Question about Westinghouse WST2000 IntelliBLEND Work Top Blender
Blender is not doing anything
I plugged in my blender the power light comes on when I press it. Also all the button lights come on when I prees them. The problem is the blender does not work. What am I not doing right or is there a mal function? I cannot find my manual and this is the first time I am using the blender.
  • William Psencik
    William Psencik May 19, 2008
    I used the blender 10 times before it quit. Power comes on but the motor does not work. I found an open connection at the motor winding. Between the brush and the winding there is a item that could be a fuse link but I cannot tell because it's wrapped in black plastic. I have not been able to find parts. WST2019 is the model number. White intelli blend blender
  • Anonymous Nov 12, 2008
    I have the same damn problem and now I am looking for a blender with the same features, but one that will actually work after more than a few freaken uses!
I have had my blender sitting for over a year ( only used it once ) because of the same problem and asked my husband to take a look at it... he opened it ... cut the zip ties took the metal banding off ( note only one side of the motor has the metal banding). What you need to get at is behind the first (I think) resistor. Behind that is a thermal fuse (found at radio shack part # 270-1320 about $1.96). you will need some kind of tester to check the ohms going through it (should read zero) the bad one on mine read 334 ohms and you will need a soldering iron to put it back together. Actually a good project for someone who loves to tinker with this. Also note the shaft of the motor for turning the blender blade screws off be careful not to pull at it. Hope this helps.
Posted on Jun 29, 2008
    Problem Solver:
  • 13 Answers
Either the motor is inoperable, or is improperly wired. return it to the retailer. that is assuming you have the cup firmly seated before you try to operate the machine.also if the control panel has more than one speed make certain that only one button, or switch position is engaged
Posted on Apr 05, 2008
3 Suggested Answers
  • 142 Answers
SOURCE: Intelli blender will not work
Do you hear it hum when you try to turn it on?
If yes, remove the cup. Try again... if the motor runs, try moving the blade by hand. If it is seized, remove it and clean it to free it again.
If not, possibly blown windings on the motor or divider circuit (which supplies different voltages to the motor for the different blend speeds). Repair will be required in either case.
Posted on Mar 24, 2008
SOURCE: westinghouse WST2000 IntelliBlend
My 6700 0ster blender won't come on when power button is pressed. What do I need to do?
check the wall plug to prove there is power with an appliance known to work. If still inoperative, return for service or buy a new one.
6700 0ster blender Google Search
Feb 10, 2017 | Blenders
Why won't the blender start? the on/off light keeps blinking
my Ninja blender wont turn on, power button keeps blinking red ...
https://answers.yahoo.com/question/index?qid...
Dec 11, 2011 - I know I"m not supposed to drown myself in the toilet yet the don't build in a head protector. The blinking light won't go off. It worked last night ...
Ninja Blender Red Light Is Flashing ' Appliance Repair ...
appliancerepairquestions.com/question/ninja-blender-red-light-is-flashing/
Mar 29, 2015 - My new Ninja Blender has a power button that is flashing red. ... and the top of the blender is on and secure but the light keeps blinking / flashing. ... How do I set the oven off from demo mode asked by Anonymous, 2 months ago ....Whirlpool MDU1955XTSS2 won't turn on asked by Anonymous, 4 months ...
cuisinart blender red light flashing but Questions & Answers ...
www.fixya.com > Forum > Tags
Dec 26, 2015 | Euro-Pro Ninja Nj600 1000 Watt Xl...
My cuisinart spb-7 blender won't spin
How do I replace the blender blade driver clutch? I have the part but do not know how to get it in.
Jun 13, 2009 | Cuisinart SPB-7 SmartPower Work Top...
Lights/LED lit up, but blender does not start!
The motor brushes may be in need of replacement.
Sep 09, 2017 | Cuisinart CB-600 Blender
Kitchen Aid blender
to see if its the Triac or just the off button perform this: connect the blender,while pressing the off button press the on button; if the blender stays on and you dont hear the relay function (Light ticky sound) maybe the off button get a broken solder point. But if the relay is functioning and there is no way to change the speed the problen is the TRIAC. This is a small piece on PCB with a heat sink
Aug 30, 2008 | KitchenAid KSB3 Classic Work Top Blender
Mar 24, 2008 | Westinghouse WST2000 IntelliBLEND Work Top...
Westinghouse WST2000 IntelliBlend
Aug 29, 2007 | Westinghouse WST2000 IntelliBLEND Work Top...
Blinking lights on KitchenAid blender
Alternating blinking lights on a Kitchenaid blender indicate a bad circuit board which is unable to run the motor properly. Unplug the blender, take the jar off, and turn the spindle by hand. Then plug it back in. If it does not work properly, try a different outlet (perhaps not in the kitchen). If nothing works, the blender needs to be repaired.
Aug 27, 2007 | KitchenAid KSB3 Classic Work Top Blender
Westinghouse WST2000 IntelliBLEND Work Top Blender Logo
406 people viewed this question
Top Westinghouse Blenders Experts
eyecam
ray gallant
Tom Chichester
Are you a Westinghouse Blender Expert? Answer questions, earn points and help others
