Question about Baxter OV300E Stainless Steel Electric Oven
Oven not staying up to temp when doing bagles
  • The link below is geared more towards residential ovens. If your oven is dropping more than 100 degrees below the set points then you could have a problem, most bagel programs have an airflow delay during which time the oven will not heat. Before the cooking cycle is over you should notice the temperature coming back up, if the temp doesn't come back up or the temperature displays start flashing then you have an issue with your burner or elements and you should have it serviced by an authorized technician.
  • Baxter Master
  • 43,501 Answers
Check out this tip that I wrote about this problem...
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
Posted on Apr 28, 2010
When I light my oven, it stays on full all the time. Is it the thermostate
I'd recommend buying an oven temp dial to stick in your oven to verify the actual temp. Then you can turn on the oven using a lower setting and write down the temp for the setting. Then as you slowly adjust the setting higher and higher, note each temp. If it doesn't show a consistent increase of temp for each setting, you may need it calibrated or replaced. Good luck!
Sep 18, 2014 | Ovens
Oven sometimes doesn't stay up to temp
The temp is controlled by electronics that monitor the oven sensor.
The sensor should ohm out at 1100 ohms.
If it is shirted to frame or open the open temp would not do right and the
oven control would not know what the temp was and would probably declare an F-3 error.
In your case I don't think that is the problem. What i think it is going to be is the ignitor. If it is getting weak it sometimes won't draw enough amps to open the safety bimetal inside the gas valve.
Probably the ignitor is on it's way out.
Jul 30, 2011 | Maytag CWG3100A Gas Single Oven
Fan and light work, oven stays cold
one of three things are possible:either you are missing part of your 240volts at input power,or a bad neutral power wire to heating element,an oven temp control,or the thermocouple that controls oven temp
Aug 22, 2009 | Ovens
Maytag MGR5745ADA Gas stove/oven. Oven takes very long to reach pre-heat temp. Think it is the temp sensor, but unsure how to locate and remove
i did a clean on my oven maytag model mgr5745ada. when i try to use the oven the preheat lite stays on for only a few seconds then i get either a f4 alarm or f1 alarm. what do i need?
Jul 14, 2009 | Maytag Ovens
Oven turn's on, keep's heatings at a higher temp.
This is failed communication between the EOC and the temp sensors located in the oven. i recommend testing the EOC(break point test on the pins) for its operational value and the temp sensors as well. replace any component that doesn't register.
I would also inspect the oven temp sensors for welded harness and fouled housings.
In most cases, this will be a EOC issue.
May 24, 2009 | Frigidaire 30 in. Electric Gallery Series...
My oven won't heat to the right temp.
Check the temp censer in the oven It went bad.
Feb 26, 2009 | Frigidaire FEB27S5A Electric Single Oven
Oven will not stay on
I used what Charlie recommended ...” post-it” as insulation
And works PERFECTLY….
I have a Kenmore oven Clock…( built in the wall)
Thanks Charlie…you are a Genius!!!!
Jul 29, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Kenmore electric oven
Sears Kenmore Electric Wall OVen, Mod.#9114012192 purchased in 1993. Set oven for 425 degrees, reaches set temperature, stays on about 10 minutes and temp. display goes out and oven starts cooling down. Will not stay on desired temp.to cook. Can you tell me what my problem is? Thanks. Doug.
Dec 02, 2007 | Ovens
Baxter OV300E Stainless Steel Electric Oven Logo
204 people viewed this question
Top Baxter Ovens Experts
Owen Barnes
joneable
Level 1 Expert
Are you a Baxter Oven Expert? Answer questions, earn points and help others
