counter, it may need service. Contact Lexmark.
I hope this helps.
Apr 17, 2014 | Lexmark X342n All-In-One Laser Printer
Grinding noise
could be the laser unit on top of the printer out of whack -i have the same fault also
Jun 29, 2012 | Lexmark E120n Laser Printer
The printer toner light is continuously flashing even after putting in a new cartridge
After installing a new cartridge and the blinking light is on Toner Low, it means that the photoconductor is almost full and should be replaced soon. Press and release the Continue button (green button) to clear the light sequence and continue processing the print job. If the light is still blinking, replace the photoconductor kit.
For further assistance, please call Lexmark Technical Support.
Jun 14, 2011 | Lexmark E260D - QTY 4 - LMB OFFER Laser...
We have a Dell 1700 at our office and the drum light is flashing and the page prints out stating the photoconductor kit is at the end of its useful life - so we ordered a new one. We received and installed...
There is nothing on the photoconductor unit to 'tell' the printer that it is new, you have to do this yourself, by following the photocinductor reset procedure (it's in the manual, or
Dell 1700
RESETTING DRUM PAGE COUNTER
1) Leave the power on, insert toner cartridge, and leave door open
2) Press the cancel button and hold till the leds flash
3) Release cancel button and close toner cartridge door
May 12, 2010 | Dell 1700n Laser Printer
Dell 1700 is giving me an error about the Toner. It also prints out a page telling me to replace the photoconductor kit. I have replaced the photoconductor and the toner but it still has the same error and...
The printer has no way of knnowing that you have changed the Photoconductor Unit, unless you tell it (as there is not chip on the Photoconductor).
The Photconductor reset procedure is as follows.
Dell 1700
Apr 08, 2010 | Dell 1700n Laser Printer
TONER LIGHT STAYS ON WITH NEW TONER CARTRIDGE
If the main problem is just the toner light on then what you could do after installing the new toner is resetting the printer. You could do that by powering the printer off, open the front cover (as if you were to replace the toner) with the front cover open and the printer off push and hold the two buttons on the printer and turn the printer on while holding down the buttons then once the bottom light stays on solid, release the two buttons and that should reset the printer.
Now if the toner light is blinking that means that you have reached the 30,000 page mark and the Photoconductor needs to be replaced. If that is not the case you can follow this link to a procedure where it will explain how to reset the Photoconductor. http://bit.ly/91SWS3
Mar 04, 2010 | Lexmark E232 Laser Printer
Power up init fails
When you replaced the photoconductor, did you go through the procedure to reset the photoconductor counter ?
There's no chip on the photoconductor, so you need to reset this manually
Photoconductor Reset Procedures:
Step 1:
Open the front door and hold the
Cancel button until all lights begin to cycle.
Step 2: Close the front door. The warning
clears and the counter resets to zero.
Step 3: Press Continue to resume printing.
Mar 01, 2010 | Lexmark E120n Laser Printer
Toner light still blinking orange after new toner installed. Rebooted printer, light still blinking.
It means you need to replace the photoconductor kit (the bit the toner fits into) reset information is supplied with the new photoconductor kit.
Oct 15, 2008 | Lexmark E232 Laser Printer
Resetting Lexmark E340 after replacing photoconductor kit
Reset Procedure(s) after installing new photoconductor kit
Resetting the Lexmark E340/342 (display type) machines
1) Turn the printer off
2) While still off, press and hold the SELECT and RETURN buttons.
3) Keep both buttons pressed, and turn the printer on. Continue to hold both until either “Performing self test” or “Config menu”
appears on the display.
4) Release the two buttons
5) RESET PC CNT should now show on the display. If it does not, press the left or right menu buttons until it does.
6) Press the SELECT button once. “Resetting PC Cnt Value” should show on the display.
7) When the display shows CONFIG MENU again, turn the printer off.
8) Turn the printer back on. (Do not hold any buttons down this time). The printer is reset.
You can confirm the counter was reset by printing a “menu settings page”.
Jun 04, 2008 | Lexmark E340 Laser Printer
Lexmark E232 Laser Printer Logo
2,870 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
