Question about Brother HL 1440 Laser Printer
Vertical black stripes in print output. What to do?
    Problem Solver:
  • 18 Answers
Clean your print cartridge head by using the software that came with the printer or by referring to the manual
Posted on Apr 26, 2010
Black stripe when printing from hp laserjet 2840
Cartridge faulty...
Two ways you can find out the faulty cartridge.
1. Remove each cartridge, just flip the drum shutter & chk for any toner bands appears on drum surface.. if found replace that cartridge..
2. Go to the paint. create four colored page as shown, print & verify which colored print mixed with bads.. replace that cartrdige.. ">
Mar 01, 2014 | HP LaserJet 2840 All-In-One Printer
Printing on heavy paper gets a black vertical stripe
make sure all the catridges are fine and it is not getting leaked .if possible then remove the catridge and clean it and also when you give print command that time aslo you chosse paper type and size in printer properties option.
Jan 19, 2010 | Epson Stylus Photo 1290 InkJet Printer
Black vertical stripe on screen, any input
good day sir/maam, the black vertical stripe on screen could either be onscreen data input/output,so check your manual, worst it could be failure of the vertical amplifier stage. It could also be interference. at this point its kinda hard to isolate the problem, only diagnostics tools found on service centers could find the fault. better check your local service shop if they could take a look at it.
Oct 13, 2009 | Vizio P2 42 in. HD-Ready Plasma Television
Have just placed new toner cartridge., prints have black stripes
Try cleaning the charger wire on top of the toner/drum unit. It should have a green plastic knob/handle to slide the cleaner left to right and back. Do this several times.
Sep 29, 2009 | Brother HL-2040 Laser Printer
9 year old Toshiba TV. The picture is totally
Symptom shows TV got problem in vertical out deflection section, please check and replace vertical output IC and nearby electrolytic capacitors.
Jun 25, 2009 | Toshiba Televison & Video
Pale vertical stripe on black prints
It sounds like the black drum unit needs to be replaced.
Apr 23, 2009 | Ricoh Aficio CL3500N Laser Printer
Copying with 4" solid black vertical stripe
what about if you print from computer or do an internal print like a self test? if print looks good on those, you most likely have a scanner problem, which is the mechanism under the glass.
razors
Jan 12, 2009 | HP OfficeJet 6210 All-In-One InkJet...
Possible Print Head Issue
Select the Jet Substitution Mode.
  1. On the Control Panel, select Troubleshooting, and then press the OK button.
  2. Select Print Quality Problems, and then press the OK button.
  3. Select Eliminate Light Stripes, and then press the OK button.
  4. Select Jet Substitution Mode, and then press the OK button.
  5. Follow the Control Panel prompts to select the color and malfunctioning jet number indicated on the Light Stripes Test page.
Mar 25, 2008 | Xerox Phaser 8550DX Laser Printer
Brother HL 1440 Laser Printer Logo
242 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
