Question about Zanussi IZ161S Front Load Washer
I have a Zanussi 1600 Jet System Washing Machine, it has started the cycle and 4 mins into it, an E10 error reads on the display, have turned the machine off, and back on, checked pipes, can see you physical sign of blockage, could you please help ... Much appreciated if you could
  • 269 Answers
This error code relates to water pressure check that the pipes are not kinked,check the water valves are fully on also check if the little filters in the end of the hoses are cleaned.Make sure that the mains water pressure has not been reduced.There could still be a fault with one of the inlet valves but it is most probably the little gauze filters
Posted on May 04, 2010
I have a Zanussi Jet System 1600 (5 years old), for the last two weeks it wont empty the fabric conditioner and also shows up error code E20
Posted on Jun 14, 2010
I have a zanussi jet system 1600 and it's not allowing us to do a wash,we start the wash and it shows as 1.40 mins till complete then it jumps to 3 mins and stops,it's leaving all are clothes soaking and...
i guess its machine pcb error. take out front pcb and dry it well and reconnect to washing machine. still its not working you have to replace 8000 mhz xtal in control pcb.
Jun 05, 2014 | Washing Machines
Zanussi jet stream 1600 door locked
SOUNDS LIKE THE LATCH IS NOT WORKING AS IT SHOUD. I WOULD START BY REPLACING IT FIRST.
May 23, 2014 | Zanussi IZ161S Front Load Washer
My washing machine keeps flashing e10 what is the problem
E10 - not filling make sure the water is turned fully on and pipes are not frozen if in garage. when you have checked everything then turn off machine at control panel and then unplug it for 5 mins then plug back in turn on and start cycle it should start to fill. hope this helped.
Dec 28, 2010 | Zanussi FJS1225W Front Load Washer
My Zanussi ZWF14581 washing machine shows an error
The error code E10 is in relation to low water pressure.Have you checked that the hose at rear is not kinked or check the filters in the ends of the hose.Also make sure when you have hose off check the pressure in the supply.If all that is ok then it could be a faulty solenoid valve.
Hope this helps.
May 09, 2010 | Washing Machines
Zanussi Jet Stream 1600 is displaying E10 as it has started its cycle to wash. Can you tell me what this means please?
I found that the water pipes were frozen! so I have 'gently' defrosted them and we are now working...
Thanks
Jan 10, 2010 | Zanussi IZ161S Front Load Washer
Error 10 message
Hi
E10 means there is no water getting in to machine.
check water supply if ok then fault will be fill valve.
regards
Mar 07, 2009 | Zanussi ZWF1430W Front Load Washer
E10 code on a zanussi jet system washer
Is it a washer-dryer? E10 relates to a fault with the inlet valve.....usually the valve itself going open circuit.
Feb 26, 2009 | Zanussi WJS1265W Front Load Washer/Dryer
Just wont work
  1. Turn it off.
  2. Unplug it.
  3. Wait 5 or 10 minutes.
  4. Plug it in.
  5. Turn it on.
Apr 09, 2008 | Washing Machines
Zanussi IZ161S Water filling problem
Check the drainpump. It may be clogged with lint or something, or blocked.
Jan 14, 2008 | Zanussi IZ161S Front Load Washer
Error E90
That happened to mine, and apparently it is the connection to the control panal at the front of the machine or the desplay unit (4 blue wires). Take the top off and wiggle them around or re-connect if any are loose. Mine worked for one wash and then started displaying E10........so i'm not amused and I think i may end up getting a hotpoint!
Nov 09, 2006 | Zanussi WJS1265W Front Load Washer/Dryer
Zanussi IZ161S Front Load Washer Logo
1,080 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
